Old 12-24-2014, 10:54 AM   #5797
brianhj
Drives: 2017 Camaro 1SS
http://www.ft86club.com/forums/showp...postcount=3819
I found that post. So what have I done to the engine/supercharger running without that connected? Mine came broken just like in post #3819
brianhj is offline   Reply With Quote
Old 12-24-2014, 10:58 AM   #5798
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
No clue but I'd get that fixed ASAP
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 12-24-2014, 10:58 AM   #5799
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
Was wondering if you saw my post.... They really should add a note to take off the tower supports..... Depending on the butterfly position you have either been running under some boast even at idle, or you have a massive leak because that valve is open. Either way, definitely stop driving the car and call sprintex to get a replacement - you will need a 6mm and 5mm Allen socket to get it off and back on
mikalem is offline   Reply With Quote
The Following 2 Users Say Thank You to mikalem For This Useful Post:
brianhj (12-24-2014), CK_Bladesmith (12-24-2014)
Old 12-24-2014, 11:41 AM   #5800
brianhj
Thanks!! So it will run even better than it already is?? Hahaha
The Following User Says Thank You to brianhj For This Useful Post:
mikalem (12-24-2014)
Old 12-25-2014, 04:44 AM   #5801
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by stockysnail View Post
Upon your recommendation I picked up the idler pulley NuLine EP075. I could only find it in Australia unfortunately as O'Reiley doesn't carry it anymore. Shipping was more than the part. At least it was still only $33. Hopefully this fixes the squeak that started a couple months ago as it's starting to get annoying. Hopefully this is the part that's making the noise.
My sprintex kit has only been on for a week and I've noticed an annoying high pitched squeak that is most audible at low throttle and low rpm. The sound increases (in pace but not volume) with revs/speed but then disappears once the engine is fully warmed.
Is this a symptom of idler pulley failure, or something else?
Fizz is offline   Reply With Quote
Old 12-25-2014, 06:47 AM   #5802
steve99
Drives: FT86
check your belt tension , if its a toothed belt it does not need to be super tight like v belt,hopefully you were given tension specs.
a large\long screwdriver can be used as a stethoscope to find noises and crook bearings. crook bearing generally make a grating sound. listen to some good ones first to get the idea of what it sounds like.
stick the metal blade end on or near the bearing\pulley\area you want to listen to , then stick your ear on the plastic handle end. Will consentrate the sound so you can work out where th noise is comming from. obviously be carefull not to stick it to close to moving belts ect.
if you think its an air leak squirt some soapy water on pipe connections ect and look for any bubbles.
did you hose clamp all the lines on\under the intake maifold
Fizz (12-25-2014)
Old 12-25-2014, 09:15 AM   #5803
xxscaxx
Drives: 2013 SWP BRZ
You cannot adjust the tension. We have an auto tensioner on these cars, and there are no toothed belts. All the rest is good advice though.
xxscaxx is offline   Reply With Quote
The Following User Says Thank You to xxscaxx For This Useful Post:
steve99 (12-25-2014)
Old 12-27-2014, 08:13 AM   #5804
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@whataboutbob @stockysnail
When you guys replaced the idler pulley, was it just the one directly below the charger pulley, or did you also replace the one below the A/C pulley?
Old 12-27-2014, 02:31 PM   #5805
stockysnail
Just the tip
stockysnail's Avatar
Down and left of supercharger, down and right from alternator, above belt tension pulley. I haven't got mine in the mail yet however.
The Following 2 Users Say Thank You to stockysnail For This Useful Post:
Fizz (12-27-2014), whataboutbob (12-27-2014)
Old 12-27-2014, 02:39 PM   #5806
whataboutbob
AutoX-10/10ths every run
This.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Fizz (12-27-2014)
Old 12-27-2014, 06:08 PM   #5807
xxscaxx
yes its the pulley that you have to add to run the supercharger in the first place.
Fizz (12-27-2014)
Old 12-27-2014, 07:29 PM   #5808
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
LoL I'm glad I asked....all the while I thought it was the factory idler pulleys that were failing
Old 12-27-2014, 07:47 PM   #5809
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
If I were to install an aftermarket wideband O2 sensor/gauge, that sits in place of if factory rear O2 sensor, does my tuner need to recalibrate the tuned map to account for the new sensor?
Or can I just install it and run without any adjustments to the tune?
Old 12-27-2014, 08:51 PM   #5810
xxscaxx
the rear O2 only monitors the cat...you wouldn't need to adjust the tune but he would have to turn off the code that would be associated with unplugging the rear o2 sensor.
So yes you can just install it and run it, but you will have a CEL.
regarding the pulleys, honestly I have a squeak and I have replaced that idler pulley. I'm fairly certain its coming from the alternator but it comes and goes so I haven't bothered really examining it lol
Fizz (12-27-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
