Old 12-18-2014, 05:18 PM   #5755
Jonesy86
Jonesy86's Avatar
Drives: innovate sc frs
Does anyone know if the seibon fa hood fits with the innovate?!
Jonesy86 is offline   Reply With Quote
Old 12-18-2014, 09:45 PM   #5756
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by CK_Bladesmith View Post
Good luck. My innovate kit is currently removed for access to the exact same thing.
Bummer....I was hoping it wouldn't require so much work.
By the way, is it possible to remove elbow without removing the blower unit itself?
Fizz is offline   Reply With Quote
Old 12-18-2014, 09:48 PM   #5757
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
By the way, are you sure the circle in the picture is where the PCV is? I thought it was a little further back, right below the supercharger elbow. Which is why I thought just removing the elbow may be sufficient.
Which brings me to another question: Is it possible to remove elbow without removing the blower unit itself?
100% sure. That little nipple sticking up is the pcv valve. Zoom in on the pic a bit to see it.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 12-18-2014, 09:54 PM   #5758
sickmint79
Drives: bmw
what's all this oil in there from?
sickmint79 is offline   Reply With Quote
Old 12-18-2014, 09:56 PM   #5759
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
LoL yeah I realised that after looking a little closer...
How many miles have you done with the supercharger? Just thinking if I should fit the catch can ASAP, or wait till I've got a little more time later on.
Old 12-18-2014, 10:01 PM   #5760
CK_Bladesmith
Drives: Raven FR-S
PCV blowby. I'm redoing the system with a new pcv valve and a dual radium catch can setup with a check valve in between the catch can outlet and the crankcase inlet on the back of the supercharger ( the middle one ).
Old 12-18-2014, 10:04 PM   #5761
CK_Bladesmith
Drives: Raven FR-S
Only had the system on for 6k miles and my old catch can (ADD W1) didn't catch shit ever. I plan on keeping the car for a long time so engine longevity is a huge must. Hopefully the radium cans will live up to the hype.
Old 12-18-2014, 10:18 PM   #5762
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
So you accumulated all that oil inside the blower even with the old catch can in place? Do you know why it didn't do it's job?
Old 12-18-2014, 10:22 PM   #5763
CK_Bladesmith
Drives: Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
Crappy design I'm guessing. The inlet comes in through the side of the catch can rather than the top so it doesn't really filter anything. The interior baffling design is really bland as well. If you want to see an awesome catch can look up elite engineering e2.....it's what I have on my corvette and its an extremely well built can with excellent baffling.
Old 12-18-2014, 10:45 PM   #5764
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Ok so I need some advice if this method will work?
- Leave the factory PCV fitting in place (too hard to access without removing blower)
- Disconnect hose from middle brass fitting. Extend this hose and plug into top of catch can.
- Insert new hose to vacant middle brass fitting. Plug other end of this hose to bottom of catch can.
Now I've also got some check valves, which line should I fit it to? Both?
Old 12-18-2014, 10:51 PM   #5765
CK_Bladesmith
Drives: Raven FR-S
The check valve will go between the outlet of the catch can and the middle brass fitting on the supercharger. Make sure the arrow is facing towards the supercharger. I haven't been able to do any of this to mine yet as I'm on call at work. I'll post pics as soon as I can though.
The Following 2 Users Say Thank You to CK_Bladesmith For This Useful Post:
Fizz (12-18-2014), whataboutbob (12-21-2014)
Old 12-19-2014, 08:30 AM   #5766
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Why a check valve? The PCV acts like one to keep air from going back into the crank case, and the blower elbow is always under some vacuum.
The Following User Says Thank You to Draco-REX For This Useful Post:
calispec (12-23-2014)
Old 12-19-2014, 09:20 AM   #5767
CK_Bladesmith
Drives: Raven FR-S
Just to be on the safe side. The pcv valve on our cars is pretty weak. I got a brand new one from toyota and I can blow air back through it. It's just an extra precaution to keep the crankcase from potentially being pressurized.
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
Old 12-19-2014, 09:36 AM   #5768
blown
Drives: ft86
anyone got any extra check valves?
blown is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
