#5797 |
Drives: 2017 Camaro 1SS
http://www.ft86club.com/forums/showp...postcount=3819
I found that post. So what have I done to the engine/supercharger running without that connected? Mine came broken just like in post #3819 |
#5798 | |
Drives: Raven FR-S
No clue but I'd get that fixed ASAP
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
#5799 | |
Drives: 2020 DGM BRZ Limited
| The Following 2 Users Say Thank You to mikalem For This Useful Post: | brianhj (12-24-2014), CK_Bladesmith (12-24-2014) |
#5800 |
Thanks!! So it will run even better than it already is?? Hahaha
| The Following User Says Thank You to brianhj For This Useful Post: | mikalem (12-24-2014) |
#5801 | |
Senior Addict
Drives: 86 GT
Is this a symptom of idler pulley failure, or something else? |
#5802 | |
Drives: FT86
a large\long screwdriver can be used as a stethoscope to find noises and crook bearings. crook bearing generally make a grating sound. listen to some good ones first to get the idea of what it sounds like. stick the metal blade end on or near the bearing\pulley\area you want to listen to , then stick your ear on the plastic handle end. Will consentrate the sound so you can work out where th noise is comming from. obviously be carefull not to stick it to close to moving belts ect. if you think its an air leak squirt some soapy water on pipe connections ect and look for any bubbles. did you hose clamp all the lines on\under the intake maifold |
| The Following User Says Thank You to steve99 For This Useful Post: | Fizz (12-25-2014) |
#5803 |
Drives: 2013 SWP BRZ
You cannot adjust the tension. We have an auto tensioner on these cars, and there are no toothed belts. All the rest is good advice though.
| The Following User Says Thank You to xxscaxx For This Useful Post: | steve99 (12-25-2014) |
#5804 |
Senior Addict
Drives: 86 GT
@whataboutbob @stockysnail
When you guys replaced the idler pulley, was it just the one directly below the charger pulley, or did you also replace the one below the A/C pulley? |
#5805 | |
Just the tip
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following 2 Users Say Thank You to stockysnail For This Useful Post: | Fizz (12-27-2014), whataboutbob (12-27-2014) |
#5806 |
AutoX-10/10ths every run
This.
| The Following User Says Thank You to whataboutbob For This Useful Post: | Fizz (12-27-2014) |
#5807 |
yes its the pulley that you have to add to run the supercharger in the first place.
| The Following User Says Thank You to xxscaxx For This Useful Post: | Fizz (12-27-2014) |
#5808 |
Senior Addict
Drives: 86 GT
LoL I'm glad I asked....all the while I thought it was the factory idler pulleys that were failing
#5809 |
Senior Addict
Drives: 86 GT
If I were to install an aftermarket wideband O2 sensor/gauge, that sits in place of if factory rear O2 sensor, does my tuner need to recalibrate the tuned map to account for the new sensor?
Or can I just install it and run without any adjustments to the tune? |
#5810 | |
So yes you can just install it and run it, but you will have a CEL. regarding the pulleys, honestly I have a squeak and I have replaced that idler pulley. I'm fairly certain its coming from the alternator but it comes and goes so I haven't bothered really examining it lol |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
