Old 05-09-2012, 02:05 AM   #2647
Giccin
Giccin's Avatar
Depends how much money you spend.
I got to be a 'shitty' teacher today. Korean ESL student was ecstatic to learn how to use 'bullshit' properly in English.
Hmm.. Lets say enough to replace/resurface the entire thing.
And I didn't know you were a teacher. I had always thought you were a master metal person slash wielder.
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Giccin is offline
Old 05-09-2012, 02:28 AM   #2648
Dimman
Kuruma Otaku
Dimman's Avatar
Non-apathetic machinist. Master of nothing.
A couple nights a week I 'teach' basic conversational English and West-Coast Canadian 'culture' (with a subversive Northern twist) to mostly Japanese and the occasional Korean student in exchange for Japanese lessons.
Edit: engine question...
Um, usually once is no problem if it hasn't been badly over heated. The more metal that gets removed to correct problems the weaker it gets. (This is from domestic experience, and older imports like 22Rs. I think some new motors don't like overbores because of fancy cylinder liner stuff...)
Because titanium.
Dimman is offline
Old 05-09-2012, 03:30 AM   #2649
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Just noticed @Guff's name became red...
ichitaka05 is offline
Old 05-09-2012, 03:50 AM   #2650
Giccin
Giccin's Avatar
I did too.
Whatever happened to Matador anyways? He kinda poof'd.
I am the Ice Queen.
Logic > Emotion
┬──┬◡ノ(° -°ノ)
TOYOTA FT-86
Giccin is offline
Old 05-09-2012, 04:02 AM   #2651
ichitaka05
Site Moderator
ichitaka05's Avatar
I did too.
He's still around, just don't post as much
Old 05-09-2012, 08:12 AM   #2652
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
The heat-treatment issue is a theoretical vs practical problem. Car chassis are big and have lots of stuff attached (and in the Lotus case, high-tech glued) to them.
Ahh, I see...
When someone does a engine overhaul. What really happens? Does it give the engine it's life back like a new engine?
Engine Overhauling probably involves changing worn parts and replacing fluids. It depends on the extent of what they are going to do. Some crooked mechanics might replace one or two parts and say it was a full engine overhaul. It's just a matter of you knowing what they're doing.
- The Ancient BRZ Sacrament
by Zaku
Guff is offline
Old 05-09-2012, 09:24 AM   #2653
Dimman
Kuruma Otaku
Dimman's Avatar
I did too.
Hates all the noobs.
Because titanium.
Dimman is offline
Old 05-09-2012, 02:04 PM   #2654
Want.FR-S
Want.FR-S's Avatar
Drives: 4 Wheels Auto
Definition from Wiki:
Overhaul
An overhauled engine is an engine which has been removed, disassembled (tear down), cleaned, inspected, repaired as necessary and tested using factory service manual approved procedures. The procedure generally involves honing, new piston rings, bearings, gaskets, oil seals. When done by a competent engine builder the engine will perform as new. The engine may be overhauled to 'new limits' or 'service limits', or a combination of the two using used parts, new original equipment manufacturer (OEM) parts, or new aftermarket parts. The engine's previous operating history is maintained and it is returned with zero hours since major overhaul....
Link: http://en.wikipedia.org/wiki/Engine_tuning#Overhaul
However, as @Guff said, some crooked mechanic may charge you for a full overhaul but only do some little things.
Hope that helps.
Originally Posted by Winding Road FR-S review
What is astonishing about the FR-S is that it combines the cruising comportment and function of the 128i with the dynamics of the Cayman, or Boxster, or S2000.
Want.FR-S is offline
Old 05-09-2012, 03:17 PM   #2655
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
Originally Posted by Snoopyalien24 View Post
Hmm whats the smart thing to do....?
Save up like 7k and buy an amazing 240sx with an SR or a RB pullin 300hp+ or us that 7k for a BRZ down in about 2 years, after I graduate college?
This will also be my first real car...
Can anyone help me with this q?
Snoopyalien24 is offline
Old 05-09-2012, 03:56 PM   #2656
ichitaka05
Site Moderator
ichitaka05's Avatar
Can't answer this, but can give my 2cents.
Save it up to buy BRZ. Why? You're in college, RB or SR 240sx is cool, but will cost you for a maintenance
Old 05-09-2012, 04:02 PM   #2657
SVTSHC
(ノಥ益ಥ)ノ
SVTSHC's Avatar
Drives: 2015 Series Blue BRZ
That's up to you bro. A car is a large expense either way you slice it; you have a choice between making that a predictable/manageable expense or dealing with multiple miscellaneous expenses. Now you've also got to ask yourself if miscellaneous expenses are something you can handle given your currect financial situation as a college kid.
When I was in college that was killer, and having a project car was expensive. Often when something would break my car would sit for weeks before I could get the funds to take care of it. My advice would be to wait until you're done and get the BRZ; financing will help build your credit and warranty will help minimize miscellaneous vehicle related expenses.
"Sweet Subaru, sweet Subaru, send your BRZ unto me, for the roads of the unworthy must be baptized in speed and glory." ~Zaku
SVTSHC is offline
Old 05-09-2012, 07:06 PM   #2658
ichitaka05
Site Moderator
ichitaka05's Avatar
Had a lunch w a good friend of mine. When she came, she had colored & cut her hair, it reminded me one of my ex, that it really was freaky
Guff (05-09-2012)
Old 05-09-2012, 10:49 PM   #2659
M-17
Ninja Cat Mod
M-17's Avatar
So not only is Guff a mod, so it Dave-ROR.
M-17 is offline
Old 05-09-2012, 11:49 PM   #2660
Want.FR-S
Want.FR-S's Avatar
More d the merrier?
