Old 12-16-2014, 01:25 PM   #1
Calum
That Guy
Drives: 2013 asphalt FRS MT
Sprintex vs Eaton ??
I'm trying to compare the Eaton R900 to the Sprintex S5-335. Clearly the 335 has a much larger displacement/revolution, but the R900 can spin significantly faster. Unfortunately Sprintex doesn't seem to publish compressor maps. I did find that Sprintex lists a max volumetric flow rate of 740 cfm, but at what pressure ratio and efficient I have no idea. The R900 seems capable of ~618 cfm at a pressure ratio of ~1.8 and 60% efficiency.
Does anyone know anything about the Sprintex specs and how they were measured? I'm guessing that even if Spritex's has conducted their tests under extremely favorable conditions that the 335 will still be capable of more flow and thus more power than the R900. I'm wondering how far behind the R900 will be, and what kind of inlet temperatures could be expected for similar power levels?
Thanks
Sources: http://www.sprintex.com.au/superchargers/ (click S5-335) and http://www.eaton.com/ecm/groups/publ.../ct_127897.gif
Old 12-16-2014, 01:48 PM   #2
bfrank1972
Drives: 2013 FR-S Argento
Thanks
Interesting topic - just poking around ran across this comparison:
http://www.modularfords.com/threads/...omparison-maps
Bigger models, not sprintex, but it is a TVS vs twinscrew comparison, so maybe we can extrapolate from this writeup.
Old 12-16-2014, 02:58 PM   #3
CSG Mike
CSG Mike's Avatar
Thanks
Both blowers offer enough flow that you cannot take advantage of their maximum flow rates without a built engine.
ATL BRZ (12-16-2014), Calum (12-16-2014)
Old 12-16-2014, 03:21 PM   #4
Calum
That Guy
Exactly what I was expecting. Any idea which is more efficient though?
Old 12-16-2014, 03:28 PM   #5
CSG Mike
CSG Mike's Avatar
That depends on your power target. The TVS is more efficient, but the Sprintex has more potential.
If the potential isn't needed, then there's no reason to go that way.
Calum (12-16-2014)
Old 12-16-2014, 03:31 PM   #6
Calum
That Guy
/thread
Thanks Mike.
Old 12-16-2014, 03:44 PM   #7
D K
Stig's dark passenger
60% efficiency?
Isnt Rotrex in the high 70's?
D K is offline   Reply With Quote
Old 12-16-2014, 03:48 PM   #8
CSG Mike
CSG Mike's Avatar
Originally Posted by D K View Post
60% efficiency?
Yes
The TVS hits 70% at its peak/sweet spot (albeit small one), while the Rotrex C38-91/92 hits 75%.
Old 12-16-2014, 03:56 PM   #9
D K
Is there even ANY advantage of a positive displacement compressor?
Old 12-16-2014, 04:38 PM   #10
bfrank1972
Yes, huge advantage. Centrifugal compressors build boost exponentially as a function of compressor speed, that's why you see rotrex, vortech, etc. belt driven superchargers make big torque only at higher engine speeds. A PD unit will make a much broader torque curve - just compare the area under the hp/torque curve for one of the rotrex kits vs. this new 335 unit Moto East is playing with (another thread). Both could be tuned to hit 320 whp on E70, but just look at the torque curve of the 335.
The Following User Says Thank You to bfrank1972 For This Useful Post:
Chad86 (02-14-2015)
Old 12-16-2014, 04:39 PM   #11
Calum
That Guy
Possibly area under the curve and/or more power in the daily driver parts of the rpm band. Either way the decision will be subjective when we finally get some decent PD offerings. (Puts on flame suit)
Old 12-16-2014, 04:41 PM   #12
Calum
That Guy
60% efficiency?
Aren't the rotrex kits already running past their efficiency island?
Edit: looking at the compressor map for the c30-94 and assuming ~90k rpm and 1.8 pressure ratio it looks like they're running at about 55%. Please, if I'm not reading that right, show me why instead of flaming.
Old 12-16-2014, 05:51 PM   #13
CSG Mike
CSG Mike's Avatar
You want to be looking closer to the 1.45-1.65 and between 60-85k. The reasoning behind this, is that the nominal used RPM range for redline pulls, is about 5k-7.4k, which yields boost in the 0.45-0.65 bar range, and impeller speeds between 60k (5k rpm) and 89k (7.4k rpm). You only see 89k rpm at redline, momentarily.
If you draw a line following the pressure and rpm used by the Jackson Racing kit, you'll note that the unit is sized as close to ideal as possible from the superchargers in the Rotrex range for the powerband used during pulls; it crosses directly across that "sweet spot".
The compressor map reads identical to a turbo. Let me know if you need specific explanations or have questions!
The Following 3 Users Say Thank You to CSG Mike For This Useful Post:
Calum (12-16-2014), mad_sb (01-23-2015), whataboutbob (12-16-2014)
Old 12-16-2014, 07:55 PM   #14
Calum
That Guy
Nope, that covers it.
RMS Sprintex Supercharger for sale Ryan86 AFRICA 5 12-16-2014 12:59 PM
The new sprintex 335 supercharger jet86 Forced Induction 39 11-01-2014 11:27 AM
Innovate/sprintex SC rudysaliby Scion FR-S / Toyota 86 GT86 General Forum 3 10-28-2014 03:14 PM
Khorne's - AUDM Red 86 GTS Sprintex Khorne Member's Car Journals 53 08-31-2014 09:44 AM
Innovate/ Sprintex vs vortech GeeTee86 AFRICA 5 03-05-2014 07:26 AM
