#1261 | |
Drives: 2015 Series.Blue BRZ
#1262 |
Drives: WRB JR BRZED
#1263 | |
Even with 93 octane, you will be pushing the bleeding edge of knock threshold. E85 or 100 octane is highly recommended to reduce cylinder pressures and potential for knock. We're not sure, since we never tested the pulley by itself only, only with supporting mods (Tomei header, joint pipe, front pipe). Compared to customer cars with the exact same supporting mods, but without the smaller pulley, there was a 25hp difference. This is with the same tuner, same dyno, and both on stock injectors and pump. However, the smaller pulley WILL NOT be able to redline on 91 octane; you'll need to cut the redline short. The 25hp difference was with 93.25 octane on the CSG car, vs 91 octane on the customer cars. The hp gap increases as fuel quality increases. |
#1264 |
That Guy
Drives: 2013 asphalt FRS MT
If there an intermediate pulley?
#1265 |
#1266 |
#1267 | |
The numbers are from a track tune, not a dyno queen. I'd imagine we can squeeze out quite a bit more if we wanted to see how high we could push the number without blowing up the engine. Tunes were performed with a fully heat soaked engine, not a fully cooled engine with a few minutes in between each pull. This isn't how most people will do it, but this is what we need, and is how we have it done. |
#1268 |
By the way anyone that hasn't checked out crazy sideways Mikes Youtube videos you should!
Mike how are the Tomei products? |
#1269 |
#1270 |
Speed Chaser Thrill Seekr
Drives: 2014 Asphalt Monogram FR-S 6MT
I second that. My setup has been solid.
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint My Build |
#1271 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
link?
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
#1272 |
Our first test with the JRSC back in Dec 2013...
[ame="https://www.youtube.com/watch?v=-r7EgQGxA4g"]Jackson Racing Supercharged BRZ Track Shakedown - YouTube[/ame] Tomei? http://counterspacegarage.com/tomei-...-frs-gt86.html Youtube? This is my (poor) attempt at pretending I'm a drifter. [ame="https://www.youtube.com/watch?v=3FkCXleL8MI"]Subaru BRZ Drift at Streets of Willow Springs - YouTube[/ame] Some chase action [ame="https://www.youtube.com/watch?v=VWcYdp0rqww"]Following Counter Space Garage's Turbo BRZ at Super Lap Battle - YouTube[/ame] Some in-car action with a GT3, GT3 CUP, and a Boss 302 [ame="https://www.youtube.com/watch?v=HCWz5ymLKrI"]Scion FRS vs Porsche GT3 86Fest II - YouTube[/ame] |
#1273 |
So what about the upgraded blower? When our engines blow and we upgrade to something stronger, is there upgradeable parts to use the bigger blower?
#1274 |
| Jackson Racing Rotrex Supercharger System Info and Discussion | Jackson Racing | Forced Induction | 827 | 04-06-2020 04:56 PM |
| Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
| jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
| Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
| Jackson Racing Supercharger Pre-Order Sale, $200 off! | Xero-Limit | Forced Induction | 2 | 03-05-2014 04:14 PM |
