Old 10-07-2014, 08:26 PM   #43
pleong
Drives: 2013 Whiteout FR-S
Has anyone tried the subaru resistor or splash air bag light fix yet?
TEAM NEMESIS | NEM 86 | IG: @NEM_86
PTE5858 Turbo | Integrated Engineering Fuel Surge Tank | 1300cc Injectors | Exedy Twin Disc | RAYS Volk ZE40 | 295/30/18 | 522whp @ 6,600 Dyno Dynamics
The NEM86 Build Thread
pleong is offline   Reply With Quote
The Following User Says Thank You to pleong For This Useful Post:
BPM (06-03-2017)
Old 12-08-2014, 01:39 PM   #44
vroom4
So the airbag from steering wheel still works after the resistor trick? Sorry, couldn't find a clear answer.
vroom4 is offline   Reply With Quote
Old 12-08-2014, 02:19 PM   #45
tigermack
STX 188
tigermack's Avatar
Drives: STX BRZ
Send a message via AIM to tigermack
I'd believe so, or else the light would stay on.
tigermack is offline   Reply With Quote
Old 12-09-2014, 08:28 AM   #46
pleong
this trick didn't work for me for some reason.. not sure what was done wrong..
Old 07-04-2015, 02:30 AM   #47
8R6
8R6's Avatar
Drives: FRS
what do you mean by it not working?
sorry for bumping an old thread but i still had some questions and figured this is better than a new thread...
after a few hours of searching in this forum, as well as others online, im just curious as to all the types of issues some people are having still. looks like this resistor trick works for the majority, but there are still some with issues and in case i have the same issues i just wanna be prepared when i do mine lol.
thanks
8R6 is offline   Reply With Quote
Old 07-10-2015, 02:35 PM   #48
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Drives: 13 BRZ, Galaxy Blue Silica
I'm about to do this tonight after work. Will report back.
Perrin Headerback, OFH, OFT, Ohlins R&T MI20, 17x9 Weds TC105N, Hankook RS4 (235/40), TOM's JDM Tails, PCV AOS, Perrin Crank Pulley, Perrin Rear Trans. Mount, Whiteline Shift Bushing, SS brake Lines, Hawk DTC60, Bayson R Lip Kit, LED Lighting , Smoked JDM Sidemarkers, Rear Fog Enable, Carsmo Armrest, Grimmspeed Plate Relocater
φφκα
Cjymiller is offline   Reply With Quote
The Following User Says Thank You to Cjymiller For This Useful Post:
8R6 (07-10-2015)
Old 07-15-2015, 01:20 PM   #49
pleong
thanks
it just didn't work.. the light was still on
Old 07-15-2015, 02:22 PM   #50
8R6
8R6's Avatar
Drives: FRS
any updates?
Old 07-15-2015, 07:58 PM   #51
Cjymiller
Original 2013 Owner
Cjymiller's Avatar
Seat base finally came in and I was able to do the switch over today. 3.3 Ohms 1 Watt resistor worked like a charm. Make sure you have the right colors on your resistor to ensure that you aren't using a 33 or a 330 or a 3300 or a... you get the picture.
Here's a diagram below: You will be using a 4 band resistor colored Orange Orange Gold Gold.
φφκα
The Following 4 Users Say Thank You to Cjymiller For This Useful Post:
8R6 (07-16-2015), tigermack (07-16-2015), Tristor (05-28-2018), Yobiwan (02-10-2016)
Old 07-16-2015, 12:51 AM   #52
8R6
8R6's Avatar
Drives: FRS
Awesome. Thanks for the super clear pic!! In your pic it doesn't look like there are 4 holes as mentioned in the OP. But it still does look like they're both in the same position at the bottom of the plug. I'm finally getting my new seat tomorrow and I already have the correct resistor, so I guess I'll see for myself next week when I install.
What are you doing to keep the resistor in place in the plug? Just covering it up with electric tape?
Thanks again for the great info and pic again! Much appreciated!
Old 07-27-2015, 01:12 PM   #53
8R6
8R6's Avatar
Drives: FRS
just to add to the thread for anyone in the future that comes across this, i did the resistor mod over the weekend and no airbag light!
i also transferred over the stock seatbelt buckle with cable from my stock seat to my new seat and no seatbelt warning/light either. not sure how/why some people are getting a seatbelt warning - when taking off the stock buckle, you have to transfer the cable with it, no? i just unclipped the cable from its holders and unbolted the buckle, then just transferred everything over. plugged the connector back up and everything is "normal" again.
Old 07-27-2015, 01:35 PM   #54
aznflightfreak23
aznflightfreak23's Avatar
Drives: 2014 Subaru BRZ Limited Manual
Just installed my bride stradia seats this weeekend. Need to get those resistors for the driver and passenger seats. From browsing this thread the only way to get rid of the passenger airbag is removing OEM seat sensor and reinstall. Any other methods to get the passenger seatbelt/airbag light turned off?
aznflightfreak23 is offline   Reply With Quote
Old 07-31-2015, 12:23 PM   #55
qqqqball
qqqqball's Avatar
yeah..this trick isn't working for me....I've tried multiple times but still have the airbag light on my dash. I took a multimeter and the resistor even read 1 w, so it's working properly.
qqqqball is offline   Reply With Quote
Old 07-31-2015, 01:00 PM   #56
8R6
8R6's Avatar
Drives: FRS
driver-side airbag?
Light Weight Seats sw20kosh Tracking / Autocross / HPDE / Drifting 23 11-06-2012 11:15 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 05:09 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
FR-S / BR-Z Racing Seats!!! vividracing Interior Parts (Incl. Lighting) 8 06-19-2012 08:07 PM
