#15 |
AutoX-10/10ths every run
Can't wait to get my hands on one of these and put it in.
#16 | |
PhoneFlash by EcuTeK
You head unit does not have the app installed. The app will be available through the Google Play Store when it is released and can be downloaded from there. You head unit will allow for this and we will make sure it works properly on the head unit as we have them in our vehicles also. You will need the "PowerPlug" module (what we call it, without the FlexFuel aspect) to control other aspects of the vehicle if you like via BlueTooth. This will be priced around $425 as a full plug in solution without the FlexFuel aspects. You will also need our tune to make it work as expected but should allow for a little more control on your end through our application. Cheers, William Knose Delicious Tuning |
#17 | |
In this configuration (Jackson Racing CARB tune and our FlexFuel Kit) it will also throw a CEL for the rear O2 sensor, which would cause a fail. You can very easily disconnect it from the rear O2 sensor and the vehicle will run properly. In order for the Delicious Tuning FlexFuel BT Kit everything to work correctly you would need to purchase the following. Delicious Tuning Flash & Go Tune Delicious Tuning FlexFuel BT Kit Delicious Tuning 11 PSI Map Sensor You can always switch back to the CARB tune whenever you choose, by following these steps. Make sure you are 91 octane (or very close) Install stock OEM 5 PSI Map Sensor (5 mins) Disconnect Rear O2 Sensor FlexFuel Input (1 min) Reflash Jackson Racing Tune (5 mins) Cheers, William Knose Delicious Tuning |
| The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post: |
#18 |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | whataboutbob (12-30-2014) |
#19 |
Drives: 86
More vids!
..especially NA tunes vids
#20 |
building life
Drives: Raven Black, 6MT
#21 |
That Guy
Drives: 2013 asphalt FRS MT
#23 |
Drives: sti 2012 sedan
What are the differences between this kit which uses the the o2 sensor and the old kit which taps the evap line? Is it better to use the o2 line?
#24 |
from the way i understand it is the difference is that the old kit you had to wire up a gauge display to show your e content where as the new kit you can use your phone instead of having to install a gauge. but i could be wrong
#25 |
We are back and sending out tunes today that were ordered on January 2nd or later. Just trying to catch up on 300+ emails from the holidays and lots of voicemails.
If you ordered before this your tune has already been sent. If you have not received it, please check your spam folder and if not in their please email us. Cheers, William Knose Delicious Tuning |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | whataboutbob (01-30-2015) |
#26 | |
The older kits would require running wires through the firewall and through the passenger compartment to the ECU. Then you would need to either splice into the ECU harness OR purchase and additional adapter harness for $100 which makes those kits even more expensive. We just wanted to make it a lot easier to install and remove when the time came. Lastly you can view your ethanol content with your phone, with the free app we offer with the kit. App coming out soon. Cheers, William Knose Delicious Tuning |
| The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | lucid215 (01-07-2015), whataboutbob (01-30-2015) |
#27 |
Drives: 2017 Camaro 1SS
Any update on when these will ship?
#28 |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | brianhj (01-21-2015) |
| Delicious Tuning - Q&A EcuTeK ProECU Tuning and Maps | DeliciousTuning | Software Tuning | 1213 | 06-17-2025 04:02 PM |
| 200+ WHP Completely Stock Vehicle, E85 and EcuTeK ProECU RaceROM Only (VIDEO) | DeliciousTuning | Software Tuning | 156 | 07-01-2014 08:37 PM |
| Delicious Tuning - 200+ whp E85, Stock Headers, EcuTeK ProECU | DeliciousTuning | Software Tuning | 19 | 12-07-2013 12:01 PM |
| Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-19-2013 05:58 PM |
| Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-13-2013 01:34 AM |
