Old 12-12-2014, 01:02 AM   #5727
8686
8686's Avatar
Drives: 86
Originally Posted by CK_Bladesmith View Post
What did they tell you? I called them today and they told me a little oil consumption was normal but mine has eaten a good bit in only about 1500 miles....
They sent me a new oil seal.
Mine was very clearly leaking. I found oil all over my engine.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
8686 is offline   Reply With Quote
Old 12-12-2014, 01:03 AM   #5728
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
So it was leaking externally or internally? I can smell the supercharger oil in the Laminova charge cooler but there's nothing on the outside.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 12-12-2014, 01:31 AM   #5729
8686
8686's Avatar
Drives: 86
Mine was leaking externally.
I hope it is not leaking internally also.
Old 12-12-2014, 01:57 AM   #5730
whataboutbob
AutoX-10/10ths every run
Still going on the CARB tune done by Delicious. Installed at 34.4K.
Build thread:Here
Old 12-12-2014, 02:34 AM   #5731
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Originally Posted by brianhj View Post
What if I don't care about the top end? I never go faster than 80 or so and I doubt I ever will. Should I go UEL? Would UEL give better mid and lower gains than EL?
Top end is referring to the engine rpm here. An EL will have the advantage at higher rpm regardless of vehicle speed.
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 12-12-2014, 03:14 AM   #5732
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by sales@delicioustuning.com View Post
That is true that the UEL does a better job at removing the torque dip, however, the Innovate kit does that for you. Where the Innovate kit lacks is top end, and that is why the Tomei EL compliments it so nicely. In my personal opinion, if you have an Innovate kit and you're adding a header because you desire more power, it would be silly to get an UEL design as it won't help you at all on the top end; at least not nearly as much as a quality EL design will.
Thanks. I understand that an EL would help at higher revs...but do you think running a UEL will help improve low-mid torque more than the EL?
Or would the low-mid range improvements on the UEL be no better/worse than an EL when you're running a supercharger?
Fizz is offline   Reply With Quote
Old 12-12-2014, 12:08 PM   #5733
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
It sure feels like 300 whp now, wonder how long my clutch will last lol
JesseE is offline   Reply With Quote
Old 12-12-2014, 12:26 PM   #5734
sw20kosh
Drives: 2013 Black FR-S
JDL uel is a top end monster and has even been tested by delicious. Not all uel's are created equal.
The Following User Says Thank You to sw20kosh For This Useful Post:
J.C. (12-16-2014)
Old 12-12-2014, 01:21 PM   #5735
xxscaxx
Drives: 2013 SWP BRZ
When will 8.70 be pushed out to customers @sales@delicioustuning.com?
xxscaxx is offline   Reply With Quote
Old 12-13-2014, 11:26 AM   #5736
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Technically, no UEL's are created equally
And yes, JDL's UEL does do well on the top end, it happens to be one of our favorites. My point, was that the UEL offerings, as we've seen, perform better as a whole in the low to mid range, whereas the EL do better up top. This is not to say they don't help everywhere. We've found that JDL's EL helps on the top end noticeably more than their UEL, and helps less in the low to mid range, which supports my previous statement.
In short, a well designed header will perform well in all areas of the rpm band, but will still have a range that it performs optimally in due to design.
Sincerely,
Zach
Old 12-13-2014, 11:30 AM   #5737
DeliciousTuning
****Edit: We are still verifying on certain setups for 8.70 before releasing to everyone. We have so far verified the tune on 75mm, 80mm, 70mm, and 69mm on 91 octane. We are still verifying that everything functions as intended on E85. It will take a few more weeks until 8.70 is officially pushed out to all current owners with E85 tunes.
As they are requested, with priority being placed just after new orders and custom tunes.
Anyone that would like the update to 8.70 is advised to please send an email to wknose@delicioustuning.com with your delicious user ID and "Innovate 8.70 Update Request" in the subject line. Example, if your delicious user id is xxscaxx, your subject line would read "xxscaxx Innovate 8.70 Update Request".
In the body please include your full name, dongle id, and any pertinent modifications the vehicle has such as intake or header.
Formatting things this way will really help us keep track of these requests and get updates out in a timely manner.
Sincerely,
Zach
The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post:
MINOCIN (12-13-2014), TemeCal (12-13-2014)
Old 12-13-2014, 04:00 PM   #5738
Calum
That Guy
Drives: 2013 asphalt FRS MT
Sincerely,
Zach
Why not just use the old ticket system?
Old 12-13-2014, 09:37 PM   #5739
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Anyone with 72.5mm pulley notice any contact or rub marks under the hood? I've seen 2 cars with standard 75mm pulley which had a small patch of paint eaten away caused by engine movement and pulley touching the hood.
I'm hoping that a 2.5mm reduction in pulley size is enough to gain just enough clearance. I'll also be installing STI engine mounts for safe measure.
Old 12-14-2014, 07:52 PM   #5740
DeliciousTuning
The ticket based system is being phased out and we don't really check it anymore. Update requests are now done through Bill, and Q&A is typically done by me.
Anyone that has any questions about a tune they'd be interested in purchasing, or a tune they have already purchased, is free to pm me on here.
Update on the Flex Fuel Kit: we have a few more testers out and all are performing exactly as they should, so at this time we're waiting on fittings. (I know, before we were waiting on sensors, we got those and now the fittings all got cleared out).
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
whataboutbob (12-14-2014)
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
