Old 12-20-2014, 03:35 PM   #1
Antstronaut
So Hot Right Now
Antstronaut's Avatar
Drives: '14 BRZ
Valenti Tail Lights - Running Lights not working at all
Hello,
I just installed my Valenti Smoked Tail Lights and went to test them and everything worked great EXCEPT the LED tube which is supposed to be a running light.
I searched a bit and found it may just be wired for JDM instead of USDM but can't find a DIY on how to rewire it for USDM.
(Plus it says US on the wiring clip so I'm not sure that's the issue.)
I will be contacting the seller on Monday since they are closed over the weekend but wanted to see if anyone else has had similar issues?
Also, I want to follow up with do the OEM tail lights have a running light as well?
I've had numerous people tell me my tail lights are out and when checking with them on, they don't light unless the brake is pressed.
I really hope it's not a bigger issue...
Any advice would be appreciated.
Thanks!
Installed: | Perrin: Resonated 2.5" Catback, Oil Cooler, Radiator Hoses, Inlet Tube, Filter, and Shorty Antenna | Openflash Tablet | Cusco AOS Catch Can | FBM Radiator | RCE Yellows | Whiteline Camber Bolts & Rear Adjustment Bushings | Michelin Pilot SS | Konig Feathers | Valenti Smoked Tails | ProTeckt Skidplates | Diode Dynamics LED Int/Ext
Last edited by Antstronaut; 12-20-2014 at 04:36 PM. Reason: Specify they aren't running at all.
Antstronaut is offline   Reply With Quote
Old 12-20-2014, 04:01 PM   #2
Wes
Wes's Avatar
Drives: JRSC'd Asphalt FR-S
like not running at all? or running when you brake?
if it turns on while signaling, then its wired for jdm specs.
from car harness the
red should go to blue valenti
green should go to red valenti
yellow to yellow valenti
and black is to black
look at the harness for valenti and you need a pick and you just unhook and it should come right off
The Following User Says Thank You to Wes For This Useful Post:
Antstronaut (12-20-2014)
Old 12-20-2014, 04:34 PM   #3
Antstronaut
So Hot Right Now
Drives: '14 BRZ
Sorry didn't realize I didn't specify; it's not running at all.
Turn signals/brakes are working just fine and appropriately.
Thanks for the info, I'll go double check the wiring now.
But I'm starting to suspect it's just a bad set since they don't light with the turn signals either
Old 12-21-2014, 02:15 AM   #4
Poodles
Drives: 2015 Series.Blue
OK, stupid question I know, but are your headlights on when you look? Just don't want to be chasing my tail here (pardon the pun).
If they are on, and the OEM lights don't light up either, then you more than likely have a blown fuse. The issue is, why did the fuse blow?
The Following User Says Thank You to Poodles For This Useful Post:
Antstronaut (12-21-2014)
Old 12-21-2014, 02:54 AM   #5
Antstronaut
So Hot Right Now
Drives: '14 BRZ
Yup, headlights are on.
I do have an intermittent issue with my dome light staying on so I just keep it in the off position a majority of the time but just checked and it's working as expected as well.
(Not sure if this could possibly be another side effect so I'm mentioning it as well.)
Are you saying the OEM tails have a running light?
I can't remember ever seeing them on when I had them in; only when I pressed the brakes did they light.
Hmm suspect for sure...
Thanks for the input!
Old 12-21-2014, 07:49 PM   #6
Poodles
Running lights are required by law...
Old 01-26-2015, 05:19 PM   #7
cto424
just noticed my running lights do not work either...
I bought them a little over a year ago and they have been working fine up until now. has this happened to anyone else?
cto424 is offline   Reply With Quote
Old 06-24-2016, 12:09 AM   #8
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Anyone got a fix for valenti running lights not working?
Decimus is offline   Reply With Quote
Old 09-10-2016, 10:30 PM   #9
636
636's Avatar
Drives: '23 CWP BRZ
bumping this, mine just went out after 2+ years
636 is offline   Reply With Quote
Old 03-27-2017, 04:41 AM   #10
FireRed_Sky
Drives: 2015 Scion FR-S
So no one found a solution for this or....
FireRed_Sky is offline   Reply With Quote
Old 08-05-2017, 12:07 AM   #11
Swarez
Drives: Toyota GTS86
My right side just went out ? Any fixes or just replace it?
Swarez is offline   Reply With Quote
Old 08-06-2017, 03:47 AM   #12
Launcher
Drives: Subaru BRZ Limited 2013
Just installed the valenti tail lights AND third brake light. All installed perfect however the brake and 3 red flash is kind of annoying but it is what it is. Not wasting my time resodering the inside of the third brake light to remove the 3 flash. Looked up and seems to be legal anyway since Mercades have it as OEM.
Launcher is offline   Reply With Quote
Old 08-10-2017, 08:11 AM   #13
636
636's Avatar
Drives: '23 CWP BRZ
Check the fuses under the steering wheel. That was what caused my Valentis to stop working.
Valenti / Lexon / Tom Tail lights, Winjet Headlights, Front Bumper lights and Mirrors Speed Element Exterior Parts - Lighting 224 12-06-2016 03:07 PM
NEW EXCLUSIVE Valenti Tail lights, Winjet Headlights, Front Bumper lights and Mirrors Speed Element Northern California 34 01-14-2015 06:32 PM
Valenti Tail lights Minovsky Cosmetic Modification (Interior/Exterior/Lighting) 30 08-08-2014 11:17 AM
Valenti Tail Lights FRSdrive Exterior Parts (Aero, Lighting, Etc.) 8 04-18-2014 04:21 PM
Valenti Tail Lights bds7692 Cosmetic Modification (Interior/Exterior/Lighting) 3 07-19-2013 04:07 PM
