Old 12-18-2014, 09:47 PM   #9143
k.houan
k.houan's Avatar
Drives: BRZZZ
Originally Posted by agent47 View Post
Installed swift frs spec sport springs
Looks good!
Wheel/tire specs? Also how much of a drop do the swift springs provide when first installed? I know they need time to settle and all, just curious.
k.houan is offline   Reply With Quote
Old 12-18-2014, 11:23 PM   #9144
R3NIK
R3NIK's Avatar
Drives: 2013 FR-S/C
Eibach sway installed tonight
R3NIK is offline   Reply With Quote
Old 12-19-2014, 12:35 AM   #9145
jeffsides
AZ FRS 86
jeffsides's Avatar
Took some photos with my little guyName:  ImageUploadedByTapatalk1418967280.906997.jpg
Size:  247.4 KBName:  ImageUploadedByTapatalk1418967290.105507.jpg
Size:  258.7 KBName:  ImageUploadedByTapatalk1418967299.556396.jpg
Size:  364.0 KBName:  ImageUploadedByTapatalk1418967305.706943.jpg
Size:  309.9 KBName:  ImageUploadedByTapatalk1418967315.375319.jpg
Size:  312.4 KBName:  ImageUploadedByTapatalk1418967323.209588.jpg
Size:  313.4 KBName:  ImageUploadedByTapatalk1418967329.896113.jpg
Sent from ARIZONA86 HQ
@AZFRS86
The Following 15 Users Say Thank You to jeffsides For This Useful Post:
AARON691983 (12-19-2014), CO777DAL (12-21-2014), fatalelement (12-19-2014), G-awesome (12-19-2014), itsbirdy (12-19-2014), Jrryjms07 (12-20-2014), Koa (12-19-2014), Lonewolf (12-19-2014), LucidMomentum (12-20-2014), lukey86 (12-19-2014), mizzta21 (12-20-2014), OrangeGuitar (12-19-2014), R3NIK (12-19-2014), raven1231 (12-19-2014), wtrxprs007 (12-19-2014)
Old 12-19-2014, 01:04 AM   #9146
fatalelement
fatalelement's Avatar
Drives: 2015 FR-S (Halo)
That wrap is nuts! Dunno if I'd rock it but it looks awesome!
Sent from my HTC One_M8 using Tapatalk
fatalelement is offline   Reply With Quote
The Following User Says Thank You to fatalelement For This Useful Post:
Old 12-19-2014, 01:05 AM   #9147
jeffsides
AZ FRS 86
jeffsides's Avatar
It's a dip. Got it done 2 weeks ago. Name:  ImageUploadedByTapatalk1418969119.604170.jpg
@AZFRS86
The Following 2 Users Say Thank You to jeffsides For This Useful Post:
FR-STY 86 (12-19-2014), wtrxprs007 (12-19-2014)
Old 12-19-2014, 04:05 AM   #9148
1GiantTurtle
Space for Rent
1GiantTurtle's Avatar
Drives: 2014 6MT ToyoBaru86ScionMonogram?
Something different
[IMG][/IMG]
ToyoBaruScionGT86hachiRokuBRZMonogram
Instagram: 86turtle
Instagram: 86turtle
1GiantTurtle is offline   Reply With Quote
The Following User Says Thank You to 1GiantTurtle For This Useful Post:
Koa (12-19-2014)
Old 12-19-2014, 10:38 AM   #9149
wtrxprs007
wtrxprs007's Avatar
Drives: 2006 Toyota Prado 4.0V6
@jeffsides, your kid is so cute :3 plus the car is so small, makes him look BIG
Awesome car though. Very awesome
wtrxprs007 is offline   Reply With Quote
The Following User Says Thank You to wtrxprs007 For This Useful Post:
jeffsides (12-19-2014)
Old 12-19-2014, 10:43 AM   #9150
agent47
agent47's Avatar
Drives: 2015 Scion FR-S
Originally Posted by k.houan View Post
Looks good!
17x8 - 45 Enkei RPF1's w/ 225/45/17 michelin pss
Thanks! I forgot to take measurements before I installed them but from the before and after pictures I have it looks to be right around an inch.
Before:
After:
agent47 is offline   Reply With Quote
Old 12-19-2014, 01:37 PM   #9151
t.chk
Drives: Subaru BRZ Limited
Took some photos with my little guyAttachment 98576
"Son this is why you dont get to go to college for free"
t.chk is offline   Reply With Quote
Old 12-19-2014, 05:25 PM   #9152
Caspeed
Caspeed's Avatar
Drives: FRS-RS1, Triumph Speed Triple, Lola
Before:
After:
Are you having any rubbing at all??? full lock, on bumps etc? This is exactly the combo I'm considering.
Caspeed is offline   Reply With Quote
Old 12-19-2014, 07:00 PM   #9153
BBYZILA
BBYZILA's Avatar
Drives: 2013 Firestorm FR-S
roommate's RX-7, and my 2013 firestorm FR-S, above my FRS is my diamondback overdrive 29er, also in red . To the right is my roommate's ducati.
my Honda CBR250R and my FRS, same color! (i love red)
JDM/Euro tips installed, pushed all the way back. (pro tip: when removing the stock tips, spray some PB -blaster and let soak for a hr, then SLOWLY torque the bolts off) I didnt do that, and broke the head on both.
Rear diffuser installed, be patient. (Pro tip: when taking the pushpins out, take the center pin out first, then the rest will come out easily, use a small flathead to get it loose, then pull!)
Another shot of the exhaust and diffuser, looks great!!
Finally, I installed the mudguards, i messed up taking out the pushpins and will be going back to toyota to purchase them...
BBYZILA is offline   Reply With Quote
The Following User Says Thank You to BBYZILA For This Useful Post:
AirborneFRS (12-21-2014)
Old 12-19-2014, 07:11 PM   #9154
agent47
agent47's Avatar
No I haven't had any rubbing but I haven't had an alignment yet. I'm getting that done Monday. I was under the impression I wouldn't have any rubbing as long as I went with less than a 245 wide tire.
The Following User Says Thank You to agent47 For This Useful Post:
Caspeed (12-19-2014)
Old 12-19-2014, 07:13 PM   #9155
agent47
agent47's Avatar
I like that rear diffuser What brand is it and where did you get it?
BBYZILA (12-19-2014)
Old 12-19-2014, 07:31 PM   #9156
BBYZILA
BBYZILA's Avatar
I think its a BasonR brand, not sure theres no branding on the actual defuser, the seller is basonR. here's a link
http://www.ebay.com/itm/371211715236...%3AMEBIDX%3AIT
59.99$ shipped! arrived in 5 days. relatively easy install, would recommend.
Tcoat (12-20-2014)
