Old 12-15-2014, 01:57 AM   #659
mkivsoopra
Originally Posted by VroomVroom86 View Post
Decided to go with the ptuning kit. Just wondering if anyone can chime in on my current exhaust setup. I have a tomei 80 exhaust. Will this fit the kit or do I need to opt for another exhaust?
The optional adapter seems to neck down to 2.5". Probably not ideal since your Tomei is 80mm. You may need a custom adapter or maybe PTuning can make one for you
mkivsoopra is offline   Reply With Quote
Old 12-15-2014, 03:14 PM   #660
kanundrum
Drives: 2013 Whiteout FR-S
Bump was on some open bi roads and got wheelspin at 100mph in 4th LOL
Old 12-16-2014, 10:21 AM   #661
Blizzz
Haha, Same thing happened to me too. I finally picked the car up yesterday and full throttle even in 5th will bust em out (I'm still on the stock tires). Just kinda chuckled, and did it again, hehe.
Blizzz is offline   Reply With Quote
The Following User Says Thank You to Blizzz For This Useful Post:
kanundrum (12-16-2014)
Old 12-16-2014, 12:51 PM   #662
kanundrum
I was wondering when you were going to get your car! haha
Old 12-17-2014, 09:19 AM   #663
buddy32
Drives: WRB Subaru BRZ Limited
http://www.ft86club.com/forums/showp...3&postcount=34
TL;DR: Bought a kit, installing in Jan cuz i'm travelling for holidays. Can't wait!!
buddy32 is offline   Reply With Quote
The Following 2 Users Say Thank You to buddy32 For This Useful Post:
CSG Mike (12-17-2014), mkivsoopra (12-17-2014)
Old 01-02-2015, 12:44 AM   #664
kanundrum
Any Updates?
Old 01-14-2015, 11:07 PM   #665
Blizzz
Update #1) We love you PTuning.
The Following 6 Users Say Thank You to Blizzz For This Useful Post:
kanundrum (01-16-2015), mkivsoopra (01-15-2015), mnsayer (01-16-2015), Mrc@ptuning (01-15-2015), rb6freak (01-15-2015), sw20kosh (01-15-2015)
Old 01-16-2015, 01:18 AM   #666
mnsayer
mnsayer's Avatar
Drives: LexusGS,Lotus Exige S240,LexusLX570
[ame]http://youtu.be/lbUs5BRH64s[/ame]
mnsayer is offline   Reply With Quote
The Following 4 Users Say Thank You to mnsayer For This Useful Post:
kanundrum (01-16-2015), Mrc@ptuning (01-16-2015), rb6freak (01-16-2015), sw20kosh (01-16-2015)
Old 01-16-2015, 08:55 AM   #667
Yoda
Drives: Crystal Black BRZ(Sophia)
Gawd I want this kit it's so sexy. So so very sexy. I might have to rethink the JRSC.
Yoda is offline   Reply With Quote
The Following User Says Thank You to Yoda For This Useful Post:
Old 01-16-2015, 05:20 PM   #668
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
The PTUNING Windshield Washer Reservoir is done and should be ready to ship out beginning of next week.
- The aluminum reservoir holds 3.5 quarts of fluid--definitely plenty for the DC metro winter. Sized to allow for provision of brake cooling ducts.
- Installation takes less than 30min once the front bumper cover is removed.
- No modification of any kind required.
- The reservoir will reuse the factory reservoir's fill neck, mounting clip, pump & grommet. So dig up those parts you removed during the original turbo system installation and have it ready, if you decide to purchase our reservoir.
Contact your PTUNING sales rep for pricing if you're interested--quantity is limited.
Mrc@ptuning is offline   Reply With Quote
The Following 9 Users Say Thank You to Mrc@ptuning For This Useful Post:
Darryljr11 (01-17-2015), Deadpool_25 (04-27-2015), Draco_PR23 (01-17-2015), kanundrum (01-16-2015), midnight23 (01-19-2015), mkivsoopra (01-16-2015), mnsayer (01-17-2015), rb6freak (01-16-2015), sw20kosh (01-17-2015)
Old 01-16-2015, 07:56 PM   #669
mkivsoopra
Originally Posted by Mrc@ptuning View Post
The PTUNING Windshield Fluid Reservoir is done and should be ready to ship out beginning of next week.
http://i334.photobucket.com/albums/m...psaf69fbe7.jpg
http://i334.photobucket.com/albums/m...ps8704acf2.jpg
Woohoo... almost forgot about this!
The Following 2 Users Say Thank You to mkivsoopra For This Useful Post:
kanundrum (01-16-2015), sw20kosh (01-17-2015)
Old 01-17-2015, 09:32 PM   #670
buddy32
Alrighty, installation question for you folks!!
I've got the RCE T2's installed on the car with Raceseng camber plates. Camber was set at -3 before I started this turbo install. After we re-installed the sway bar included in the kit, we proceeded to install the end links. I turned the hub assembly to get some clearance to make the connections and noticed that it was extremely close on top. When I turned the assembly one way, the top would scrape against the wheel well. When I turned the assembly the other way, the bottom of the coilover would come into contact with the body of the end link.
Will this problem will solve itself when I lower the car back down onto the ground? I'm pretty sure I have the endlinks situated the correct orientation, the top facing the rotors, and the bottom facing the motor. Patrick at the shop advised to reel in the camber a little from -3 degrees and it may solve the problem. I obviously haven't screwed with it and just thought I'd deal with it later. If anyone has any insight, please advise?
Old 01-17-2015, 11:16 PM   #671
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
@buddy32 I can't confirm if it is better or not on the ground, however I did check my car since it is on stands now. I have about an inch clearance from the bottom of the end-link to the arm. My coilovers have about -1 camber and a 1 inch drop. My end links are not set to the shortest setting either. Mine don't touch. Is your car slammed or what?
rb6freak is offline   Reply With Quote
Old 01-18-2015, 09:45 AM   #672
buddy32
@rb6freak, good call. I'm at about 1.5 inch drop if I remember correctly. Mental note made to adjust that to see if it helps.
ptuning, turbo kit
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2639 04-05-2026 10:31 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
