Old 12-19-2014, 02:18 PM   #1919
vroom4
sorry, I'm keeping my ballast for my stx build.
vroom4 is offline   Reply With Quote
Old 12-19-2014, 02:21 PM   #1920
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
Originally Posted by vroom4 View Post
I'm selling my full prep CS setup for 1100 in wilmigton nc if anyone is near.
You can probably use the same front bar for the STX build.
raul is offline   Reply With Quote
Old 12-19-2014, 02:28 PM   #1921
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Originally Posted by raul View Post
If you have adjustments available to you such as ride height or tire pressure changes, you don't add weight to solve a problem otherwise solved without adding it.
there are no height changes in stock class. And one could easily take out 100lb from the rear via exhaust, fuel, and spare+tools, and without any ability to adjust for the increased rake and height.
This is all about playing around within strict rule set
and as was pointed out, even if I was to implement some of this, it wouldn't be legal per rules.
Adding the weight in the rear will also increase the pendulum effect the car has while going through a slalom, and while it might have higher sustained cornering grip, it will be, arguably, harder to drive AND slower through a slalom. Your theory of adding weight falls flat because it is not inclusive of situations like slaloms. Predictability is what you want, and there's no reason to add weight to achieve it. If your car is loose, you can even play with toe settings in the rear to make it easier to drive.
Again, rear, does not mean on my bumper. Rear means before the rear axles and as close to the ground as possible. In fact I'd say that I wish the spare tire sat further inboard. I am fully aware of the effects of adding weight aft and above of the rear axle, any sort of weight THERE is without argument detrimental to performance for exactly the reasons you're stating. But I'm not suggesting wrapping a bag of cement to the top of my trunk lid, am I?
as an aside, a few friends on another forum jokes that maybe I should just pour cement into my gas tank
Old 12-19-2014, 02:32 PM   #1922
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
you had my hopes up.
Old 12-19-2014, 02:40 PM   #1923
vroom4
Which one is that? Ive got a collection at this point haha.
Old 12-19-2014, 04:01 PM   #1924
raul
Lap time enthusiast
raul's Avatar
Strano or SuperPro 21mm tubular.
Old 12-19-2014, 04:06 PM   #1925
raul
Lap time enthusiast
raul's Avatar
The closest thing you can do to what you're stating is to put the rear seat back down flat, as it'll shift the weight down some, but still a bit more forward than where you would want it. What you're trying to create, more or less is the effect of a mid-engined car I suppose, but I still think it would be detrimental under most conditions when compared to a car without the weight. Like I said, in a sustained corner that you ease into it'll probably do as you describe and handle better, but in autocross there's too much weight transfer. More weight means that when that weight transfers and you go past the limit of grip, it'll snap a bit harder than the car without the weight, making it more difficult to reel back in. It's more worthwhile, and fun (subjectively), to learn to drive a car to it's potential than to lower the bar because you run out of ability. There's always room for improvement. Get a good coach, not ballast. :P
Old 12-19-2014, 04:18 PM   #1926
AFRichZC6
AFRichZC6's Avatar
I'd say just try it and experiment. You aren't causing harm to any of us by adding ballast in a stock class car... unless you start winning because of it.
In that case we'll protest
AFRichZC6 is offline   Reply With Quote
Old 12-21-2014, 04:16 PM   #1927
bslate3
Drives: 2015 CWP BRZ
Crazy question. Can I debadge the trunk, take off the Subaru and BRZ, and still be CS legal? Or will I get protested for removing half a pound off the trunk?
bslate3 is offline   Reply With Quote
Old 12-21-2014, 05:00 PM   #1928
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
I believe 13.2A allows for removing the badges as "accessories".
14stu is offline   Reply With Quote
Old 12-21-2014, 07:10 PM   #1929
VADERR
Completely Lost
VADERR's Avatar
Drives: 2015 CBS BRZ Limited
I thought it was only allowed in street touring since the rules specifically mention it :-/ 14.2 c
VADERR is offline   Reply With Quote
Old 12-21-2014, 07:19 PM   #1930
14stu
14stu's Avatar
"Appearance and comfort modifications which do not effect performance or handling and do not materially reduce weight are permitted".
That's 13.2A, and I would consider the badges to fall under appearance items (I'm assuming they weigh about a pound, but we could always wait to protest later in the season if the points are close )
Old 12-21-2014, 07:21 PM   #1931
VADERR
Completely Lost
VADERR's Avatar
Haha good point lol go ahead Brandon!!
Old 12-22-2014, 08:56 AM   #1932
Biggins
Drives: Yes
You cannot de-badge or re-badge in CS.
Biggins is offline   Reply With Quote
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
