Old 12-21-2014, 10:17 PM   #1
Mikeez
Engineering Student
Drives: Scion FR-S 2015
Which brand of paint did you use for your headlight (Blackout)
For those who painted their headlight housing, can you please tell me the paint you used?
Brand
Matte/Gloss/Semi/Gold/
Plastidip/Plastic Paint/Etc
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 12-22-2014, 10:36 AM   #2
BlackMonarch
Drives: Red BRZ
When you say "Painted headlights" - You are indicating the internal housing, correct? After baking?
Personally did this on my old car, not on the Subie yet, but:
High-temp engine block paint in flat black. Three coats. And then a clear coat of matte finish.
Only reason I went high-temp is projectors tend to get fairly warm, and down the road I didn't want any kind of flaking.
BlackMonarch is offline   Reply With Quote
The Following User Says Thank You to BlackMonarch For This Useful Post:
hmong337 (12-23-2014)
Old 12-22-2014, 10:47 AM   #3
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
I used a duplicolor high temp Semi-Gloss Black. No Issue yet and its been a few months.
The Following User Says Thank You to DustinS For This Useful Post:
Old 12-22-2014, 11:53 AM   #4
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
I think I used Krylon for plastics. Either that or Rustoleum.
Old 12-22-2014, 02:10 PM   #5
Mikeez
Engineering Student
Yes sorry, I thought housing automatically meant the internal of it. Smart to go with high temp.
I think of going semi gloss, I am hesitant
I have access to this in my local store.
Old 12-22-2014, 02:24 PM   #6
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Transparent black/smoke/vht looks really good as a 'black chrome' look.
Old 12-22-2014, 02:45 PM   #7
DustinS
DustinS's Avatar
I have this for my high beam(duplicolor black Chrome kit). The chrome has to be super clean or it doesn't stick well. Made weird patches in the paint. I tried again with my turn signals and didn't work out at all. I went semi-gloss black once it dried.
The semi-gloss looks really good. I almost want to pick up another set and try gloss.
Old 12-22-2014, 11:18 PM   #8
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Prep work should be a given for any paint job.
Translucent paint is always going to be more sensative than solids. The blotchiness can be from quite a few senarios ranging from incorrect application to paint not being shaken up enough. Remember your spraying ontop of a smooth surface (with no tooth) applying paint to wet intially will cause it to clump up. However some rattle cans will just be patchy. Similar ecample would by if you ever attempt a very light smoke paint job on tailights with a rattle can. Due to the way the paint is sprayed you will have to due quite a few coats before the color will lay evenly. Warming the can's in some warm water or in the sun will due wonder for makeing them spray better.
Old 12-23-2014, 04:00 AM   #9
Mikeez
Engineering Student
Thanks for your inputs guys
Old 12-23-2014, 04:06 AM   #10
Mikeez
Engineering Student
Can you remove the paint done after 1-2 years ??
Old 12-23-2014, 10:38 AM   #11
DustinS
DustinS's Avatar
No?
Old 12-25-2014, 07:35 PM   #12
Mikeez
Engineering Student
No?
Paint cannot be removed once you apply it. I saw a video of people removing it using normal gasoline or something.. Its been a while I've seen the video. Maybe he was doing something else.
Old 12-25-2014, 10:42 PM   #13
GH05T
Undercover Batman
GH05T's Avatar
Lacquer Thinner makes it come right off.
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson
GH05T is offline   Reply With Quote
Old 12-26-2014, 02:23 AM   #14
Mikeez
Engineering Student
Okay, thank you for that
FR-S Headlight Reflector Blackout DarrenDriven DIY (Do-It-Yourself) Guides 476 09-26-2020 02:39 PM
Modded Headlight+Taillight Swap (Blackout, carbon fiber) for your stocks! $200! retrosmiths Exterior Parts (Aero, Lighting, Etc.) 16 04-14-2014 11:20 PM
Scion FRS Headlight Blackout Thread womensecks Cosmetic Modification (Interior/Exterior/Lighting) 3 09-24-2013 08:13 PM
Headlight housing paint job mariolefty1 Cosmetic Modification (Interior/Exterior/Lighting) 0 06-04-2013 09:50 PM
Headlight blackout help WolfsFang NY / NJ / CT / PA 10 03-24-2013 09:23 PM
