Old 12-22-2014, 12:42 PM   #771
nickmerronesucks
Ned flanders
nickmerronesucks's Avatar
Drives: 13 BRZ, 16 Hellcat, 22 Ram 2500
what causes the car to be so miata/s2000 like sometimes? I swear my car sometimes violently snaps back and it makes me just want to wreck it and build an s13 again lol
797Performance.com
nickmerronesucks is offline   Reply With Quote
Old 12-22-2014, 01:03 PM   #772
WORKS
WORKS's Avatar
Drives: WORKS CARB Legal Turbo BRZ
We had the pleasure of being the official tire installer for Sonoma Drift's Winter Jam last weekend. Ryan Kado of Team Animal Style stopped by to reload.
WORKS is offline   Reply With Quote
The Following User Says Thank You to WORKS For This Useful Post:
shifter907 (12-23-2014)
Old 12-22-2014, 01:05 PM   #773
johnnytsunami
johnnytsunami's Avatar
Drives: 14 firestorm FRS monogram series
Anyone have rear clunking with their coilovers?
johnnytsunami is offline   Reply With Quote
Old 12-22-2014, 02:51 PM   #774
philstar
philstar's Avatar
Drives: Argento FR-S
i think mixture of stock diff and electronic steering rack. steering rack feels dead to me especially when transferring
philstar is offline   Reply With Quote
Old 12-22-2014, 03:35 PM   #775
slava
slava's Avatar
Drives: brZed
Solid rack bushings help with this. Battleversion sells them, pretty cheap. But also the knuckles made mine way less snappy i think, maybe just how i feel since i spin less from angle. No front sway def helps snappyess too.
slava is offline   Reply With Quote
Old 12-22-2014, 04:10 PM   #776
philstar
philstar's Avatar
Hey Slava, I'll definitely grab solid rack bushings then. In my head, no front sway while still keeping the rear sway would make it more snappy no? but obviously you've tried it and it works. Any explanation on this you think?
off topic: i think we need to make a ZN6 team for FB2
Old 12-22-2014, 04:25 PM   #777
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I refuse to miss it next year. My deployment kept me from going this time. USAIR looks amazing to drive though
Old 12-22-2014, 05:07 PM   #778
slava
slava's Avatar
Drives: brZed
I dunno the car always seems to react slower on any car i've removed it on, dont know if i can explain the geometry. take it off on a drift day and give it a shot. and definite yes on fb2
Old 12-22-2014, 05:30 PM   #779
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
Car snapping back is because car has a lot of mechanical grip. Not tyre grip, mechanical. Run rear toe out, it'llsolve that because it makes the car want to go sideways. With toe out and a 2 way, it'll never snap, it'll feel like the rear is on snow.
I'm a fan of rear toe out on this car with stock power.
Manji is offline   Reply With Quote
Old 12-22-2014, 08:06 PM   #780
nickmerronesucks
Ned flanders
this thread makes me sad. i want to go to the track and practice with the new chassis!
797Performance.com
The Following 2 Users Say Thank You to nickmerronesucks For This Useful Post:
shifter907 (12-23-2014), WORKS (12-29-2014)
Old 12-22-2014, 09:11 PM   #781
philstar
philstar's Avatar
you guys with megan racing / hardrace inner tie rods. How much more angle did you gain? or do you have any photos of the additional angle increase?
Old 12-23-2014, 07:28 AM   #782
Manji
Manji's Avatar
I put up a post on the steeze fb page exactly about this earlier today (about 10 mins before your post!)
Has pictures, including before and after etc.
The Following User Says Thank You to Manji For This Useful Post:
Ryaquinn (12-23-2014)
Old 12-23-2014, 09:52 AM   #783
illmattic
illmattic's Avatar
I would be down for this but I suck at driving still haha.
-Flickr-
IG @illmattic86
illmattic is offline   Reply With Quote
Old 12-23-2014, 11:48 AM   #784
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
Don't worry. Just keep at it and you'll get there. Remember to practice in wide open spaces to keep you and the car in safer areas. Some of the tight space drifting you're seeing on this forum is from people who've been drifting for years.
@philstar - This is actually kind of a cool question because I have a whole guide to the physics of racing that explains it using a miata. The information is designed for track-based grip driving but can be applied to drift and any other type of driving as well. It's written by a man from the UK but google "Physics of Racing" and you'll find it still active on a miata thread at this URL: http://www.miata.net/sport/Physics/ . The basics for it are as follows:
Loose front, stiff rear allows the front to lean or flex the chasis onto your "grip" tires (front) so you can use weight of vehicle to squeeze out some more traction. The stiff rear will keep the car from flexing in the same way on the rear tires and makes the vehicle step out or slide.
Now what is said about toe in or out (In this case tow out) on the rear is also correct. The vehicle is a hair snappy. I find that driving the FT86 with the pedal dance active on the vehicle makes me more comfortable as a driver as well because the slide feels more regulated or predictable. So if you fight it with mechanical grip (Tow / camber / caster adjustments, steering angle, ect) or you fight with tire grip (tire type, traction ratings, compositions, and sway setup, ect.) this is the preference of you the driver. If you got into my car or "Steve's" car, you might not like how it is set up. So try different things and see what works best for you.
As a side note & edit: This may change tarmac to dirt to gravel now that think about it. My co-driver has always set up the tarmac / asphalt runs and I've always done the dirt and gravel. We use dirt and gravel settings on the snow (But rarely see it in my area)
Is there a thread for 'people doing stupid things in their brand new car' thread? Symbiont FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 36 02-18-2013 12:24 PM
BRZ Drifting. Hunter BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-20-2012 08:57 AM
So Cal drifting Thefear13 Scion FR-S / Toyota 86 GT86 General Forum 0 08-10-2012 04:53 PM
REAL drifting thread TylerLieberman Off-Topic Lounge [WARNING: NO POLITICS] 17 02-28-2012 04:20 PM
FT-86 II (RC) Drifting ft86cbx FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 11-11-2011 02:02 AM
