Old 12-10-2014, 10:13 AM   #1
gtzany
Drives: 2015 frs release sereis
creaking noise front end of suspension
Hey guys so I have the release series and it's been about a month now but recently my front end is making this creaking noise ...if I open the door nd sit nd get back up u hear it nd if I'm turning like into my drive way nd one of the wheels is on the sidewalk while the other is still on the road u hear it...but if I drive over a speed bump there's no noise ....It only makes the noise when one side is higher/lower than the other .....could it be the lowering springs aren't sitting properly
gtzany is offline   Reply With Quote
Old 12-10-2014, 11:44 AM   #2
If you changed the springs ...... that would be the first place I'd look.
Maybe the people who put on the springs should check it out ..... ??
Tcoat (12-10-2014)
Old 12-10-2014, 11:54 AM   #3
Koa
The release series comes with TRD lowering springs, so I'm banking on something is messed up (could still be the springs, but the problem description isn't very good).
OP take it to the stealership
The Following User Says Thank You to Koa For This Useful Post:
humfrz (12-10-2014)
Old 12-10-2014, 12:32 PM   #4
This guy has the same sounds I bet!
I will say this for about the 500th time. Noises can not be diagnosed in a written format with even remote accuracy. It could be something minor and no big deal or it could be something that could kill you (or somebody else) in the next 5 minutes. Take it to somebody that can hear and see it to be checked!!!!
humfrz (12-10-2014)
Old 12-10-2014, 02:28 PM   #5
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
How much do you weigh OP? You're probably getting in the car wrong.
Old 12-10-2014, 02:36 PM   #6
nocturne1
nocturne1's Avatar
Drives: 2013 BRZ Limited WRB
I had this problem. The dealer ended up being loose bolts holding some sort of under-engine cover at the front of the car. Sorry I can't be any more specific - I wasn't given any more detail.
nocturne1 is offline   Reply With Quote
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 01:50 PM
Squeaking / Creaking rear suspension with low ride height? Suspension pros welcome! mothespaceman Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 08-14-2015 06:06 PM
Unknown Front End Suspension noise RedFRS4me Issues | Warranty | Recalls / TSB 5 03-04-2014 05:57 AM
Creaking/Clinking Noise from Driver Side Touge86 Issues | Warranty | Recalls / TSB 17 08-17-2013 09:20 PM
