Old 11-12-2014, 11:50 PM   #1
Natheria
Overlord
Natheria's Avatar
Drives: SWP 13 BRZ, 94 Miata
Head Unit Randomly shuts off and restarts during drive
So i couldn't find anything on this but it's done it twice on the same drive now. Driving along listening to some tunes when suddenly the music cuts out. Look down and i see the welcome screen flashing as the head unit is restarting and the music starts again.
I'm already taking care of a leaky tail light and minor side window scratches at the dealer so I'm going to mention this to them, although i already know it seems like a strange intermittent wiring short that will probably be difficult to trace but i was wondering if anyone else has had this issue either with the OEM BRZ head unit or any others. I've never heard of this being a common issue.
For additional information:
i have a 13 brz with stock OEM head unit and have a little sansa clip plugged into the usb slot (although i doubt that has to do with the entire unit restarting)
"FR-S or BRZ, it doesn't really matter, they're the same to me. It's a matter of choice, like mass effect, but then the thought of boxer engines make my mass erect!" -The Roman
Natheria is offline   Reply With Quote
Old 11-13-2014, 01:21 AM   #2
extrashaky
Drives: 2014 BRZ Limited
I thought I had seen this here before, and here it is:
http://www.ft86club.com/forums/showthread.php?p=1746260
http://www.ft86club.com/forums/showthread.php?p=1797253
Maybe the solution regarding the USB stick outlined in those threads will fix your issue. If not, you might want to post in the Electronics/Audio/Nav forum.
BTW, whenever you want to search the forum, DON'T use the built-in search on this message board. It sucks and will not give you what you're looking for. Instead, use Google and restrict the search to this site using the "site:ft86club.com" tag. For example, I was able to find the threads above by going to Google and typing this:
site:ft86club.com head unit restarts
and
site:ft86club.com head unit shuts off
Good luck!
The Following User Says Thank You to extrashaky For This Useful Post:
Natheria (11-13-2014)
Old 12-10-2014, 12:33 AM   #3
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
I had this happen twice today. never happened before - i've owned the car since march '13. it's happened before on our outback though. it just shut off and rebooted, going through the set up menu. i checked the fuses and everything looked kosher. i'll see if it does it again, and more often. i'm using the same USB stick for music i've used for over a year, and no issues. no folders on the stick - just files.
shiumai is offline   Reply With Quote
Old 12-16-2014, 04:00 PM   #4
BlueSky
BlueSky's Avatar
Drives: 2015 Aozora BRZ
Happened to me about 3 or 4 times now.
I also use a USB constantly....
BlueSky is offline   Reply With Quote
Old 01-01-2015, 04:20 PM   #5
JayV
JayV's Avatar
Drives: Subaru BRZ
Factory reset radio
Reset your radio and navigation setting to factory. That fixed my issue.
JayV is offline   Reply With Quote
Old 01-07-2015, 11:57 PM   #6
andrew1021
Drives: 2014 WRB BRZ
Used to happen every month or two for me, usually when driving slowly/pulling into driveways...not sure why. I took my HU out and unplugged and replugged everything. No recurrence yet, but it's only been maybe a month and a half.
andrew1021 is offline   Reply With Quote
Old 01-08-2015, 09:29 AM   #7
BlueSky
BlueSky's Avatar
Yes, I installed OEM reference sound system and had to reset to factory settings, haven't happened since, she is away for winter though anyway...
NAV unit shuts off when doing tight turns ReaperX43 Electronics | Audio | NAV | Infotainment 2 09-24-2014 09:32 PM
FS: BRZ OEM Nav Head Unit Griever423 Audio/Visual, Electronics, Infotainment, NAV 2 09-23-2014 03:02 PM
FR-S Head Unit in BRZ? gatsbysghost Electronics | Audio | NAV | Infotainment 0 04-20-2014 08:21 AM
BRZ Nav Head Unit Sojhinn Audio/Visual, Electronics, Infotainment, NAV 16 11-03-2013 06:02 PM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 07:42 PM
