Old 12-19-2014, 12:59 AM   #2213
fstlane
fstlane's Avatar
Drives: BRZ Limited
Originally Posted by gramicci101 View Post
Firestone on N. Durango in the top left corner of the city. Ask for Alex. He's apparently the guy that does the alignments for the exotic racing experience at LVMS, and he's very comfortable aligning to given specifications instead of OEM spec. Since I got the lifetime alignment package, he said come in before an event, he'll tweak it for that event, then come in afterwards and he'll reset it back to daily driver spec.
Thanks for the recommendation gramicci101! I'm very pleased with the alignment results from these guys.
fstlane is offline   Reply With Quote
Old 12-23-2014, 09:44 PM   #2214
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
@Racecomp Engineering @CSG Mike might have made a boo-boo here so I wanted to ask the experts...any issue I should be worried about after winding my adjusters on my coilovers (ohlins R/T) full soft past the 20 clicks (while off the car)? This is my first set of coils and I was just checking out the adjuster, did not know it could actually go past the 20 clicks recommended by Ohlins until I realized that it was way more than 20...at no point did I try to "force" it, it just kept clicking. Thanks!
edit: so I did some testing today and it seems everything is okay...compressed them by hand at varying adjustments and the movement corresponded well to changes. Call ohlins - all good, bounds of the clicks are the thread ends - not taking the needle out of seat or jamming it into the seat.
1Cor10:23 is offline   Reply With Quote
Old 12-24-2014, 08:23 AM   #2215
bimmer635csi
bimmer635csi's Avatar
Drives: 2013 Cayenne turbo
I did this (but going full tight) on a set of Ohlins for my GTI. Thankfully Ohlins has a 2 year warranty and all it cost me was the shipping to North Carolina to get repaired.
Maybe call the Ohlins facility and talk to them about what might have happened. They were unable to diagnose mine over the phone, so they asked me to send them in and sure enough, they had to rebuild them.
bimmer635csi is offline   Reply With Quote
The Following User Says Thank You to bimmer635csi For This Useful Post:
1Cor10:23 (12-24-2014)
Old 12-24-2014, 10:27 AM   #2216
1Cor10:23
1Cor10:23's Avatar
@bimmer635csi before sending in did it have symptoms of any problems?
Old 12-24-2014, 01:53 PM   #2217
CSG Mike
CSG Mike's Avatar
edit: so I did some testing today and it seems everything is okay...compressed them by hand at varying adjustments and the movement corresponded well to changes. Will give Ohlins a call after the break.
The extra clicks "do nothing"; they're overhead for anything you may have done to the dampers later. As long as you weren't actually using them outside of the range, you should be fine.
Old 12-28-2014, 11:58 AM   #2218
rlpaul
Drives: point A to point C. Screw point B!
@CSG Mike @Racecomp Engineering
First off, still I'm still in research mode, so hopefully my question makes sense.
I know a common complaint is the lack of bump travel in the rear, and for lowered setups, the Raseseng shock tops remedy this. Is there a solution using the shock tops for stock/near stock ride height, therefore adding overall travel in the rear?
If I'm not mistaken, some of the Teins, for example, appear to utilize a similar approach, but as of yet been unable to find confirmation of this.
rlpaul is offline   Reply With Quote
Old 12-28-2014, 01:30 PM   #2219
bimmer635csi
No symptom other than when I was trying to soften the dampers for winter, they wouldn't adjust (the clicks were no longer clicking).
Old 12-28-2014, 03:42 PM   #2220
1Cor10:23
1Cor10:23's Avatar
Did you experience this on all the dampers?
Old 12-28-2014, 05:56 PM   #2221
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
I recently installed Blistein B6's with Swift Sport FR-S Springs. And I have Michelin PSS on the OEM wheels.
My question is what sway bars would you recommend for my setup, if any?
I'm also getting camber bolts and an alignment soon, what specs do you recommend?
I drive about 40 miles each way to work, and this is my daily but I drive it hard as much as possible and go to the occasional track day.
Thanks for any help you can give me, the suspension still mystifies me!
YouShallKnow is offline   Reply With Quote
Old 12-29-2014, 09:08 AM   #2222
bimmer635csi
No, it was only the rears, but only because I had the rears full-stiff (plus a little which is probably what made them break). After repair, I learned not to make that last click with a lot of force and there was no issue afterwards.
Old 12-29-2014, 11:13 AM   #2223
The problem is most coilovers will be at max height around 10mm lower than stock...so if you add a lowering top mount or lowering rear LCAs to the equation than you're definitely going to be lower than stock.
A single ride height adjustable coilover (such as KW, RCE, JRZ, AST, the european stuff) will likely have more bump travel than stock at their taller ride heights, or at least use it more effectively due to the firmer rates the coilovers run.
- Andy
Old 12-29-2014, 11:15 AM   #2224
Drive it with the new shocks and springs first and see what you think after the alignment.
0 toe up front, 1/16th toe in for the rear. Max out your front camber (depends on the bolts you have, but hopefully you'll get around -1.75 degrees).
- Andy
Old 12-30-2014, 03:50 AM   #2225
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Did anybody get details and specs on the new Sachs dampers and spring rates on the MY15's?
Old 12-30-2014, 12:00 PM   #2226
I saw them at PRI, but unfortunately I couldn't find anyone to talk about them.
- Andy
solidONE (12-31-2014)
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 04:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 06:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 09:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 07:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 11:13 AM
