Old 12-09-2014, 10:55 AM   #2213
Sleepless
Drives: 2016 FR-S
I've seen no evidence of our cars being delicate. I've had many other cars (including some BMWs) that I've beat on at the track and the BRZ is performing for me just as well as the others. I've had mine since late Feb and have done 14 track days (advanced/race group HPDEs) and 13K miles with no issues other than clearly needing an oil cooler which I added early on. If you run hard on R-comps, you'll want better front brakes.
Edit: Love this car
Sleepless is offline   Reply With Quote
Old 12-09-2014, 11:16 AM   #2214
DarkSunrise
DarkSunrise's Avatar
I think if bone stock, all you need to track reliably is an oil cooler and brake pads/fluid.
I've done about a dozen track days on mine (intermediate/solo HPDE), plus a handful of autocrosses and ~15k street miles. No mechanical issues.
2022 BRZ Build
2013 FR-S Build
Old 12-09-2014, 11:20 AM   #2215
kster1
kster1's Avatar
Edit: Love this car
Same here. I have at least 15+ events on my BRZ and no issues. FYI, I added an oil cooler and got an Ecutek tune right after I got the car.
kster1 is offline   Reply With Quote
Old 12-09-2014, 11:31 AM   #2216
sw20kosh
Drives: 2013 Black FR-S
Originally Posted by OkieSnuffBox View Post
Are these cars really as delicate as I'm being lead to believe when used for Auto-X/HPDE work?
Been doing HPDE's for the whole car's life. Am at 56k miles and more than half of that has been boosted miles.
So far things that have broken/worn out:
Coilpack #1 (the one right above the hot over pipe)
Front Wheel studs (replaced with longer/harder ones)
Rear Axle bearing (replaced axles with DriveShaftShop axles)
Middle brake light LED circuit board.
Been lucky so far with the motor and crossing my fingers it stays together for a long time. I personally know 2 people who have blown bone stock motors at the track. But I also personally know 4 people who are boosted and are doing fine at the track beating on their cars.
Old 12-09-2014, 11:34 AM   #2217
OkieSnuffBox
Drives: '23 BRZ Limited
This is good to know gents, thanks.
The car is stock except for the OFT Stg 1 91 oct tune.
Plans include oil cooler/ducting as mentioned, as well as a full exhaust/intake/suspension/pads.
Is a baffle or aftermarket oil pan worth the effort if using a quality oil and an oil cooler?
Old 12-09-2014, 03:02 PM   #2218
Lebby83
Drives: 2019 BRZ, 2016 Touareg
Will I noticed a nice difference around tracks with different/better sway bars? Car is a 2013 BRZ that is stock except for upgraded rotors/pads.
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
Old 12-09-2014, 03:42 PM   #2219
CSG Mike
CSG Mike's Avatar
Only a change in balance.
Don't listen to any vendor that tells you getting front and rear sways will make a huge difference. They do make a difference, but nothing close to what a good set of dampers can do.
Old 12-09-2014, 03:45 PM   #2220
CSG Mike
CSG Mike's Avatar
I don't believe anyone who tracks regularly locally uses an aftermarket oil pan, but good oil is pretty much universal.
I don't recommend the OFT tune, unless you have an early make that doesn't have the DI seal fix.
Bolt-ons basically do nothing; quite the opposite of the Miata.
I'd recommend you do an oil cooler and brake pads/fluid first, then camber mods, and then BBK. We can help you with all that.
Old 12-09-2014, 04:33 PM   #2221
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I'm curious why you don't recommend the OFT tune, Mike. Have you seen issues with it on track?
Old 12-09-2014, 04:35 PM   #2222
CSG Mike
CSG Mike's Avatar
It's just not a complete tuning solution.
Would you drive on track missing 2 of your 3 mirrors? Tuning with OFT is like tuning without everything you need.
That and I've seen a lot of people get *slower* after they get an OFT.
Old 12-09-2014, 04:38 PM   #2223
OkieSnuffBox
Ok. Yeah, mine is a 2015 just picked it up in October.
Is something like a Carbotech XP12 f/r with not going to stand up to R-comps on a mostly stock car? I know there is much better feel and modulation with a BBK (my Miata has Wilwoods at all 4 corners), but $2200 buys a lot of seat time.
Also, since you're familiar with Emilio, what's the closest BRZ equivalent to his XIDA's for the Miata? I ran the XIDA's on my car at the track and they were phenomenal.
Old 12-09-2014, 05:18 PM   #2224
DarkSunrise
I'll have to say, my OFT experience has been pretty good in my completely unscientific and non-controlled testing lol. As a data point from my last track event at Summit Main:
- A guy I know with just an ECUTek tune exited T10 at 86 mph and hit 120 mph by brake marker 3.
- I'm OFT stage 2 and I exited T10 at 82 mph and hit 121 mph by brake marker 4.
He's a better driver and was on hoosiers, and I was on sumitomos, so our exit speeds are quite different, but the interesting part is the delta. He gained 34 mph on the front straight, whereas I gained 39 mph in a slightly shorter distance.
This isn't a completely controlled test, but it looks like OFT (and stage 2 exhaust mods) made a nice difference, about 5 mph over a ~2500 ft distance. He dyno'd around 185 whp on a dynojet on 93 octane. I'm going to re-dyno in a few weeks (but made 177 whp on the same dyno with stock tune + just CBE).
That said, you know your stuff Mike so I don't doubt you for a second either. One thing I suspect is that OFT base maps are somewhat aggressive and if you don't have access to good fuel, it will knock and pull timing (i.e., lose power).
2022 BRZ Build
2013 FR-S Build
Old 12-09-2014, 08:42 PM   #2225
celica73
OFT + OFH got me 3 mph at the end of the front straight at VIR (122-123 vs 119-120). In 90+ degree humid summer VA weather.
I suppose others might get different results. At least I did it with tires that were a year more worn and heat cycled.
Old 12-09-2014, 09:57 PM   #2226
CSG Mike
CSG Mike's Avatar
There isn't.... yet. The CSG-spec SRC is the closest, but it would tier in higher than a XIDA. However, the design philosophy behind the dampers are identical.
The XP12 will survive r-compounds, but you will go through them fairly quickly since you're pretty experienced. They won't last a full season like they will on a Miata. Getting a BBK up front will be the largest consumable cost reduction you can make. The faster guys generally go through a set of race pads in 4 days or so with street tires.
Since you do run r-comps, you'll notice we're the feature BRZ in Maxxis's testimonial video, along side Emilio.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
