Old 12-04-2014, 02:31 AM   #57
Celigts
Celigts's Avatar
Drives: 2014 Toyota FRS
Originally Posted by lukey86 View Post
225/40's what I went with, as I said its a fair stretch but they look awesome
And yeah I thought I would have issues with the fronts as well but nothing so far, it does rub the chassis a little at full lock but that's ok...it all really depends on your coils and how much camber they give, most are the same and with 8k fronts and maxed out camber plates you should be fine, they'll poke a few mm but will look mint
Soooo clean!!!! Should I get LCA?? I can get the spc lca for 200. Worth? Or not needed? Im at the "checkout" menu on evasive motorsports website with them. Lemme know asap lol
Celigts is offline   Reply With Quote
Old 12-04-2014, 02:42 AM   #58
lukey86
Built Not Bought
lukey86's Avatar
Drives: 2012 Toyota 86 ZN6
I don't have them myself, I was gonna get them but I got the look I wanted without them, the big plus with aftermarket though is strength, with high spring rates comes the added strain on the suspension parts....but as I said I don't have them (yet) lol and I'm happy with the look of my car, but if you do get them I'd reccommend getting them installed professionally and get a wheel alignment (something you should probably do after new coils anyway)
lukey86 is offline   Reply With Quote
The Following User Says Thank You to lukey86 For This Useful Post:
Celigts (12-04-2014)
Old 12-04-2014, 02:54 AM   #59
Celigts
Celigts's Avatar
Idk if they're worth it. Or if I should get a different brand...I'll head over to skunk2 tomorrow and see if they have anything in the works. Maybe I'll hold off til I do more research.
Old 12-09-2014, 02:28 AM   #60
Celigts
Celigts's Avatar
Hey so I just tried to install it. Got thec18x9.75+20 on 235/40/18 ... and man when it's maxed low on the skunk2 coils it rubs...impossible to drive on 10k springs... also sticks out like an inch in the rear and maybe 2 inches in front. Did you use a camber bolt for front? How much gap do you have from top of tire to fender on front/rear?
Old 12-09-2014, 02:29 AM   #61
Celigts
Celigts's Avatar
As it sits now...in order to drive it...I have like a 2 finger gap in front and 3 finger gap in back...not exact measurements but...lol it looks bad
Old 12-09-2014, 02:46 AM   #62
lukey86
Built Not Bought
lukey86's Avatar
I have a one finger gap front and rear but I have 225's not 235's...it pokes about 20mm front and rear as well which is fine, no camber bolts or anything else, I'd say it's your tyre size, you might not think there would be much difference between the two but there is when you're trying to go low...got any pics?
Old 12-09-2014, 02:57 AM   #63
Celigts
Celigts's Avatar
I do let me upload...also my coils were loaded wrong...Sooo that might have impacted. I'll post. Sec.
Old 12-09-2014, 02:59 AM   #64
Celigts
Celigts's Avatar
Sorry for sideways view...uploaded from phone...stupid thing...anyways thats it fully dropped...rubs all around...so currently it's sitting high as fauq. Needs wayyy more low. I have camber bolt for front...might need to use that...also gonna redo the coilover preload my damn self...since the shop is took it to had noooo idea wtf they were doing...tell me why my camber plate was installed facing sideways? ?? I was like uhhh...ya no.
Old 12-09-2014, 03:10 AM   #65
lukey86
Built Not Bought
lukey86's Avatar
There looks to be a lot more meat on those tyres compared to mine...also, do you have camber plates up front? looks like its running positive if anything, or is it just the angle of the photo?
Celigts (12-09-2014)
Old 12-09-2014, 03:12 AM   #66
Celigts
Celigts's Avatar
I shoved the plate toward the center of the car. Away from the tire...maxed out. Correct right?
Old 12-09-2014, 03:21 AM   #67
lukey86
Built Not Bought
lukey86's Avatar
Yeah sounds about right, just doesn't look right in the pic here's mine, getting heaps, enough to clear the rubber
Size:  376.0 KBName:  ImageUploadedByTapatalk1418113278.704295.jpg
Old 12-09-2014, 03:34 AM   #68
lukey86
Built Not Bought
lukey86's Avatar
lol I didnt read this till just now, yeah I'd be asking for my money back, thats shocking! incorrectly installing camber plates is easy enough to do for the DIY'er but not a proffessional shop! once theyre facing the right way you'll get alot more camber
Old 12-09-2014, 03:41 AM   #69
Celigts
Celigts's Avatar
Honestly...on the skunk2 camber plate I can't tell which way is front and back...etc. lol I'll have to check in the morning....maybe they're reversed...also I can move the screw over to the middle which I just found out lol. Tomorrow 8am...time to do it right!!
The Following User Says Thank You to Celigts For This Useful Post:
lukey86 (12-09-2014)
Old 12-09-2014, 03:48 AM   #70
lukey86
Built Not Bought
lukey86's Avatar
Which screw are you talking about?
Also I'm gonna have a play around with different pre-load/dampening settings this week sometime to try and find the butter zone for ride quality without rub, I'll let you know how I go
Finally ! she's here ! Christina_Marie Scion FR-S / Toyota 86 GT86 General Forum 44 09-12-2012 03:58 PM
YES! finally here! :) HELP Obja Scion FR-S / Toyota 86 GT86 General Forum 58 09-07-2012 01:30 PM
Finally here!! _F-R-S_ Scion FR-S / Toyota 86 GT86 General Forum 3 08-26-2012 11:13 AM
Finally geb2391 Northwest 11 07-24-2012 02:12 PM
Finally got it!! percyng CANADA 21 06-17-2012 01:50 AM
