Old 12-06-2014, 08:39 AM   #99
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
There's a bolt and washer that goes on top to secure the pulley to the charger, but not sure if there's anything else on the charger side (spacer for example)... When I do secure the bolt and washer to the charger, the pulley doesn't spin since it's touching the charger base. Just want to make sure that makes sense before I re-install it today. I would call Vortech, but they are closed on the weekends...
If you are wondering why it was removed... I had the charger checked out and it needed one new bearing and shaft seal.... the re-builder removed the pulley in question... and hence, my question since the pulley is pre-installed by vortech when bought new.
Edit 12/7: There's a bearing that goes between the pulley and charger that I didnt realize was in the return box... everything is reinstalled. The pulley does spin as it should
Vortech SC V3 // 3.12 Pulley // Moto-East Tune (93oct,e40-50,e85)
sissupr is offline   Reply With Quote
Old 12-07-2014, 12:45 PM   #100
SonnyBRZ
SonnyBRZ's Avatar
Drives: 15 WRX 6mt (DD), 13 BRZ Sports Tech
For those with the V2 upgrade, during the install did you notice the tensioner requires to be turn all the way and the belts are still very hard to slip in? I had to slip a few grooves in and turn the crank manually so the rest would follow.
Not sure if anything is changed externally for the V2 but the tension on the belt and bearing is hell of alot greater than than stock or the V3 unit. I'm concern the bearings are taking alot of load. Previously, the V3 bearing failed this is why i'm paranoid.
If anyone or Vortech can chime in it is appreciated.
06 Infiniti G35x - Black 5AT (DD)
13 BRZ Sports Tech - White 6spd (June 18, 2012!) - Vortech SC
15 WRX Sport - ISM 6spd - Ordered May 3, 2014
SonnyBRZ is offline   Reply With Quote
Old 12-07-2014, 03:07 PM   #101
SonnyBRZ
SonnyBRZ's Avatar
Also want to add, the V2 casing is hot to the touch once warmed up and or driven (since it uses oil from the engine), where as V3 is just warm. I assume this is normal, anyone with V2 please let me know, thanks.
Old 12-07-2014, 05:50 PM   #102
Border7
Border7's Avatar
Drives: 2014 Subaru BRZ
Is there any superior place to purchase the vortech kit, better deals? anything like that for forum members.
4,600 just seems a little high when kits like KW and JRSC are so much cheaper, KW kit was going for 3600 for forum members. 1k less?
Any insight?
Border7 is offline   Reply With Quote
Old 12-07-2014, 09:04 PM   #103
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Any insight?
Talk to @PERRIN_Mladen at Perrin. He'll give you a good deal on the Vortech Kit. He's super easy to work with too. It's where I got my kit and everything went great.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
The Following User Says Thank You to Gopherboy6956 For This Useful Post:
PERRIN_Mladen (01-02-2015)
Old 12-07-2014, 09:33 PM   #104
Akari
Drives: 2013 DGM BRZ
Any insight?
Openflash's Vortech price is around $3800, not sure that there are any better deals out there than that.
Akari is offline   Reply With Quote
Old 12-07-2014, 09:53 PM   #105
Border7
Border7's Avatar
Thansk guys i will look into those for sure plan on order a supercharger soon.. just quite undecided still... i like the KW, JRSC and vortech :O so hard to pick one or the other
Old 12-07-2014, 11:29 PM   #106
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
The v2 is hella more stout than a v3
I beat the snot out of mine
13/14 psi
The v2 has no issue where the v3 would cook its 4oz of fluids
I concur, it can run hotter if you will, it does share engine oil, but I'm not sure about more load
Make sure you vent your v2 or foaming can kill it. Ask me how I know, just always warm up your car to prevent that initial start up foam!
I love my v2 just wish I wouldn't snap belts with the 2.87" pulley buy have found no solution, running the 3.33 I can run a belt and track it all summer long, and that's saying lots here in hell, aka phx
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 12-08-2014, 01:47 PM   #107
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
How can one tell if a Vortech kit is V2 or V3? The sites I looked at don't mention the version.
Sleepless is offline   Reply With Quote
Old 12-08-2014, 01:49 PM   #108
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Don't they have kits with both?
FyeaFRS is offline   Reply With Quote
Old 12-08-2014, 01:54 PM   #109
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
OpenFlash and Perrin don't specify but they both look like the V3 SC. I want whichever is best suited for hard track driving (stock pulley; reliability and durability are my top priorities).
Old 12-08-2014, 02:29 PM   #110
Foobar
SLO NO MO
Foobar's Avatar
Most vendors advertise the v3. The v2 is a special order item, as I understand it.
Old 12-08-2014, 04:23 PM   #111
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
I found a few vendors that sell both and of course Vortech directly sells both.
I recently purchased OFT, primarily since I saw they supported Vortech as the basis for the OFT300 package, but after contacting sales, they say they only support the V3 kit.
@Shiv@Openflash - Any chance you would support the the V2 kit? Any reason to think they require different tuning?
Old 12-08-2014, 04:34 PM   #112
Foobar
SLO NO MO
Foobar's Avatar
I guess the vendors that sell both differentiate by calling one the Competition Level Tuner Kit. Part number 4TF218-124. The regular tuner kit is part number 4TF218-114L.
The Following User Says Thank You to Foobar For This Useful Post:
Sleepless (12-08-2014)
New Vortech Maxflow Blow-Off Valve Upgrade for FT86 Supercharging Systems Brian@Vortech Forced Induction 168 08-08-2018 11:45 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 02:05 PM
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
Vortech Supercharging Systems Now Legal On 2 Continents... Brian@Vortech Forced Induction 27 01-22-2014 01:33 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 05:49 PM
