Old 12-15-2014, 03:30 AM   #1
Achilles
Drives: Grey GTS 86
How much extra power can I draw from the fuseboxes?
Pretty much I'm looking at adding an aftermarket amp that'll probably draw around 15A max. My question is: are there main fuses for the 2 fuseboxes (interior instrument panel fusebox and engine bay fusebox)? If so how big are they and how much headroom have I got to play with if I draw supply from one of the spare slots on either of those 2 fuseboxes? If there isn't enough "spare" amperage I'll have to draw directly from the battery but I'd like to avoid that if possible hence why I'm asking.
Thanks in advance
Achilles is offline   Reply With Quote
Old 12-15-2014, 07:49 AM   #2
Chimera
Drives: FRS
You should not do what you are looking to do, as the house wiring can only handle so much as well, for example if you get a 25A amp you probably want to run 8g wiring. Just my opinion. As far as the box having a master fuse, to my knowledge this does not exist.
Old 12-15-2014, 12:28 PM   #3
Koa
This x 10000000
Do not skimp out on power. Spend the extra $50-100 bucks for a wiring kit and take the hour or so to run those wires.
Old 12-15-2014, 02:43 PM   #4
Achilles
Drives: Grey GTS 86
If the fusebox has no master fuse to protect its own wiring I wouldn't attempt it. Like you say, wouldn't want to push the stock wiring to far. I just thought there may have been some heads to play with given the number of spare fuse slots.
Old 12-15-2014, 11:09 PM   #5
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
Run a legit power line from the battery dude. Its super easy and power wire can be purchased super cheap on eBay.
B-R-Z is offline   Reply With Quote
Old 12-16-2014, 03:47 AM   #6
brianhj
Drives: 2017 Camaro 1SS
This
brianhj is offline   Reply With Quote
Old 12-16-2014, 04:17 AM   #7
Achilles
Drives: Grey GTS 86
Yeah, will do. Getting cable isn't an issue I'm a sparky.
The Following User Says Thank You to Achilles For This Useful Post:
B-R-Z (12-16-2014)
Amp draw sw20kosh Electronics | Audio | NAV | Infotainment 4 08-20-2014 02:54 AM
REALLY, how much extra power is enough? LBC Por Siempre Forced Induction 102 12-27-2013 04:24 PM
Subaru STi - flexible draw stiffener illmatic Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-29-2013 12:04 PM
Draw your BRZ! LeeMaster BRZ Photos, Videos, Wallpapers, Gallery Forum 14 09-26-2013 02:34 PM
Blow through vs draw through MAF mrk1 Forced Induction 9 07-24-2013 08:21 AM
