Old 12-10-2014, 07:24 PM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
How much benefit are lighter wheels rotational mass wise
Pretty simple. I have gramm"LIGHT" wheels that weight about 22 lbs each.
I want to know how much benefit is it really to go to a 16 lbs or so wheel (so a benefit of about 12-13 lbs of rotational mass in the rear wheels).
Don't care about the benefit of overall weight reduction. I'm only asking about rotational mass savings allowing the engine to spin faster. Like a lighter Flywheel, LWCP, etc...
Experts on the subject... GO!
Edit: Good discussion on the subject can be found here
http://www.ft86club.com/forums/showthread.php?t=32858
Sent from my SM-N900A using Tapatalk
The Following User Says Thank You to Sportsguy83 For This Useful Post:
sato (12-11-2014)
Old 12-10-2014, 07:39 PM   #2
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Why is the sky blue?
How is a rainbow made?
How does a posi-track in a plymoth work?....
It just does. :p
-Jack Burton
The Following User Says Thank You to tahdizzle For This Useful Post:
troek (12-11-2014)
Old 12-10-2014, 07:49 PM   #3
Foobar
SLO NO MO
Foobar's Avatar
Probably depends on where the weight is shaved from too. Weight at the edge of the wheel takes more energy to spin than weight towards the hub, right? But then there's that whole conservation of inertia and shit, fuck if I know... I'm out.
Old 12-10-2014, 07:54 PM   #4
CatDaddysBBQ
Drives: '13 FR-S
I compare it to running in a pair of boots, then swapping boots for a running shoe. There is no comparison.
Everything is easier - starting, stopping, turning, reacting and feel are all better with lighter wheels.
Now, a set that's 1lb lighter per corner? You may notice it... But if you drop 5-6 lbs per corner? It's outstanding.
CatDaddysBBQ is offline   Reply With Quote
The Following 2 Users Say Thank You to CatDaddysBBQ For This Useful Post:
Blizzard (12-11-2014), GT86_PRAGUE (12-30-2014)
Old 12-10-2014, 08:08 PM   #5
8R6
8R6's Avatar
Drives: FRS
dont forget to take in account of tire weight too. a wider wheel of the same weight as the skinny stock wheel might be considered "light" for its size, but the added tire mass and weight will add it back... and at the outer edge of the rotation at that.
now if you compare a X-lb 17x7 wheel vs Y-lb 17x7 wheel, with Y-lb being lighter, then you can see and experience the direct difference weight makes from a lighter wheel alone.
8R6 is offline   Reply With Quote
Old 12-10-2014, 08:17 PM   #6
chas3wba0
chas3wba0's Avatar
Drives: Yes
Inertia = resistance to change in direction and/or velocity
Heavier wheels will be harder to get spinning, harder to turn for cornering, and harder to stop under braking. Vice versa for lighter wheels. Car will just feel more "nimble"
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
The Following User Says Thank You to chas3wba0 For This Useful Post:
kiichiro (12-10-2014)
Old 12-10-2014, 08:27 PM   #7
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Huge
It pays to go light
I'm on 235 40 17 track day in r spec and its a dream on light rims
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
The Following User Says Thank You to kiichiro For This Useful Post:
Sportsguy83 (12-10-2014)
Old 12-10-2014, 08:54 PM   #8
Hoosier Daddy
Drives: '13 Denali, '15 Volt, soon a BRZ?
A typical 18x10 wheel and tire weighing 40 lb has an equivalent mass of about ~55 lb. A wheel and tire weighing 30 lb has an equivalent mass of about 41 lb. 14 lb x 4 wheels = almost 3/4 of a tank of fuel.
Here is some code:
function calculatewheel(){
var umass = document.wheel.mass.value;
var massunit = document.wheel.massunit.value;
// mass in kg
var mass = umass * massunit;
var diameter = document.wheel.diameter.value;
var diameterm = diameter * 0.0254;
// ratio = rim mass percentage of total mass
var ratio = document.wheel.ratio.value/100
var rimmass = mass * ratio;
var spokemass = mass * (1 - ratio)
var rimri = ri_pointmass(rimmass,diameterm/2);
var spokeri = ri_rod(spokemass,diameterm/2);
var totali = rimri + spokeri;
document.wheel.inertia.value = totali.toPrecision(5);
document.wheel.rimri.value = rimri.toPrecision(5);
document.wheel.spokeri.value = spokeri.toPrecision(5);
var emass = e_mass(mass,totali,1,document.wheel.rollingradius. value);
var emassratio = emass/mass;
document.wheel.emass.value = emass.toPrecision(5);
document.wheel.emassratio.value = emassratio.toPrecision(3);
function ri_pointmass(mass,r){
ri = mass*r*r;
return ri;
function ri_rod(mass,r){
ri = mass*r*r/3;
return ri;
function e_mass(m,i,gr,rt){
// computes equivalent mass given
// m - static mass
// i - rotational inertia
// gr - gear ratio. gr = 3 means the component in question rotates 3 X as fast as
// the drive wheels
// rt - rolling RADIUS of the drivewheels
var n = gr / rt;
emass = m + i * n * n;
return emass;
Hoosier Daddy is offline   Reply With Quote
The Following 5 Users Say Thank You to Hoosier Daddy For This Useful Post:
abraxis (12-12-2014), continuecrushing (12-11-2014), DAEMANO (12-30-2014), Joe-G (01-08-2015), sato (12-11-2014)
Old 12-10-2014, 09:07 PM   #9
Sportsguy83
Drives: Limited BRZ
It just does. :p
I know it works, that is not the question. My question was how much of a difference does it make. Maybe I didn't ask the question properly, I meant does it feel marginal like replacing LWCP, or does it feel way more than that, and thus worth around $1K.
It would be basically same for same change, only difference would be lighter weight. Same tires, same 18X9.5 wheel size.
Don't know if you know my tag, but either way this was brilliant.
Originally Posted by kiichiro View Post
Huge
It pays to go light
I mean, how much? I want someone who can quantify a difference having run heavier wheels before. (You probably did, hence why I ask). Would it be worth $1K, considering the improvement.
Old 12-10-2014, 09:08 PM   #10
Sportsguy83
Drives: Limited BRZ
Here is some code:
// mass in kg
ri = mass*r*r;
return ri;
ri = mass*r*r/3;
return ri;
// m - static mass
// the drive wheels
var n = gr / rt;
return emass;
I'm a mechanical engineer, you lost me at the word "code". JK, thanks, this is very helpful.
Old 12-10-2014, 09:11 PM   #11
vroom4
On a 60 second autocross course a few tests show the difference is in the noise....as an engineer this pisses me off so I still bought lightest wheels I could
vroom4 is offline   Reply With Quote
The Following 2 Users Say Thank You to vroom4 For This Useful Post:
kiichiro (12-17-2014), Sportsguy83 (12-10-2014)
Old 12-10-2014, 09:28 PM   #12
Hoosier Daddy
You're an ME and can't answer your own question? Anyway, the above shows the formulas (code) needed to figure it out.
EDIT! Missed the J/K part... oops sry
The Following User Says Thank You to Hoosier Daddy For This Useful Post:
Old 12-10-2014, 09:35 PM   #13
kask2_6.0
kask2_6.0's Avatar
Drives: 13 BRZ
The benefit is HUGE. There is some benefit in terms of acceleration and braking but that pales in comparison to the improvement in chassis dynamics. Unsprung weight is the enemy when in comes to suspension performance. Regardless the weight of your wheel/tire the road is going to "throw" it upwards when you hit a bump. Every time that happens the dampers and chassis have to stop it. Think of catching a 20 lb medicine ball vs catching a nerf ball. Which is harder to stop? How is your balance affected with the medicine ball? The same can be said for the car stopping a heavy vs light wheel.
kask2_6.0 is offline   Reply With Quote
The Following 4 Users Say Thank You to kask2_6.0 For This Useful Post:
2much (12-10-2014), Blizzard (12-11-2014), GT86_PRAGUE (12-12-2014), Sportsguy83 (12-10-2014)
Old 12-10-2014, 10:59 PM   #14
2much
I wanna go fast
Drives: 2013 FR-S 6MT
well put
2much is offline   Reply With Quote
Should I dyno tests after installing lighter wheels? makesdrivingfunagain Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 06-10-2014 04:17 PM
Five Axis S5:F wheels "GUN METAL" on a lighter color FR-S or BRZ? OICU812 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 03-30-2013 10:38 PM
Increased whp by having lighter wheels mechaghost Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 26 07-03-2012 12:46 AM
What return from going with lighter wheels? bazguitarman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 06-01-2012 09:35 AM
Is it wise to buy an all-new model car when it first comes out? Raiden Scion FR-S / Toyota 86 GT86 General Forum 39 01-29-2011 10:57 AM
