Old 12-22-2014, 03:45 PM   #1359
robr
Drives: 2013 FRS, with boost by ATS Racing
Originally Posted by Whatabouteggs View Post
Graphs? Graph graphs?
Since humpre doesn't post much, I'll grab his files from work tomorrow if he doesn't post before tomorrow night. Assuming I have his permission.
robr is offline   Reply With Quote
Old 12-22-2014, 11:54 PM   #1360
DesertFrs
DesertFrs's Avatar
Drives: Scion FRS 10 Series AVO Turbo
Just wanted to post my last tune from @DeliciousTuning earlier this year. Going back for some more mid Feb.
AVO STG1 Turbo w/ 8PSI Actuator, AVO 3" Catless Turbo Back Exhaust, AVO Air Filter, ACT 6 Puck Clutch, DW65c Fuel Pump, 900cc DW Injectors, Grimmspeed EBC, Delicious Tuning Custom Tune, 0W-20 Purol, AEM Strutbar, GrimmSpeed Hood Struts, Mann Engineering Coilovers, RacerX UCA, Gram Lights 57Xtreme, 275/35/18 BfGoodrich G-Sport Comp2 Tires, MV Designz Aero Kit, Beatsonic Shark Fin & Roof Spoiler, Five Axis Trunk Spoiler, OEMAudioPlus Reference 400
DesertFrs is offline   Reply With Quote
The Following 3 Users Say Thank You to DesertFrs For This Useful Post:
Draco_PR23 (12-23-2014), kbogarto (12-23-2014), SkAsphalt (12-28-2014)
Old 12-23-2014, 12:13 AM   #1361
GremlinGSP
Does anyone know how to source a replacement part for this kit?
I need to source a new turbo to airbox pipe. I've tried emailing avo but no luck so far. Tried one of my vendors and they said their not able to get parts either.
GremlinGSP is offline   Reply With Quote
Old 12-23-2014, 12:31 AM   #1362
Lonewolf
Lonewolf's Avatar
Drives: Moped
Avo's super responsive customer service team at it again?
Old 12-23-2014, 12:37 AM   #1363
DesertFrs
DesertFrs's Avatar
Have you tried getting a hold of Paul on here?
Old 12-23-2014, 09:43 AM   #1364
robr
Here's one of humpre's graphs. From memory, he has an AVO kit with upgraded wastegate (still wasn't holding too well up top), 3" exhaust, whatever the normal AVO downpipe size is, Perrin intake. He can chime in if I have any of that incorrect. Tuned by ATS Racing.
Peaked at 1 bar (14.7psi) on E85.
The Following 2 Users Say Thank You to robr For This Useful Post:
Draco_PR23 (12-23-2014), Whatabouteggs (12-27-2014)
Old 12-23-2014, 10:46 AM   #1365
Simisimi
Drives: 2013 BRZ Limited w/ AVO Stage 1.5T
I have the AVO turbo installed
Running the 8PSI spring (stage 1.5) that we dialed up to 9PSI with high flow cat and overpipe replacements. Seeing 291HP at the rear wheels on a Mustang Dyno. I'm told that roughly equates to 320/325HP on a DynoJet. Paul at ECS in Windsor Lochs CT did the tune and it runs great. Noticed that under 1/3 tank of fuel I can have fuel slosh issues between 4th and 5th redline shifting. More fuel in the tank solves that.
Simisimi is offline   Reply With Quote
Old 12-23-2014, 11:07 AM   #1366
kbogarto
Drives: 2013 BRZ limited WRB
Nice numbers! I've never heard of anyone having fuel slosh issues. What symptoms does this produce?
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 12-23-2014, 12:08 PM   #1367
Simisimi
Tough to tune
Less compression makes it easier to increase boost without worrying about detonation as much. However there are new tools available on modern cars that make turbos more reliable and more effective. On old carbed engines the answer was low compression, large displacement, and biggest turbo you could find, then drive around with a screwdriver in your hand hoping it doesn't blow up. FI has changed the game in that respect, and the ECM suite on the FA20 has a ton of features that even sophisticated engines from the early 2000s didn't offer. Crank position resolution, direct injection, and better supporting and tuning mods (like widebands, MAP sensors, knock sensors, failsafe conditions, temp sensors, etc.) have made it possible to run silly amounts of boost on engines with very high compression.
That said, the FA20 clearly was not made for boost. LNF's in cobalt SS's have 9:1 compression with DI, but they also run 23psi stock. Most people with reliable FI on these engines seem to top out at around 14psi on pump gas, with some notable exceptions. E85, methanol, and race gas make it much easier to make more power safely. Plus these engines are still extremely new, and knowledge isn't in supply yet.
In the end, these days a modified engine is only as good as the person that tuned it. For every 400whp on 93 success story, there are a bunch of 250whp cars that blew up on the dyno that you may or may not hear about. Unfortunately, it's difficult to nail down who the good tuners are, and shops like to change names and addresses to purge their reputations.
Personally, I'm going to hold off until I find a local/semi local tuner with an excellent reputation, and I'm waiting for someone who has been running high boost for 10k-20k to post some blowby comparisons. As it is, people keep talking about stock engines with boost as a temporary condition and built engines as mandatory, and that makes Vorshlag's LS swap kit seem like a far better option.
My Tuner has done thousands of tunes, mostly on Subarus of all types, and tells me that the FA20 with dual fuel systems and FI is one of the most challenging tunes he has encountered. In the end we seem to have a very lively and stable car at 9PSI but he believes this is very near the edge of compromising long term reliability. My AVO went in at 2000 miles and I've got 4000 more since then. So far, aside from an issue caused by the common failure of the OEM high pressure fuel pump, it's been solid. When you consider the engine output is nearly double factory spec it's remarkable. Time will tell!
The Following User Says Thank You to Simisimi For This Useful Post:
Old 12-23-2014, 12:11 PM   #1368
Simisimi
A very brief loss of power and the fuel light comes on!
Old 12-23-2014, 09:06 PM   #1369
Astroboy
Astroboy's Avatar
Drives: None
Here's a horrible incident I encountered on my car
Passenger side
NOTE: I am NOT blaming this on the turbo kit, just bad luck
I ordered a valve cover gasket to replace the current one. It'll be a great learning experience at least.
Astroboy is offline   Reply With Quote
Old 12-23-2014, 09:14 PM   #1370
kbogarto
Passenger side
Please excuse my ignorance but what exactly am I looking at?
Old 12-23-2014, 09:52 PM   #1371
Astroboy
Astroboy's Avatar
Drives: None
Just the valve cover on the passenger side. At the bottom of the pic you could see the over pipe.
The Following User Says Thank You to Astroboy For This Useful Post:
Old 12-23-2014, 09:53 PM   #1372
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
The likelihood of a valve cover gasket leaking is extremely low.
Are you sure that's not oil that ran down the side of the engine? Is that on the passenger side? My guess would be oil scavenging pump cam plate leak, or oil feed line underneath the injector ECU cover.
Edit: i'm guessing thats the overpipe in which case I would suggest looking into the two possibilities I posted above. I'm guessing if you pull the FI ECU cover you'll notice some oil pooling beside the feed line.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
