Old 09-05-2013, 12:25 AM   #15
mobybrz
Drives: White 2013 BRZ
Originally Posted by nix View Post
There is no 'if it retains moisture'. It does. Doesn't matter if it's cheapo wrap or the best DEI offers, it will trap water and accelerate corrosion over time.
The 'paints' are OK - not as effective overall as a quality wrap but a good compromise on price for a daily driver car. The ceramic coatings are better, the best available and really the only long term choice is from Zircotec in the UK which is a permanent coating that will last the life of the pipe and is used by F1/WRC/Indy/LMP1 teams.
Sorry to cause any confusion, I said 'if' because I have no data to backup it doing so.
I can't imagine the paints do any good at all either, but again, no data to go from. Zircotec* is great stuff, probably the only thing better than Swain that I have encountered. But I would note that the last time I dealt with them, they recommended against coating any of the inside of headers, which Swain is comfortable doing. I have not data to support it, but the internal coating SHOULD keep heat out of the metal and extend life.
If we are talking about the life of headers, which is frankly probably a silly discussion on these cars, coating inside would help whereas outside would hurt. The teams you are talking about are more concerned about keeping their body work from catching fire or electronics from melting. Longevity is not their concern beyond 24hrs (or 6 weekends in F1).
Originally Posted by campy View Post
So wraps will cause rust and coatings will peel off?
properly applied and maintained they shouldn't do either.
*Zircotec also has coatings that will protect carbon fiber and composites. You can see what is likely some Zircotec products on the rear floor of the current RedBull F1 car.
mobybrz is offline   Reply With Quote
Old 09-05-2013, 01:09 AM   #16
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
The biggest issue with wraps are the fact that they can also retain oil from any leak and will act like a candle wick. Fuel + heat + oxygen = sad driver.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 09-05-2013, 07:33 AM   #17
nix
nix's Avatar
Drives: AVO BRZ
That was a paranoia of mine (shadowed now by the fuel leak fires lol).
Good points, I don't know anything about Swain! But I have heard of even the basic zircotec lasting forever on manifolds that uncoated were going full cherry.
I haven't tried it yet because of the shipping costs to the UK but they are opening a new coating facility in AU next year.
On the wrap - yes I agree with proper application so long as it's checked & maintained/replaced every year or so depending on conditions it should be fine.
nix is offline   Reply With Quote
Old 09-06-2013, 05:05 PM   #18
CyberCT
Drives: RSX
I had my RSX Comptech 304 Stainless shorty header head coated. I think it was by Swaintech. It may have cost me $250 or so, I don't exactly remember. But I did buy the header used for $100 and spent time taking the bits of rust off it before sending it in. They do a sandblast I believe anyway.
The underhood temps of my car were reduced dramatically. Highly recommended, and it still is holding up well to this day.
CyberCT is offline   Reply With Quote
The Following 2 Users Say Thank You to CyberCT For This Useful Post:
nix (09-06-2013), unsurety (06-12-2014)
Old 09-06-2013, 05:17 PM   #19
tinma
Drives: '13 BRZ
Miss the rsx at all? Or the new car filling all the needs? :p sry to get off topic haha
tinma is offline   Reply With Quote
Old 09-06-2013, 06:42 PM   #20
CyberCT
Drives: RSX
The RSX will be my winger beater or car for kayaking / outdoorsy trips. So its not going anywhere
Old 06-09-2014, 06:33 AM   #21
Boba_kz
As I understand Zircotec really effective coating but requires plasma equipment.
Is there any another alternative coating paint which can be used without any specific equipment?
Boba_kz is offline   Reply With Quote
Old 06-12-2014, 08:51 PM   #22
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I found a somewhat local place that can coat headers inside and out. Is there a consensus on what's best? Ceramic coating inside and out, inside only, outside only... ?
Silly question too... does it matter if the flanges are coated or not as well?
unsurety is offline   Reply With Quote
Old 06-13-2014, 01:58 PM   #23
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Rust Oleum High Heat Paint!!
Old 12-28-2014, 10:03 PM   #24
Alltezza
Alltezza's Avatar
Drives: WRB Limited BRZ
Lol sorry to bring back an old thread but hey at least I'm using the search function.
But anyways! Since we are on the topic about thermal coating.
I was on here http://jdlautodesign.net/shop/ft86-c...length-header/
Looking at JDL UEL headers and I noticed that there is an optional thermal coating. Is there a difference between Black thermal coating and Titanium? What is better and what does it do?
Does our stock headers even have thermal coating on them?
Alltezza is offline   Reply With Quote
Old 12-28-2014, 10:16 PM   #25
DarkSunrise
DarkSunrise's Avatar
I went with the titanium coating. I think it's worthwhile on these cars if you go to the track. If you notice, most of the coil pack failures are on the cylinders directly above the primary cat. A lot of heat seems to get trapped in that area just below the ECU. The header also surrounds the oil pan.
What the thermal coating does is reduce radiant heat coming off the header. In theory, this would reduce oil temps and prolong the life of the coil packs. I say "in theory" because, while thermal coating has been generally tested and found effective, I don't think anybody has specifically tested its effects on this platform. But for $100-150, I think it's an easy call.
FWIW I had my car at a local muffler shop over the weekend and they were surprised how quickly the header got cool compared to most cars they've worked on. I explained to them that the header was thermal coated and they said that made sense.
Stock header does not have any coating, but does have a heat shield.
2022 BRZ Build
2013 FR-S Build
Old 12-28-2014, 10:31 PM   #26
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I wonder what the % of people with coil pack failures had non-coated aftermarket header....versus those who had failures with stock header or ceramic coated header.
Even with the heat shields on the factory header it gets very toasty in there, I can only imagine the additional heat being radiated with a raw header.
Fizz is offline   Reply With Quote
Old 12-28-2014, 10:43 PM   #27
phrosty
If this is a problem, I imagine it only affects catted headers. Catless ones should retain significantly less heat.
phrosty is offline   Reply With Quote
Old 12-28-2014, 11:13 PM   #28
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
I had my header coated, inside and out. 2000 degree ceramic on the outside, I don't remember what he used on the inside. I have been happy with it and so far it still looks like new.
Lunatic is offline   Reply With Quote
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Ceramic Coating options or Jet hot coating brzadmir NY / NJ / CT / PA 4 07-10-2013 12:35 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
