Old 12-25-2014, 06:31 PM   #1037
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
We I'll probably be close to 500 hp. I know there are 17x9.5 wheels but not very many choices.
texasbound972 is offline   Reply With Quote
Old 12-25-2014, 07:38 PM   #1038
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
It's also about wide enough tires that don't have super tall sidewalls on 17s. Why do t you want 18s??
Old 12-25-2014, 07:39 PM   #1039
texasbound972
USMC
Tires are less expensive. I don't know, I was under the impression that the bigger you go the more show it is and not as much performance.
Old 12-26-2014, 02:45 AM   #1040
0ricardo0
Drives: Raven FRS
Question wheel & tire noob
After reading through the entire thread I think I may get it or I've just confused myself lol. Figured, I'll just ask specifically what I'd like to know.
The wheels I like are 18x9.5 and come in both a +35 and +40 offset. I planned on lowering the car on TRD springs only. Will a square setup work w/ out any rubbing issues (mainly in the front, since that's where it seems the issue lies) or the need for other modifications like fender rolling, etc? If so, what would be the meatiest tires I could use (once again, I'd like a square setup instead of staggered) to go along w/ them?
If the 9.5 is too wide for the front to fit w/ TRD springs as opposed to coils, what would be the best staggered setup I could get to work (wheel & tire)?
Thanks for the help in advance & I apologize for the noob questions. It's been a long couple days lol. Loving everyone's pics & setups. The whole meaty tire look is absolutely amazing.
0ricardo0 is offline   Reply With Quote
Old 12-26-2014, 03:01 AM   #1041
texasbound972
USMC
On the eibach pros I had there was less than half an inch between my wheel and strut. I have the xxr 535 17x8.25 on 245's.
Old 12-26-2014, 04:35 PM   #1042
JEFFSTYLE
hi
JEFFSTYLE's Avatar
Drives: 2013 BRZ Limited
Send a message via AIM to JEFFSTYLE
What's your setup as far as suspension? Also are you running LCA's?
Originally Posted by 10Stars View Post
Looks good man! I wanted to do that same setup.
What suspension do you have on?
Thanks guys, I'm running Fortune Auto 500's v4 with roller bearing upgrade. stock LCA's.
JEFFSTYLE is offline   Reply With Quote
The Following User Says Thank You to JEFFSTYLE For This Useful Post:
texasbound972 (12-26-2014)
Old 12-26-2014, 05:05 PM   #1043
BRZ Stefan
BRZ Stefan's Avatar
Drives: 2014 Subaru BRZ
Will this fit stock? Also, I'm planning on getting Hotchkis springs to lower the car about an inch, hence why I have a 1inch drop. I just want to know, with the amount of poke, do I have to worry about the tire hitting the fender? It is a +20 offset wheel that I want.
BRZ Stefan is offline   Reply With Quote
Old 12-26-2014, 05:55 PM   #1044
Pete156
I like to eat!
18x9.5s will rub your stock front struts unless you go crazy offset with a bunch of poke. Square setups are best in my opinion. The car handles well and rotation means getting the most miles out of a set.
I have three square sets. Stock, 18x8s with 225s and 18x9.5s with 255s. I will probably try the staggered setup in 2015 for shits and grins at an autocross or two.
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
BRZ Stefan (12-27-2014)
Old 12-26-2014, 06:22 PM   #1045
texasbound972
USMC
What's the limit for tire width on 18x9.5's?
Old 12-26-2014, 07:48 PM   #1046
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Even with 265 hankook rs3's my 525whp/415tq is absolutely useless. Also have a set of 255 nitto nt05's on 17x9 and they are useless as well. At 400whp, I could manage by peddling. I have Mickey Thompson et street radials for the rear for next season. I'm over the rolling burnout game lol
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following User Says Thank You to spitfire481 For This Useful Post:
Old 12-26-2014, 10:45 PM   #1047
texasbound972
USMC
So I could fit 275's in the rear with 18x9.5?
Old 12-26-2014, 11:17 PM   #1048
spitfire481
Drives: 2JZ FRS
I had 265/35/18 on 18x9.5 et43 and a 275/35 should have cleared I believe. -2 camber front, -2.2 rear
MoTeC
Build Thread
@spitfire481
texasbound972 (12-27-2014)
Old 12-27-2014, 10:05 AM   #1049
BlaineWasHere
Grip>Drift
Drives: FRS
Yes, that's about the widest you can get with just suspension mods and no fender mods. Good luck!
Old 12-27-2014, 03:02 PM   #1050
BRZ Stefan
BRZ Stefan's Avatar
Is +20 off set crazy enough?
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
