Old 12-19-2014, 07:17 PM   #57
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
+1 on that. I am expecting a nice step up (Stage 2 UEL) with Shiv's custom tune once I have all the pieces installed, running 94+ octane really helps. I got a nice compare the other week when my local station was out of 100 for like a week. Had to run 91 and the car slowly dialed back to just "good" instead of fantastic. Once back to 94+ within 30-40 miles it picked right back up. This car loves octane. I would fill up with 100 but my wallet she cries...
F1fletch is offline   Reply With Quote
The Following User Says Thank You to F1fletch For This Useful Post:
Koa (12-19-2014)
Old 12-19-2014, 09:00 PM   #58
Koa
Stage II UEL 91 Octane off the shelf OFT
OFH UEL + Grimmspeed Intake
3rd gear pull
http://tinyurl.com/Koa-3rdpull-OFHplusGSIntake
AFR at 11.25, low LTFT, no knock, hoping to scale MAF and dial in everything else. Could I get some feedback? Tuner noob relative to a lot of ya'll here.
Could re-check the intake filter's distance from MAF flange, as it needs to be exactly 1 inch difference there for best performance.
The Following User Says Thank You to Koa For This Useful Post:
200hp/tonne (12-19-2014)
Old 12-19-2014, 10:18 PM   #59
steve99
Drives: FT86
3rd gear pull
If you scale maf on stage 2 tunes its going to run a lot leaner top end as the afr will follow the OL fuel table , like its supposed to. however on anything but the best fuel your going to get knock once you get near 12 afr top end. the rich mix buys you knock resistance. carnt remember off top of my head but think ol fuel table top high 11 afr stage 2 petrol tunes. Im pretty sure the OFT guys do this on purpose so the tunes are safe on all fuels even 91.
you could probably shoot for 11.8 top end and still be pretty safe, 11.3 is pretty rich. for an NA motor. if you go leaner than high 11 then keep a good watch on knock when everything is hot and you rearly start to need a dyno to see you not starting to loose power.
Koa (12-19-2014)
Old 12-22-2014, 08:21 PM   #60
TruRace
TruRace's Avatar
Drives: FRS-Raven-MT
Iv'e been running this intake with UEL header and e85 for a while now. Haven't noticed anything crazy. It does run a bit rich from what I've seen. I took a couple logs tonight to post up if anyone is curious how the car runs with this intake and tune.
http://datazap.me/u/trurace/stg2-e85...=2-3-6-8-12-13
TruRace is offline   Reply With Quote
Old 12-22-2014, 08:58 PM   #61
Koa
actually that looks very nice...
I'm running into a problem where my OFT doesn't recognize IAM or maf voltage.. trying to debug it
Old 12-23-2014, 01:04 PM   #62
Cop
Cop's Avatar
Drives: 2013 FRS
I've taken my first shot at logging AFR data with the GS intake this morning to familiarize myself with the process, so far it seems pretty straight forward (big shoutout to steve99). For the best source of data, how long do I need to be recording the data, and in what conditions? By conditions I mean freeway driving, street, etc. Hopefully what I log within the next week or so is informative to the rest of the GS crowd
Cop is offline   Reply With Quote
Old 12-23-2014, 03:17 PM   #63
steve99
Drives: FT86
If your doing maf scaling using the VGI utility then you need
At least 30 minutes of smooth driving at varying loads and rpm. Racer-X on/off throttle and WOT is no good. Backroads are good for this and a bit of freeway stuff is good as well. Your trying to log data when ECU is in closed loop mode this happens at steady throttle .
Then at least 3 runs 2000 to redline at WOT in second or preferably 3rd gear . for the Open loop data.
Old 12-24-2014, 09:19 AM   #64
Turdinator
Señor Member
Turdinator's Avatar
Finally flashed this today. Feels great and LTFTs are nice and low straight off the bat. Great work @Shiv@Openflash
1974 TA22 Celica
2013 86 GT
Old 12-24-2014, 10:08 AM   #65
jaf89f
jaf89f's Avatar
Drives: Raven MT
Originally Posted by Shiv@Openflash View Post
you have email
Hey Shiv! Happy Holidays! Could you send along the same tune to me as well? I just sent you an additional follow-up email with my CAL ID included.
Thanks!!
OpenFlash Tablet Tune v2.06 E85 Stage 1 - Grimmspeed Intake, Strut Tower Brace & Master Cylinder Brace - MTEC Clutch & Shifter Springs - TRD Quickshifter - cQuartz Finest Paint Protection Coating - and more to come...
jaf89f is offline   Reply With Quote
Old 12-26-2014, 03:35 PM   #66
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
@Shiv@Openflash I e-mailed you a couple weeks back regarding the GrimmSpeed intake tune files. Just wondering if you received them or not? Please let me know!
MokSpeed is offline   Reply With Quote
Old 12-26-2014, 06:46 PM   #67
steve99
Drives: FT86
w
If your stage 1 tune its easy to make your own
their are only two tables different between grimspeed stage 1 and original v2xx oft stage1 tune
tables are
PRIMARY OL FUEL TABLE
MAF SCALING
see 700G rom zip file attached, use romraider to compare this one to the oft sage1 700G map and you will see. use the definitions from oft site for V2.xxx tunes.
then just copy and paste those two changed tables into your rom calid map
WARNING: This is only for stage1 oft maps. Stage 2 maps both petrol and E85 have offset maf scaling and different PRIMARY OL FUEL TABLES. You need to do a bit more work to get the grimspeed intake working correctly on stage 2 maps
enjoy your grimspeed intake tune
Weasel Soup (01-04-2015)
Old 12-27-2014, 03:35 PM   #68
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
tables are
MAF SCALING
see 700G rom link, use romraider to compare this one to the oft sage1 700G map and you will see. use the definitions from oft site for stage2 tunes.
https://docs.google.com/file/d/0B67a...p=docslist_api
Thanks so much for providing this google docs link for the 700G GS Intake tune. Unfortunately, I'm not having much luck getting the link to work. When I click it, a new browser window opens up, but the window is empty. Am I missing something simple that would allow me to download the 700G ROM from your google docs link? As you suggested, I just want to open this ROM up in RomRaider and compare it to other tune files that I have.
jprice130 is offline   Reply With Quote
Old 12-27-2014, 04:47 PM   #69
steve99
Drives: FT86
upoaded file now attached to post as zip file
jprice130 (12-27-2014)
Old 12-27-2014, 07:45 PM   #70
jprice130
AutoX Nut
The zip file you attached to the previous post downloaded just fine. Thanks so much!
DIY - GrimmSpeed Intake Installation Guide GrimmSpeed DIY (Do-It-Yourself) Guides 60 09-08-2017 10:12 AM
** GrimmSpeed BRZ/FR-S Air Intake - GROUP BUY ** GrimmSpeed Engine, Exhaust, Bolt-Ons 1902 08-29-2017 07:47 PM
GrimmSpeed Intake Before and After OFT Tune + Review F1fletch Engine, Exhaust, Transmission 76 06-30-2016 02:40 PM
For Sale: GrimmSpeed Intake *newish* xDanger_208x Engine, Exhaust, Bolt-Ons 13 11-30-2014 10:16 AM
WTB GrimmSpeed intake VakaGT Want-To-Buy Requests 0 11-18-2014 12:19 PM
