Old 10-11-2010, 04:57 AM   #15
overvolting
Drives: Integra type-r
They've taken shots of the undercarriage and it has macphersons up front. Not a surprise it based off the impreza and no other car I can think of since honda in the early 2000's has had full double wishbones. It will still handle well, but you can't say anything with macpherson on the front handles supreme. Macpherson has no dynamic camber control.
The weight remains to be seen. One of the reasons I keep up on news is because it might be lightweight.
The current boxer is not that old. Subaru just released a new boxer with DI, fancy cooling and other things and it only gets 10% better mileage with the same power output. This is the engine they release 2 weeks ago.
Subaru had one 2L engine that made about 180hp, but it was only released in japan. Hey if they want to develop a one off engine for the ft-86 I'm all for it, but the car is supposed to be cheap too.
If they would just hurry up and release the damn car we could compare it to other cars, but until then it's all speculation.
overvolting is offline   Reply With Quote
Old 10-11-2010, 05:19 AM   #16
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
I`ll be just out here on the bench enjoy this thread.
Old 10-11-2010, 05:49 AM   #17
[es vi: eks]
Drives: Subaru Legacy
Actually I beleave the new Gen FB20 engine is still yet to be fitted with DI. If you look at the Pictures it is still only has MPFI.
So far the FT86 Will only get D4-S
[es vi: eks] is offline   Reply With Quote
Old 10-11-2010, 06:00 AM   #18
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
^ 'Only' D4-S?
D4-S is better than both Direct Injection and Port injection... Because it's a combination of the two.
Snaps is offline   Reply With Quote
Old 10-11-2010, 06:12 AM   #19
[es vi: eks]
I like the Concept of D4-S. Vast improvement over just using DI. Best of both worlds.
The new Subaru block still looks like it uses MPFI.
So if thats the case you can get even better fuel eccommony and power out of the new Gen FB20. So more than the 10% increase that subaru says for there engine.
Old 10-11-2010, 06:25 AM   #20
70NYD
70NYD's Avatar
Drives: RX8 S1
lol itchi join in u make some of the best posts ahhaha
please do show the pic with macpherson up front (remember just cus the spring and shock is in one package doesnt mean its macpherson or chapman strut.. it has to be PHYSICALLY attached to the wheel DIRCTLY in a FIXED manner, with more than ONE bolt to be a macpherson/chapman) so PROOF PLEASE cus thats news to me..
and learn what D4-S is b4 commenting on it..
also this isnt a subaru engine.. its a subaru block with toyota/yamaha heads.. will more than likely have vvtl-i or the new valvetronic controll.
70NYD is offline   Reply With Quote
Old 10-11-2010, 06:56 AM   #21
Snaps
Supra Owner
Snaps's Avatar
^ It's valvematic
But I would guess if Toyota included valvematic and D4-S (confirmed already for D4-S?) then this engine should make over 200hp N/A, but only if Toyota tunes it for performance over economy.
I very much doubt this will be MacPherson strut, I think it will most likely be double wishbone.
Old 10-11-2010, 09:10 AM   #22
Matador
hashiryu
Drives: Mk4 Supra
You people are out of your ever lovin minds.
First off, look at the subaru 2.5L boxer, it puts out 165hp at the crank.
You make cheap cars with off the shelf parts.
Only way it's going to be 200hp is with a turbo.
Second, they've never released the weight, they don't even have a final production version, how on earth you think it's going to be sub 2700lb which is the weight of the old 1990's civics and integras, I do not know. But either way it remains to be seen.
3rd, It doesn't even have front double wishbone, so supreme handling is out of the question. Also, it's not mid-engined so supreme balance is also out of the question.
I hope they release the damn thing soon so you people can come back to reality. Seems like you think this thing is going to set some nurburgring records or something.
How about you get back in your little fwd Honda and roll the fuck on out of here?
The current batch of Subaru boxers aren't built for NA performance. This is why Toyota is redoing the head, with their own technology. Even if they didn't, There is one example, that shows it can be done and It makes 197ps. Check around next time before you come on here and spout rubbish.
With respect to the weight, have you seen how much a Miata weighs? Have you seen the size of this car? Actually, I think this is the one area where Toyota can properly balls this up, so I'm tempering my expectations, but lightweight is a focus of this car, and anything more than 2650-2700lbs in my book will be fail.
Next, I know it has McPhersons up front. I never claimed any different. That statement expressed the desire of another poster, not a claimed fact. Front double wishbones are not a necessity for supreme handling, ask BMW and their entire line of 3 series sedans & coupes, including the M3s.
Lastly, mid engined cars are usually rear weight biased, and while imo that is truly where the engine belongs, is not for inexperienced drivers. Trust me, I've ditched enough MR2s to know this. The boxer will be FMR (mid as in between the axles, but in front of the driver), some of the advantages of a regular MR, but without the disadvantage of being rear weight biased (as most MR cars are, around 42/58 to 45/55), and without the weight of the engine over the rear wheels making for the entertaining phenomenon known as snap oversteer. Hopefully it will have 50/50 or close to it, dynamic weight distribution (as in when the car is moving), or at least 50/50 static distribution to keep people like you who don't know anything happy.
Nobody is expecting this car to set any ring records or anything of the sort. We just want it to be quick, reliable, economical and FUN, with the ability to be modded to ones taste, and if you can't grasp that, you don't get this car nor 90% of the people who are here on this board.
Matador is offline   Reply With Quote
Old 10-11-2010, 10:21 AM   #23
70NYD
70NYD's Avatar
Drives: RX8 S1
valvematic thats right i keep mixing it up with the bmw one haha
matadore, i missed where it was said it will have macphersons up front.. do u have a linky
Old 10-11-2010, 10:55 AM   #24
Midship Runabout
formerly Dixie Normous
Midship Runabout's Avatar
Drives: The ladies wild!
Had this thread awhile ago... All speculation from us, but still good stuff.
http://www.ft86club.com/forums/showt...alk+suspension
Midship Runabout is offline   Reply With Quote
Old 10-11-2010, 11:29 AM   #25
nate89
nate89's Avatar
Drives: MR2
nate89 is offline   Reply With Quote
Old 10-11-2010, 02:50 PM   #26
Matador
hashiryu
Drives: Mk4 Supra
http://www.ft86club.com/forums/showthread.php?t=251
Old 10-11-2010, 03:18 PM   #27
Dark
Elite Padawan
Dark's Avatar
I think New gen boxer doesn't equip with DI yet. How the he** is this guy claiming it is?
I didn't know about suspension tho.
Dark is offline   Reply With Quote
Old 10-11-2010, 06:22 PM   #28
Snaps
Supra Owner
Snaps's Avatar
Originally Posted by MatadorRacing_F1 View Post
That does say struts up front.... But it also says 1000kg...
Just sayin'.
