Old 12-21-2014, 09:38 PM   #2787
johnnytsunami
johnnytsunami's Avatar
Drives: 14 firestorm FRS monogram series
Originally Posted by MrMarinakos View Post
Tighten your toe arms, check if any are broken or messed up. You don't have to take the liners out but suggested because chances are you'll rub on them
Everything is on there really tight, also if it helps any im using battle version toe rods and pbm lower control arms
johnnytsunami is offline   Reply With Quote
Old 12-21-2014, 09:39 PM   #2788
MrMarinakos
Drives: Asphalt Monogram Fr-s
Is it everytime you turn or just randomly happens driving?
MrMarinakos is offline   Reply With Quote
Old 12-21-2014, 09:41 PM   #2789
johnnytsunami
Usually when I go over bumps or crappy roads slowly. Also happens when turning slowly too. When I'm on the freeway there are no noises and the car feels great. Hoping maybe it's just the middle but on the coilover that needs to be tightened down.
Old 12-21-2014, 10:04 PM   #2790
MrMarinakos
recheck all nuts for the coilovers on the top in the rear and rear tighten all the nuts connected to the lca's, last thing i'd suggest is trying out stock toe rods to see if it does the same thing. It sounds like the same problem i had and all i did was tighten the toe rod from lca
The Following User Says Thank You to MrMarinakos For This Useful Post:
johnnytsunami (12-21-2014)
Old 12-21-2014, 11:01 PM   #2791
Brndn704
Brndn704's Avatar
Couple questions, those of you here slammed on BC coils are you getting a rear clunking sound? Also I'm assuming yall removed the front fender liners as well? Many thanks in advance for the info.
Like everyone else said, check all the nuts and bolts. As far as liner goes, you could keep it, or take it out. I have mine in still and constantly rub. If you don't mind the sound of rubbing don't bother with it.
Brndn704 is offline   Reply With Quote
The Following User Says Thank You to Brndn704 For This Useful Post:
Old 12-22-2014, 06:13 AM   #2792
Manji
Toyotas don't have boxers
Manji's Avatar
Drives: GTV86, ISF, TE27
The GT86 drift club has just put up a new public fb page to post pics of drifting, drift style, and other rad shit. Some of the setups in this thread certainly fit into that category.
If you don't want a pic contained in this thread, posted on the page, let me know.
If one of us posts your car, YOU GET A STICKER! oo0oo amaze!
https://www.facebook.com/86steeze
Manji is offline   Reply With Quote
Old 12-23-2014, 01:24 PM   #2793
Brndn704
Brndn704's Avatar
Old 12-23-2014, 03:21 PM   #2794
Frishkorn
Hi everybody!
Frishkorn's Avatar
Drives: 14 Whiteout FRS 6M. 16 Abyss iA 6A.
Originally Posted by OmarGC View Post
Nah... It's all about location
St. Louis, nontaxable, 6 figures.
This screams drug trafficking
Frishkorn is offline   Reply With Quote
Old 12-24-2014, 12:14 AM   #2795
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Lolololol
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 12-24-2014, 10:07 AM   #2796
Alq
Drives: 2014 BRZ Limited
Originally Posted by TylerLieberman View Post
Front is currently 18x9.5 +16. Going to 18x9.5 +0 soon.
Exactly the look I want to go for on my future BRZ. So clean. May I ask what coilovers and rims those are with sizes?
Alq is offline   Reply With Quote
Old 12-24-2014, 11:49 AM   #2797
636
636's Avatar
Drives: '23 CWP BRZ
Setting up for my next setup, PBM LCA's and Megan Toe-Arms on. Now just for the adjustments..
PS, that rear bumper tab sucks.
636 is offline   Reply With Quote
The Following User Says Thank You to 636 For This Useful Post:
Jrryjms07 (12-27-2014)
Old 12-24-2014, 04:29 PM   #2798
Brndn704
Brndn704's Avatar
Looking good! You're gonna put the mesh wheels back on, right?
Old 12-24-2014, 09:57 PM   #2799
636
636's Avatar
Drives: '23 CWP BRZ
Of course man! Just can't drive on the mesh far distances because it still rubs really badly right now. Need to add a little bit more camber, or raise it up a little bit..or just roll my damn fenders. I'm afraid the rears will buckle though.
Anyway here's what I did today, roughly -9 degrees in the rear. Haven't touched the fronts yet.
jedichimp (12-27-2014)
Old 12-25-2014, 12:11 AM   #2800
Kotu100
Kotu100's Avatar
Drives: Supra, 2014 BRZ
Looked way better with the old setup IMO.
Kotu100 is offline   Reply With Quote
The Following 7 Users Say Thank You to Kotu100 For This Useful Post:
10Stars (12-26-2014), AznKirby (12-25-2014), ckkone (12-25-2014), Manji (04-15-2015), mmmcambelsoup (12-25-2014), NyC Zn6 (12-25-2014), TylerLieberman (12-25-2014)
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 04:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 02:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 10:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 10:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 02:20 AM
