go_a_way1
Old 12-11-2014, 01:59 PM   #2269
CSG Mike
CSG Mike's Avatar
Originally Posted by Campo View Post
Unfortunately, I already asked the NASA TT National Director about the paddles, and he said I had to take the +3. He said he had more bad news about the auto: I have to take +3 for non-standard gear ratios...
Makes getting this little sucker competitive a tad challenging - but that's what's so fun!
Yeah, the diffuser is definitely at the bottom of the list. Good thoughts on the Hoosiers though, thanks!
Yeah, and +3 for the gear ratios in the auto...
I'm not totally familiar with the rules around dyno reclassing, but might it be worthwhile to ask after I actually start competing (again, this is like 2016 I'm thinking)? The stock auto dynos around 163 at the wheels as far as I've seen. I'm guessing that with my e85 tune I'm maybe 185-195 at the wheels. I've done zero weight reduction yet and no dyno yet, so I'm not 100% sure where my lb/hp ratio is, but I might benefit from a dyno reclass, no?
This sounds asinine to me. They're going to penalize you for FACTORY paddles with FACTORY gear ratios that are *taller* than the MT?
Old 12-11-2014, 02:09 PM   #2270
DarkSunrise
DarkSunrise's Avatar
We haven't done enough testing with the OSG unit yet to determine if we want to offer a CSG-spec differential yet. Custom configuration on a OSG starts at $150, and goes up, depending on the labor and parts involved.
For the Cusco units, we know exactly how to set it up based on driving style and setup; we have much more experience with these. The Cusco unit also happens to be cheaper as well. Currently, we configure the Cusco unit for free if the requested/recommended changes are within the capability of the LSD without needing to swap parts.
@ja1217
In case you hadn't seen it. I know you were interested in buying a Cusco LSD, this sounds like a good deal, especially if you wanted to customize settings on it.
2022 BRZ Build
2013 FR-S Build
Old 12-11-2014, 02:58 PM   #2271
ja1217
Drives: 2004 Toyota RAV-4 5M
Originally Posted by THEmailman View Post
The manual transmission is considered the base, thus the automatic with the paddle shifters is considered an addition. Its in the exact same way way with the oem spoiler example you mentioned. If it is not the domestic base trim than ot take points. Basically, anything above the most bare bones car in non-btm.
You are correct, I am mistaken. I thought that the transmission wouldn't get dinged since it was a torque converter, but apparently OP already emailed the head TT director and they do indeed incur 6 points. +3 for added paddle shifters and +3 for altered gear ratios.
http://forums.nasaaz.com/showpost.ph...7&postcount=12
ja1217 is offline   Reply With Quote
The Following User Says Thank You to ja1217 For This Useful Post:
Campo (12-11-2014)
Old 12-11-2014, 02:59 PM   #2272
sw20kosh
Drives: 2013 Black FR-S
Completely agree. That is the stupidest most illogical thing I have ever heard. DUMB.
The Following User Says Thank You to sw20kosh For This Useful Post:
Campo (12-11-2014)
Old 12-11-2014, 03:03 PM   #2273
ja1217
Originally Posted by DarkSunrise View Post
@ja1217
Yup, I was already planning on giving @CSG Mike / @CSG David a call and order the LSD from them. Still need to decide which to get (OS Giken vs Cusco) and need to save up a bit more money.
Old 12-11-2014, 03:31 PM   #2274
OkieSnuffBox
Drives: '23 BRZ Limited
You typically want to build a "points" car vs a dyno reclass.
The dyno reclass cars typically end up dinged in 1-1.5lb per HP range as far as max power and comp weight vs "points" cars.
I hate to be the bearer of bad news, but taking +6 on the auto trans is basically going to render that car uncompetitive in any region with decently prepped cars and drivers.
The Following User Says Thank You to OkieSnuffBox For This Useful Post:
Campo (12-11-2014)
Old 12-11-2014, 03:51 PM   #2275
Campo
Campo's Avatar
Drives:
Yup. Since it's not a zero dollar option, I technically paid $1000 for a nonBTM transmission. It's from the factory, but it's not base model trim.
I figured I might contest it if I felt it would help, but Dyno reclass may work in my favor in this case. A reduced final drive can easily makeup the difference and make the auto a proper contender for a zero points mod. (But I'll be missing 6 available points to work with)
It may be a fool's errand, but I'm gonna stick with it for now.
Sent from Tapatalk
"Fuck, you've gone completely sideways, man."
~Raoul Duke
Gas is pretty cheap considering you're buying liquid explosive dinosaurs.
Campo is offline   Reply With Quote
Old 12-11-2014, 03:58 PM   #2276
JZA
Drives: AP2
You'll need camber plates and rear lower control arms.
Try starting at -2.4 all around, with 1/16" total toe-in on both axles.
Great. Thank you, Mike.
JZA is offline   Reply With Quote
Old 12-11-2014, 04:22 PM   #2277
Campo
Campo's Avatar
Drives:
I need to understand the dyno reclassing rules better. Are you saying that one particular car, setup one particular way, could be classed 'D' via points, but may end up in 'C' with a dyno reclass?
~Raoul Duke
Old 12-11-2014, 04:51 PM   #2278
OkieSnuffBox
No, imagine this scenario. Because I did a bunch of research on the Miata side and link you to some good threads that may help, but as a quick example.
Let's say you could build a "points" BRZ that would be:
175whp - 2750lb comp weight
For a dyno-reclass you're either going to end up with more weight at the same power level, or less power at the same weight. It's just the way Greg handles dyno-reclass to keep it from being a major advantage.
For example, certain cars/engines/tuners have become very good at hitting the peak power limit with a detuned engine that allows them to have a very, very large "peak" vs what you typically see out of a "normal" curve.
When I get home today I'll link you to some good discussion on it.
Campo (12-11-2014)
Old 12-11-2014, 04:55 PM   #2279
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
A dyno reclassed car can end up in any class you want. You tell Greg two of the following three, and he will tell you the third:
1. Class
2. Horsepower
3. Weight
You will never get a dyno reclass that puts you at the maximum weight/power ratio for a given class though. Generally dyno reclasses are used to get a car with a ton of points classified down a letter, so you would have the points for C but be reclassed into D.
Campo (12-11-2014)
Old 12-11-2014, 05:13 PM   #2280
Campo
Campo's Avatar
Drives:
Yeah, I've seen cars with dyno charts that make 205 hp from 2k rpm to 6k rpm. I get why Greg would want to put a dyno car in the middle of the class and not right at the top of it. I look forward to those links!
1. Class
2. Horsepower
3. Weight
This is what I would hope to accomplish. I'm eating 6 points immediately for the auto, and it's 'technically' a disadvantage in power. I feel like it would be reasonable to ask for a reclass in order to make it competitive.
~Raoul Duke
Old 12-11-2014, 10:15 PM   #2281
enivid
enivid's Avatar
Drives: WRB JR BRZED
Isn't the OSG unit slightly better?
Also is it wise to preemptively replace the rear axles or just wait and see if they blow up?
enivid is offline   Reply With Quote
Old 12-11-2014, 10:29 PM   #2282
CSG Mike
CSG Mike's Avatar
They'll start to click on load changes before they go completely. You'll know they're starting to fail if you look for the right signs.
The OSG is different, but I wouldn't necessarily class it better or worse. A properly set up differential will do exactly what you want, regardless of brand. The OSG, I believe is more forgiving to less optimal setups, but we prefer to get the best setup we can, not just "good enough". We're still testing one on our car.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 07:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 01:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 08:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 08:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 10:54 AM
