Old 12-26-2014, 10:48 PM   #1
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Brake Rotors: Rusted Stuck
Went to install the TF Brake Duct kit today and got stuck at the rotors. Silly place to get stuck, but they are REALLY on there. Tried letting it soak for a few hours in PB Blaster, hammering at it with a big rubber mallet and regular hammer, and used the threaded rod for the spare tire hold down in the removal holes. I eventually found bolts from my ZO6 I have torn apart right now that fit the rotor holes and used that to push off the passenger side. It eventually gave. However, I tried that cautiously on the driver side and ended up stripping the holes....they are absolutely stripped.
I have the car soaking in PB (not convinced it will do any good) and will go at it again tomorrow with a bigass hammer. I'm sure I'll destroy the rotor in the process. Clearly, I'm relatively new to some of this...so I'm open to suggestions on how to get this thing off without ruining a wheel hub bearing along with the rotor. Need to be ready for Sebring on the 7th, gotta get this done!
Suggestions?
Apex_BRZ is offline   Reply With Quote
Old 12-26-2014, 11:10 PM   #2
Apex_BRZ
Going to try this tomorrow. Seems like everybody has good luck doing it.
[ame="https://www.youtube.com/watch?v=mtsTJCRljAs"]Remove Rusted Brake Rotors ( Easy for any car or truck ) - YouTube[/ame]
The Following 2 Users Say Thank You to Apex_BRZ For This Useful Post:
fx35s (12-27-2014), jimmillion (12-26-2014)
Old 12-26-2014, 11:35 PM   #3
jimmillion
Power Ranger Elite
jimmillion's Avatar
Drives: '13 WRB Sport-tech
Not gonna lie, watched the video and was throughly impressed with the simplicity.
jimmillion is offline   Reply With Quote
Old 12-26-2014, 11:38 PM   #4
Apex_BRZ
I have high hopes, and really can't think of a reason why it shouldn't work. I do, however, have some concerns for the rotor face on the backside. I have some thin pieces of wood I will tuck in there, but I'm not sure it'll protect it.
Unfortunately, I've dinged the passenger side rotor already with a hammer. Only one, and not bad. Might just get some new centric blanks.
Old 12-26-2014, 11:41 PM   #5
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Throw a couple lug nuts on (leaving 2-3mm of thread showing on the stud) and use a hammer to hit inbetween them a few times. Like your trying to force the rotor onto the wheel hub. Usually in the shop that takes care of any problem rotors.
Old 12-27-2014, 01:25 AM   #6
Apex_BRZ
I think I'll try the bolt and nuts method above before trying anything potentially destructive.
Old 12-27-2014, 01:35 AM   #7
Poodles
Drives: 2015 Series.Blue
Attack the hub with a steel bristle brush and get all the rust off so the rotor can slide off.
Old 12-27-2014, 09:01 AM   #8
wparsons
wparsons's Avatar
If you don't want to harm the rotors, use the proper method. The video above will ruin the back surface of the rotor.
Look at the center (hub area) of the rotor, there are two threaded holes. Thread a bolt into them and it'll push the rotor off the hub without damaging the rotor area. IIRC the bolt you need is 8 x 1.25mm, but I'm not sure. There's info (and videos) all over the internet documenting this for WRX's (which run the same front rotors).
flickr
D_Thissen (12-27-2014)
Old 12-27-2014, 12:33 PM   #9
CoupedUpSubie
Drives: 2013 BRZ Limited
He stripped those holes already.
OP, with how stuck your rotors seem to be I would just replace them. When you do take a wire brush to everything you can on the hub. Then take and apply a thin coat of anti-seize or high-temp grease. A very thin coat is all that is needed.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline   Reply With Quote
The Following 3 Users Say Thank You to CoupedUpSubie For This Useful Post:
AZP Installs (01-28-2015), Calum (01-04-2015), Ultramaroon (12-27-2014)
Old 12-27-2014, 01:07 PM   #10
Apex_BRZ
Used the method from the video above and had them off in 5min. So easy it was embarrassing. Put a couple plastic shims in to protect the rotor face, but it scored the surface anyway. They were stuck so bad it literally dug through the plastic into the rotor. I may just replace them, if I should even worry about it. I'll post pics later and see what you guys think. Moving on with the install for now, thanks for the advice.
Old 12-27-2014, 01:57 PM   #11
Apex_BRZ
Any advice on removing the wheel hubs? They are also stuck on there...
Is it safe to use something to push in from the rear of it in the center? Looks aluminum and the bearings may be in there.
Old 12-27-2014, 02:17 PM   #12
Unless you have some fancy-schmancy ones, rotors are cheap consumables.
Old 12-27-2014, 07:48 PM   #13
wparsons
wparsons's Avatar
Just an FYI, the spare tire hold down is not the right threads for the front rotors. I tried, couldn't get it to thread, bought the right bolts and got mine off without issue.
flickr
Old 12-27-2014, 11:07 PM   #14
Ozzman
Drives: old
Why in tarnation are you removing the hubs? Don't remove em unless you are planning to replace em.
Ozzman is offline   Reply With Quote
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 12:29 PM
FS: OEM Brake Rotors SuiSid3l Brakes, Suspension, Chassis 3 12-23-2014 02:55 PM
Project Mu - Brake Pads, Rotors and Brake Cooling Duct - FREE SHIPPING! eauto Brakes, Suspension, Chassis 255 10-15-2014 01:45 PM
BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC SOURCE,LLC Brakes, Suspension, Chassis 94 07-07-2013 10:56 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
