#2269 | |
#2270 | |
In case you hadn't seen it. I know you were interested in buying a Cusco LSD, this sounds like a good deal, especially if you wanted to customize settings on it.
2022 BRZ Build 2013 FR-S Build |
#2271 | |
Drives: 2004 Toyota RAV-4 5M
http://forums.nasaaz.com/showpost.ph...7&postcount=12 |
| The Following User Says Thank You to ja1217 For This Useful Post: | Campo (12-11-2014) |
#2272 |
Drives: 2013 Black FR-S
Completely agree. That is the stupidest most illogical thing I have ever heard. DUMB.
| The Following User Says Thank You to sw20kosh For This Useful Post: | Campo (12-11-2014) |
#2273 | |
#2274 | |
Drives: '23 BRZ Limited
You typically want to build a "points" car vs a dyno reclass. The dyno reclass cars typically end up dinged in 1-1.5lb per HP range as far as max power and comp weight vs "points" cars. I hate to be the bearer of bad news, but taking +6 on the auto trans is basically going to render that car uncompetitive in any region with decently prepped cars and drivers. |
| The Following User Says Thank You to OkieSnuffBox For This Useful Post: | Campo (12-11-2014) |
#2275 | |
Drives:
Yup. Since it's not a zero dollar option, I technically paid $1000 for a nonBTM transmission. It's from the factory, but it's not base model trim. I figured I might contest it if I felt it would help, but Dyno reclass may work in my favor in this case. A reduced final drive can easily makeup the difference and make the auto a proper contender for a zero points mod. (But I'll be missing 6 available points to work with) It may be a fool's errand, but I'm gonna stick with it for now. Sent from Tapatalk
"Fuck, you've gone completely sideways, man."
~Raoul Duke Gas is pretty cheap considering you're buying liquid explosive dinosaurs. ![]() |
#2276 |
Drives: AP2
#2277 | |
Drives:
I need to understand the dyno reclassing rules better. Are you saying that one particular car, setup one particular way, could be classed 'D' via points, but may end up in 'C' with a dyno reclass?
#2278 | |
No, imagine this scenario. Because I did a bunch of research on the Miata side and link you to some good threads that may help, but as a quick example. Let's say you could build a "points" BRZ that would be: 175whp - 2750lb comp weight For a dyno-reclass you're either going to end up with more weight at the same power level, or less power at the same weight. It's just the way Greg handles dyno-reclass to keep it from being a major advantage. For example, certain cars/engines/tuners have become very good at hitting the peak power limit with a detuned engine that allows them to have a very, very large "peak" vs what you typically see out of a "normal" curve. When I get home today I'll link you to some good discussion on it. |
#2279 | |
NASA SpecE30 Racer
1. Class 2. Horsepower 3. Weight You will never get a dyno reclass that puts you at the maximum weight/power ratio for a given class though. Generally dyno reclasses are used to get a car with a ton of points classified down a letter, so you would have the points for C but be reclassed into D.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
| The Following User Says Thank You to King Tut For This Useful Post: | Campo (12-11-2014) |
#2280 | ||
Drives:
This is what I would hope to accomplish. I'm eating 6 points immediately for the auto, and it's 'technically' a disadvantage in power. I feel like it would be reasonable to ask for a reclass in order to make it competitive.
#2281 | |
Drives: WRB JR BRZED
Also is it wise to preemptively replace the rear axles or just wait and see if they blow up? |
#2282 | |
The OSG is different, but I wouldn't necessarily class it better or worse. A properly set up differential will do exactly what you want, regardless of brand. The OSG, I believe is more forgiving to less optimal setups, but we prefer to get the best setup we can, not just "good enough". We're still testing one on our car. |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 07:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 09:54 AM |
