#71 |
Drives: 2015 Raven FRS
Installed my new GTR wing today. Still have a lot of fine tuning to do, more angle for more down force, and re-paint. Also I'm going to have to add the center support and it's a bit flexible with out it. All in all I really like it.
#72 |
Got my Cusco LSD installed today. Can't wait to try it out Friday.
#73 |
You and your wife are just awesome. I hope to have family track days with my future wife one day. But first gotta teach her stick shift :/
#74 |
I got my new AP Sprint big brake kit today, but won't install it until my current pads are wore out.
| The Following User Says Thank You to Lunatic For This Useful Post: | 10Stars (12-17-2014) |
#75 |
Just got my car back from the paint shop. I added a wing off a Nissan GTR, that we modified to work better. I basically fit the car but we made spacers to fill the gap between the wing and trunk lid. And made spacers with 1 inch of angle added to change the angle of attack of the wing to actually give me some sown force. And we made a new center support and wired in the brake light.
So all this got painted plus the new side skirts. |
#76 |
Drives: Lightning Red '13 Limited BRZ
Looks beautiful except for that column...no way to do a reinforcing piece along the underside of the wing for stability instead?
#77 |
I agree. There actually is a center support for the stock GTR wing but we had to make a longer one. The wing is just to flimsy with out it. I'm going to try to make something more streamed lined latter on.
#78 |
I'm no engineer or anything, far from it, but what about a metal beam attached to the underside to reinforce the rigidity? Something not too noticeable.
#79 |
I put my new AP Sprint brake kit on today. Tomorrow I'll finish bleeding the brakes then off to West End Alignment for corner weighting and alignment.
#80 | |
Drives: RX-7 / BRZ
After it is shaped you need to drill a hole from the top though the center so you can run the wire for the LED lights. I also drilled a small hole in the decklid to run the wiring though. Since I used the factory center support it used the 2-screw mount TO the spoiler. On the bottom I used 2-sided body moulding tape and a dab of silicone around the wire hole (to keep water out if it gets past the tape.) Goodluck. ~
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#81 | |
#82 |
Your car is the tits. Love it!
2013 Series 10 FRS #553
#83 |
Drives: 2016 FR-S
How would you compare the Maxxis RC-1s to the Hoosiers and other tires you have tried with the FRS?
#84 |
The maxis are not as sticky as the Hoosiers, but talk to you where the hoosiers don't. This can be another tool in learning. I really liked the Nitto NT01s but they were with a different suspension set up so I can't give a fair comparison.
| *** Feal Suspension, Megan Racing, BC Racing, KSport, ISIS Coilovers - ON SALE!!! *** | Sonic Motor | Brakes, Suspension, Chassis | 489 | 07-29-2016 02:15 PM |
| Update Vivid Racing Cool Wall E90 M3 KW's Status Racing Seats | vividracing | Other Vehicles & General Automotive Discussions | 0 | 12-03-2013 11:59 AM |
| Cipher Racing 5 Point Quick Release Racing Harness 5 COLOR | Tubano-shop | Interior Parts (Incl. Lighting) | 2 | 05-27-2013 07:36 AM |
