Old 12-14-2014, 01:55 PM   #1
Liquidsnake
Drives: "I drives like a Porsche"
Those with subs in their FRS.
How did you get the third break light above the back seats to stop ratteling.
Did you try deadening it from the trunk or from the back seat?
What did you use?
Thx
Liquidsnake is offline   Reply With Quote
Old 12-14-2014, 02:01 PM   #2
Thorpedo
The SquadWhisperer
Currently running the Infinity Basslink, no rattle yet... *Knocks on wood*.
Try sticking some dynamat under the rear deckÉ For 20$ for a square foot it is worth a try I would say.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion
2017 Bluenose Autosport Club Overall Rallycross Champion
Powered by Great North Performance, Jani-King Canada, and OK Tire.
Thorpedo is offline   Reply With Quote
Old 12-14-2014, 02:03 PM   #3
Koa
Hey Liquid, I got some sheets of Damplifier Pro (sold by Second Skin directly from their website), and followed this DIY to http://www.ft86club.com/forums/showthread.php?t=10002
When you get the rear deck off, lay the Damplifier Pro across the whole thing, tucking it with a roller (trust me, buy the roller. It looks like a mini dough roller. You need it. You'll thank me later!)
and poke holes for all the mounting things. The sides are pretty much symmetrical so just keep one side of the deck uncovered while you do the others, and look at the holes at the un-covered side for reference when poking through. Only thing you need to be aware of is the ground for the electronic locking box on the driver's side. Other than that, symmetrical and EZ PZ.
I have a JL 12" W6V2 powered by a 1000.1 amp in the back... needless to say I found every single rattle. This rear decklid deadening took care of a good three quarters of the rattles. The other sources are the plastic panels to the sides, and the underlighting tray in the trunk. Surprisingly trunk doesn't rattle much.
Good luck, PM me with any Q's
Old 12-14-2014, 02:15 PM   #4
kingnba6
Drives: 2015
Sound deadening is a must with a sub in the trunk. I use B-Quiet and RaamAudio. They are both good quality and cheaper than Dynamat products.
And as stated before, buy the roller! It will make the adhesive and material conform better to the shapes and lines of where you are applying it too.
kingnba6 is offline   Reply With Quote
Old 12-14-2014, 03:33 PM   #5
xITSxTHExPOPEx
xITSxTHExPOPEx's Avatar
Drives: 2013 FRS 6MT
Tada.
http://www.ft86club.com/forums/showthread.php?t=68048
Did this a few months ago, no more rattle, and its a lot easier than pulling the rear deck.
2013 FR-S 6MT
xITSxTHExPOPEx is offline   Reply With Quote
Old 12-14-2014, 03:57 PM   #6
Liquidsnake
You guys are fkn awesome
Old 12-14-2014, 06:17 PM   #7
toast
Drives: 14 BSP Edelbrock BRZ
Mine was rattling because of contact between the housing and the window. I ran a thin line of adhesive felt across the contact points.
toast is offline   Reply With Quote
Old 12-15-2014, 10:19 AM   #8
Rosticles
Drives: 1966 Mustang, 2013 FR-S
http://www.ft86club.com/forums/showthread.php?t=75887
Rosticles is offline   Reply With Quote
Old 12-15-2014, 12:25 PM   #9
Koa
Originally Posted by xITSxTHExPOPEx View Post
Tada.
I tried that actually, and there were still significant rattles. Might be my sub or a one-off, but I had to take apart the whole rear deck to stop the rattles!
Thank you though for being a pioneer. Was the first mod I did to try and quell the horrible noises whenever I turned the gain up
Old 12-15-2014, 04:47 PM   #10
xITSxTHExPOPEx
Well it helps that i only have a 10" JL with a 300W amp lol
2013 FR-S 6MT
Old 12-15-2014, 04:50 PM   #11
Koa
I'm thinking of downgrading to a 250.1 and 10w3.. the cabin is pretty well off & I only run half or less gain most days. I could put the money from the 12w6 and 1000.1 into the suspension also
OP def give Pope's fix a try before taking the rear deck off, it's a looot easier
The Following User Says Thank You to Koa For This Useful Post:
xITSxTHExPOPEx (12-15-2014)
Old 12-16-2014, 10:13 PM   #12
quality_sound
Drives: '15 BRZ Series.Blue
Sound deadening isn't for stopping rattles. It might work but it'll cost you a crap ton more than using the correct item. Go buy some foam. Yes, foam. Put that between the rear deck and the rear deck cover. It'll cost you maybe $10 and will work better than $100 of any deadener. You may also be having an issue with the 3rd brake light actually hitting the back window. If that's the case, adhesive-backed strip foam will fix that.
quality_sound is offline   Reply With Quote
Old 12-16-2014, 10:34 PM   #13
Koa
I respect your apt name and agree foam is great. The rear deck has some items on it that foam may affect the deck's fitment.. if you ever get around to using foam to quiet that deck rattle hope it gets documented and shared around- could save people some moolah.
Sound deadener, when used in strategic places, can work to stop rattles 100%. Don't need to cover the whole thing in your choice of CLD. Just spots where washers, mounted objects (such as the key remote brain), pieces of trim are indeed rattling.
Same goes for license plates and other sensitive trim areas where the bulging foam is not feasible, but you can certainly add a layer of CLD over it
Old 12-17-2014, 08:10 AM   #14
AtlasMick
Drives: FR-S 2013 Asphalt
Tuning will also help a great deal. The stock door speakers work fine down till about 60-70hz so if you cross over your subs at 60hz low pass you eliminate an enormous amount of rattling just from that. (that worked for me, but my subs are connected to a baffle fiberglass'd directly to the sheet metal)
AtlasMick is offline   Reply With Quote
Replace backseats with subs andrew5826 Electronics | Audio | NAV | Infotainment 9 06-25-2013 07:06 PM
2 X 12" Subs, 2 X Amps and NOS Yruyur Off-Topic Lounge [WARNING: NO POLITICS] 3 04-28-2013 11:38 AM
how to add subs to stock stereo fr-s chris's fr-s Electronics | Audio | NAV | Infotainment 10 11-30-2012 08:33 PM
Anyone keeping their siriusXM subs when it runs out? mechaghost Electronics | Audio | NAV | Infotainment 9 06-01-2012 04:38 PM
