Old 12-10-2014, 11:24 PM   #15
brandonblt2
The Stig's African Cousin
brandonblt2's Avatar
Drives: 2014 wrb brz
I'm a mechanical engineer, you lost me at the word "code". JK, thanks, this is very helpful.
Hold on are you seriously a ME? If so this should be basic physics and dynamics I'm a Civil Engineer and could figure out the benefits.
brandonblt2 is offline   Reply With Quote
Old 12-10-2014, 11:49 PM   #16
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
I'm an Aerospace Engineer (at least, that's my degree) and so I shall settle this debate once and for all:
Microwave.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
brandonblt2 (12-11-2014), SkAsphalt (12-11-2014)
Old 12-11-2014, 12:47 AM   #17
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I guess you didn't read the whole thread. The question is not "why" or "how", I already knew the answer to both. The questions is quantity. How much of a benefit it really is. If you research, some people say it's negligible others say it's a big improvement so what I am looking for is people with experience on the subject. Someone who has actually changed wheels for same sized wheels but noticeably lighter and their personal opinion of performance improvement.
Sent from my SM-N900A using Tapatalk
Old 12-11-2014, 12:49 AM   #18
swarb
rpf1? do it!
It makes everything more efficient. Brakes, Suspension, Acceleration, etc.
18x9.5 is much wheel. go 17x9 for racecar because racecar.
If you are near the limit with your current setup I would say its worth the money. Otherwise I would say spend money on consumables/track time/ stuff you don't have.
There is a reason why almost everyone runs 17's, even 17x8 or 17x8.5. And many run 225/45-17 instead of 245/40-17, car benefits more from acceleration(which it lacks) and nimbleness over outright grip. Tires are also lighter in smaller sizes.
maybe a tenth or two per lap.
Old 12-11-2014, 12:53 AM   #19
Sportsguy83
Drives: Limited BRZ
Originally Posted by swarb View Post
rpf1? do it!
I hate having the same wheels everyone has.... I am looking at TWS T66-F which are even lighter than RPF1s. But, they have two downsides. One more expensive than my current wheels, second, uglier than my current wheels. That's why I'm trying to gauge real actual quantifiable benefit of them.
Old 12-11-2014, 01:45 AM   #20
swarb
rpf1's. DO EEEET. ONE OF US> ONE OF US.
seriously though, .1 up to maybe .2 per lap. +slightly faster with 17's. And tires are much cheaper, meaning you can get a better compound which is more important than the weight imo.
Your car is pretty built. I would suggest a lsd and maybe some aero instead.
The Following User Says Thank You to swarb For This Useful Post:
Sportsguy83 (12-11-2014)
Old 12-11-2014, 08:59 AM   #21
Sportsguy83
Drives: Limited BRZ
I would never go back to 17's
The benefits I'm thinking about are, acceleration, specifically before the turbo spools up. The response from the car on initial WOT, and cutting down spool up time. Once I hit full boost, the wheel weight don't matter much. The transition phase when its spooling up is when I think these lighter wheels could make a big difference acceleration and response performance wise.
Old 12-11-2014, 09:31 AM   #22
OkieSnuffBox
Drives: '23 BRZ Limited
In the real world, it's not that big of a deal.
Grassroots Motorsports did a test on this in a past issue using a Miata (even lighter and more sensitive to wheel weight) and the changes didn't amount to anything more than statistical noise.
In other words, don't worry about it. It's just bench racing.
The Following 4 Users Say Thank You to OkieSnuffBox For This Useful Post:
DAEMANO (12-30-2014), fatoni (12-30-2014), SomeoneWhoIsntMe (12-12-2014), Sportsguy83 (12-11-2014)
Old 12-11-2014, 09:52 AM   #23
jvincent
jvincent's Avatar
I hear ya on this.
Have a look at the PF01. They are much better looking than the RPF1 and according to Enkei site they are also stronger so should handle track abuse better. They are a little more expensive, which means you don't see many around.
Depending on the size you are looking at they are only marginally heavier than the RPF1.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
Campo (12-12-2014), Sportsguy83 (12-11-2014)
Old 12-11-2014, 10:21 AM   #24
bababooey
Drives: BRZ SWP Limited -6MT
Originally Posted by tahdizzle View Post
Why is the sky blue?
How is a rainbow made?
How does a posi-track in a plymoth work?....
It just does. :p
as delivered by dear-teh SR
bababooey is offline   Reply With Quote
Old 12-11-2014, 10:37 AM   #25
echo419
echo419's Avatar
Drives: 2014 BRZ Limited
Originally Posted by Foobar View Post
Probably depends on where the weight is shaved from too. Weight at the edge of the wheel takes more energy to spin than weight towards the hub, right? But then there's that whole conservation of inertia and shit, fuck if I know... I'm out.
cuse Merica' that's why
Old 12-11-2014, 11:32 AM   #26
brandonblt2
Oh, ok I missed that part when reading through I guess
The Following User Says Thank You to brandonblt2 For This Useful Post:
Old 12-11-2014, 02:14 PM   #27
Sportsguy83
Drives: Limited BRZ
There was a good thread going for this already but I just found it today.. ooopps....
http://www.ft86club.com/forums/showthread.php?t=32858
Old 12-12-2014, 11:27 AM   #28
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
If I remember correctly its also harder to slow down the weight at the end then at the center. Hmmm ...
C130NAV is offline   Reply With Quote
Should I dyno tests after installing lighter wheels? makesdrivingfunagain Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-10-2014 04:17 PM
Five Axis S5:F wheels "GUN METAL" on a lighter color FR-S or BRZ? OICU812 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 03-30-2013 10:38 PM
Increased whp by having lighter wheels mechaghost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 07-03-2012 12:46 AM
What return from going with lighter wheels? bazguitarman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 06-01-2012 09:35 AM
Is it wise to buy an all-new model car when it first comes out? Raiden Scion FR-S / Toyota 86 GT86 General Forum 39 01-29-2011 10:57 AM
