Old 12-14-2014, 11:19 AM   #1
Flasher
Smartass
Flasher's Avatar
Drives: Toyota GT86 & Impreza STi
TRD Trunk Spoiler fitment issues
Hey guys,
I deleted the big OEM wing and mounted the TRD trunk spoiler yesterday on my European spec GT86. I noticed, that the bottom part of the spoiler, just above the Toyota emblem, is not flush fitting to the trunk. Also I interpreted the Japanese manual to not use the delivered sealing gasket in that area. Is it supposed to be like this?
BTW, that's how the beauty looks now
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker
Flasher is offline   Reply With Quote
Old 12-14-2014, 04:10 PM   #2
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
Is it possible to buy the wing you took off your car?
Plxdjake89 is offline   Reply With Quote
Old 12-14-2014, 04:59 PM   #3
Flasher
Smartass
Flasher's Avatar
Unfortunately I traded the whole trunk with a guy who had the small OEM spoiler (because of the screw holes). So what's left now is the small spoiler.
Old 12-14-2014, 05:09 PM   #4
DIM
Is the trunk you traded for that had a spoiler on it an authentic TRD spoiler? or is it a replica?
DIM is offline   Reply With Quote
Old 12-14-2014, 06:05 PM   #5
Flasher
Smartass
Flasher's Avatar
Ok - I suppose I have to get this straight.
I traded this trunk
for that trunk
and removed the OEM spoiler, because I baught and mounted the genuine TRD ducktail. (Don't mind the colors those are only examples - to lazy to upload actual pics of my car)
Old 12-14-2014, 06:48 PM   #6
jvincent
jvincent's Avatar
Are you sure of the interpretation? I would think you should have the gasket all the way around.
Old 12-14-2014, 07:31 PM   #7
cfordart
cfordart's Avatar
Drives: 2014 FR-S
The rubber gasket doesn't go all the way around, it's supposed to stop exactly as in your photos. In fact, there's a notch around the edge of the spoiler to allow room for the gasket to fit underneath the edge...and that notch stops where the gasket stops.
Don't know why yours doesn't fit flush in the lower middle area. Mine fits fine and it's a genuine TRD piece, your's looks genuine too. Are the bolts tightened enough to pull it against the trunk? That's the only thing I can think of, or perhaps the trunk is slightly warped, but that would show up with an ill fitting center piece where the license lights are located.
Ignore it and enjoy the look of the new spoiler!
cfordart is offline   Reply With Quote
Old 12-15-2014, 04:17 AM   #8
Flasher
Smartass
Flasher's Avatar
This...
The bolts are tightend pretty well and you can see the spoiler sits flush where the bolts are located.
It looks nice and clean, but it bothers me, that there might come moisture and debris in between the trunk and the spoiler.
Old 12-15-2014, 07:07 AM   #9
jvincent
jvincent's Avatar
Good to know. I have been waffling on whether or not to get the TRD spoiler.
Old 12-15-2014, 09:37 AM   #10
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
mine fits perfectly.
Old 12-15-2014, 04:57 PM   #11
Flasher
Smartass
Flasher's Avatar
Does it stick in this area to the trunk? When I push with my finger i can actually bend this area inward a little bit. It doesn't seem like the adhesive tape on the spoiler is touching the trunk.
Old 12-15-2014, 05:21 PM   #12
ATL BRZ
ATL BRZ's Avatar
Yes it sticks
Beatsonic Shark Fin Fitment Issues Visxco Cosmetic Modification (Interior/Exterior/Lighting) 7 06-13-2014 07:36 AM
Trunk trade? Factory spoiler for non-spoiler trunk The Racers Line Northern California 7 01-21-2014 01:09 PM
Fitment Issues Silp3 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 01-02-2013 03:34 PM
Is this what they mean by panel fitment issues? ahquit Issues | Warranty | Recalls / TSB 7 08-21-2012 03:19 PM
JDM clear sidemarker fitment issues D1cker Cosmetic Modification (Interior/Exterior/Lighting) 6 07-27-2012 03:44 PM
