#29 |
Drives: BRZ DIT;VX220 T;'85 Silvia S12 FJ20
#30 |
in orbe terrum non visi
Drives: violent
From what I've seen there is no difference in the two engines DI system. Maxx ed out on e85 no one has been able to make much power without adding the fa20 PI system. So enlighten me. The only advantage I see here is the ability to use the oil pump gear from the fa20dit. Since it can't be adapted due to a diffrent cover.
Reliability? I have 14,000 miles at 400wtq on the stock engine. I'll keep my 12.5:1 over the fa20dit lower compression anyday. Low compression bis for people with shirt fuel.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
#31 |
Very funny thing about the DI system.
Everybody seems to think that the system is quite the same. It definitely isnīt. There is substantial difference in the DI systems. Both the DI pump and Injectors flow significantly more than the D4-S System (Iīll not give you the numbers please understand) Further as you state "from what Iīve seen", you didnīt ahve a deep look into the DIT did you? But honestly, even w/o having a close look. Did you really assume that a 200 hp mixed injection DI system has the same spec like a 300 hp full DI? |
#32 |
Road-hole
Drives: 2013 Whiteout FR-S
why couldn't you???
#33 | |
So elite I'm 1338
Drives: WRB Subaru BRZ
I wasn't well versed on the engine replacement laws @ the ARB.
-Jack Burton |
#34 |
re E85 that needs quite a lot more flow by itself because of itīs stoichiometric ratio (9,85 E85 to 14,7 gasoline), so maybe a bad example for comparison.
think again about relation CR/boost taking in consideration the IC and itīs thermodynamic function. It makes sense that boosted engines have a lower CR. At this point again: std DIT can put down 521 Nm of torque just below 3000 rpm. Quite impressive I think and letīs one assume a not so badly chosen CR. |
#35 | |
Drives: violent
#36 |
Drives: violent
By the way I make more torque than you on a stock engine. Guess my cr isn't that bad.
#37 |
So elite I'm 1338
The greatest appeal of the fa20dit to me, is a factory turbo.
Personally, I'd take a factory turbo over any aftermarket turbo set-up for reliability. No additional tuning, or anything. A fa20dit, operating under normal conditions at factory settings and output is all I could even want in my BRZ. Plus, You will NEVER smog an aftermarket turbo in California.
-Jack Burton |
#38 |
Drives: 2005 Toyota Camry
I just realized something... this kit may alter one or more mounting points, including relocating intercooler.
If that's the case, most likely as-is it won't pass BAR unless the parts can be made CARB-exempt. It's such a niche market that most likely @Speedhead won't bother trying to get it certified... but given that the engine needs to be out of same MY or newer car, anyone wanting a completely certified, street-legal DIT swap in California would need to get over the hump of trying to find a complete engine for sale for no less than $7k+. At that price point I'd consider turboing the factory FA20 D4S first. -alex |
#39 | |
Road-hole
While the dit would be nice...
Later on for less than 10K I could even add an e force supercharger for 600hp... I've done some of the preliminary measurements and the entire rear end should be able to be bolted on with some fabbed up adapter plates although some body work would be needed and probably a wide body kit or rocket bunny of some type to use the wheels from the camaro. But those BIG BRAKES..... ![]() Jaden |
#40 |
Drives: GT 86
#41 |
#42 | |
The Australian engines listed above are 2012, won't work. Love it or hate it, that's how the laws are here. -alex |
| FA20DIT vs FA20 D4-s? | hmong337 | Forced Induction | 31 | 07-26-2020 02:11 AM |
| *** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** | Sonic Motor | Brakes, Suspension, Chassis | 489 | 07-29-2016 02:15 PM |
| Convert NA FA20 to FA20DIT in the WRX | SunkenFRS | Forced Induction | 21 | 03-15-2015 08:59 PM |
| FA20DIT parts | glorydays | Forced Induction | 8 | 03-14-2014 05:03 PM |
| FA20DIT vs EJ25 - 2015 WRX and STI get dyno tested | kbye | Other Vehicles & General Automotive Discussions | 7 | 02-27-2014 09:40 AM |
