#29 |
i dont think ride quality is much about springs at all but im curious to see how you came up with those numbers.
Drive upgrades. Don't buy them.
#30 | |
Drives: Raven FR-S 6M
“The World is Flat”
[||•]=(86)=[•||] Last edited by Apoc; 12-14-2014 at 02:12 PM. |
#31 |
What you need to have good ride quality:
1. Quality damping 2. Enough suspension travel Spring stiffness plays a role, but it's not as big as most think. Choose spring rates based on how you use the car and what kind of tires you run. I don't think the stock FRS or BRZ rides poorly...it's fine for a sporty car at it's price point. There is room for improvement for sure though. Better shocks help...but the keyword is "better", not just "different." There's a lot of stuff out there that isn't better. Lowering the car with just springs is tricky since you reduce compression travel. Using properly designed shortened bumpstops helps here but most importantly, you just can't go too low. You can go lower with coilovers and keep adequate bump travel, but with coilovers often comes other compromises. If stock BRZ is too rough for you, then you're gonna have a bad time with any lowering. Only thing I would recommend at that point is to try Bilstein B6 dampers. - Andy |
| The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post: | 8R6 (12-16-2014), Captain Snooze (12-14-2014) |
#32 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
When the engineers moved the motor 9 inches further back, they reduced the cars moment of inertia, making it easier for bumps to move the weight balance front to rear, or rear to front. I normally carry about 75 to 100 pounds of computers and parts in my trunk, and I think that adds to the disparity when the front springs are stiffer than the rear springs. So, my solution for a good ride is not going to be the solution for everyone, just for me and my use of the car. It's more like driving around with two wheels in the trunk. In a normal car two wheels in the trunk won't do much beside make the steering a bit lighter. In the BRZ however, it changes the balance enough to force the back end down when the front end comes up, like a see-saw. It's this forward to back rocking sensation that I really hate with a passion of undying fire. That sensation has finally been lifted from me. |
#33 | |
Drives: FRS
#34 |
Drives: JAWS
| The Following 5 Users Say Thank You to JB86'd For This Useful Post: | Koa (12-14-2014), Plxdjake89 (12-14-2014), quality_sound (12-14-2014), Racecomp Engineering (12-14-2014), slicktop (12-16-2014) |
#35 | |
Generally you have a rough idea of the range of spring natural frequencies to shoot for in a car on X tires without downforce for the track (for example). There are all sorts of guidelines on the internet and I recommend taking them as just guidelines. You can also (with some testing) investigate predicted lateral forces and desired roll angle, or run springs as soft as you can without hitting bumpstops, or run springs as soft as you can to keep suspension geometry "good", or some combination of all of the above. You might also have a full run-down on tire data (tire spring rate, internal damping, etc.) but you'd probably be working in F1 or something. ![]() - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | quality_sound (12-14-2014) |
#36 | |
Some facts to ponder
HKS Hypermax GT IV are; Front-59 N/mm Rear-38 N/mm Stock springs are; Front BRZ 27 N/mm, FR-S 23 N/mm Rear BRZ 34 N/mm, FR-S 37 N/mm BRZ front springs are roughly 79% as stiff as the rears, while FRS front springs are roughly 62% as stiff as the rears. I think the ratio is as important as the stiffness is. Using FRS front springs and BRZ rear springs would give me a ratio of roughly 68% front to rear, so I might find that to be a more comfortable setup. In the meantime I will continue to use the scientific method of trial and error to find the best combination for the best ride. |
| The Following 2 Users Say Thank You to KoolBRZ For This Useful Post: | chaoskaze (12-16-2014), Ultramaroon (12-14-2014) |
#37 |
Because compromise ®
Drives: Red Herring
You have ignored motion ratio.
With the number you have given it works out to be approximately Hypermax 48 N/mm / 24 N/mm FR-S 21 N/mm / 24 N/mm BRZ 24 N/mm / 22 N/mm The BRZ is softer in the rear but the FR-S is stiffer in the rear. (Which lends itself to the FR-S being less understeery than the BRZ.)
#38 |
What are those ratios exactly? I'd like to figure this out scientifically. Nevermind, I found out it's 1/1 front and 1/.75 rear.
#39 |
Drives: Red Herring
I have seen numbers for the front ranging from 0.9 to 0.95 and 0.75 to 0.82 for the rear. The ratios change with suspension movement but is usually not considered.
#40 | |
So the effective spring rates are...
Front-59 N/mm Rear-28.5 N/mm KW V3 are; Front-60 N/mm Rear-52.5 N/mm Stock springs are; Front BRZ 27 N/mm, FR-S 23 N/mm Rear BRZ 25.5 N/mm, FR-S 27.75 N/mm So the BRZ ratio front to rear is 1.06/1, the FR-S ratio is .83/1, the HKS ratio is 2.07/1, and the KW V3 ratio is 1.14/1. Mix and match gives us FR-S front with BRZ rear, .90/1, and BRZ front with FR-S rear, .97/1. So, with just stock parts I can try out ratios of .83/1, .90/1, .97/1, and 1.06/1. If I can mix and match KW and HKS, I can get F/R ratios of .63/1, 1.14/1, and 2.46/1. Last edited by KoolBRZ; 12-14-2014 at 05:25 PM. Reason: Added KW V3 info |
#41 |
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Captain Snooze (12-14-2014), quality_sound (12-14-2014) |
#42 |
Drives: '13 BRZ Limited, '95 BMW M3
Why would you mix shocks from different companies. The valving wouldn't be correct and you'd really get a fucked up ride. Quit focusing on the springs as the issue, as others have said is more on the shocks. Did you bother adjusting any on the dampening settings on any of the systems?
| Well this sucks. | Dave-ROR | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 11-16-2014 10:18 PM |
| Getting OLD kinda sucks... | blackhawkdown | Off-Topic Lounge [WARNING: NO POLITICS] | 44 | 06-13-2014 10:41 AM |
| Elitism..sucks | RedLeader | Other Vehicles & General Automotive Discussions | 60 | 01-29-2014 04:09 PM |
| NY sucks | Hardrock4445 | Off-Topic Lounge [WARNING: NO POLITICS] | 35 | 01-18-2013 09:28 AM |
