go_a_way1
Old 12-05-2014, 06:32 PM   #29
sato
sato's Avatar
Drives: Dodge Patitas
I'd expect the kit to make around the same power as every other CARB kit, in CARB form. There's only so much you can do with CA 91.
However, there will be more than enough overhead to require a built engine to utilize the full potential of the supercharger.
We just hope we don't have to buy in pairs at an non-negotiable cost of $50k...
sato is offline   Reply With Quote
The Following 2 Users Say Thank You to sato For This Useful Post:
EAGLE5 (12-05-2014), lightdir (03-21-2015)
Old 12-07-2014, 10:46 AM   #30
xwd
I would expect both the Harrop and Edelbrock to use the TVS 900, same exact supercharger as the Cosworth kit.
The Following User Says Thank You to xwd For This Useful Post:
CSG Mike (12-07-2014)
Old 12-07-2014, 11:51 AM   #31
350matt
Drives: toyota mr2/ Toyota GT86
then why would you wait for the E force solution? when you can get a Cosworth kit now?
will E force kit will cheaper do we think?
also it looks like its a front breathing unit rather than from the rear so is there room for this,a dive pulley and the AC pump?
as the TRD setup was a front breathing unit but that had no AC?
350matt is offline   Reply With Quote
Old 12-07-2014, 12:04 PM   #32
Calum
That Guy
Drives: 2013 asphalt FRS MT
You can see the ac compressor in the picture.
The Following User Says Thank You to Calum For This Useful Post:
Freeman (12-07-2014)
Old 12-07-2014, 12:16 PM   #33
350matt
yes you can,
you can also see that there's almost no room to get an intake pipe, off the throttle body and past the AC pulley
maybe the angle of the picture is misleading but it looks to me like the AC pulley would have to go to get this to fit
Old 12-07-2014, 12:19 PM   #34
xwd
I think both will be considerably cheaper than the Cosworth kit, probably in the $4K range.
I think it's just a mockup, I would expect any production setup they produce to keep the A/C.
I have the TRD unit and it also uses a significantly larger throttle body than the stock one. If it were stock sized and the snout a little shorter you could potentially get a 90 degree elbow in there with the A/C still installed.
Old 12-10-2014, 07:50 PM   #35
stoked_on_spool
Drives: 2013 BRZ, SSM, Limited, M/T
Originally Posted by itsibarra View Post
This just came up on my feed...
I think the red manifold is a 3D printed mock-up and that's why it looks the color/shine it does, not because the photo was overly photoshopped
Bret
stoked_on_spool is offline   Reply With Quote
The Following User Says Thank You to stoked_on_spool For This Useful Post:
clayrush (02-11-2015)
Old 12-12-2014, 08:40 PM   #36
Stark Performance
Drives: 2014 FR-S
It is pretty typical to paint prototype parts red to distinguish them from production units. That way no one accidentally sends out the prototype to a customer.
Stark Performance is offline   Reply With Quote
The Following User Says Thank You to Stark Performance For This Useful Post:
HachiEnam (08-21-2015)
Old 12-14-2014, 04:53 AM   #37
nonicname returns
Drives: 4 wheels
1) looks amazing!
2)looks pricey! Very pricey.
3)I really hope they offer more colors not just
That huge chunk of red.
nonicname returns is offline   Reply With Quote
Old 12-14-2014, 04:59 AM   #38
GT86_PRAGUE
Drives: GT86
Originally Posted by keen as View Post
from harrop facebook
"2015 TVS Supercharger kit release sneak peak.."
https://www.facebook.com/harropperfo...levant_count=1
Cosworth inspired?
GT86_PRAGUE is offline   Reply With Quote
Old 12-14-2014, 11:44 AM   #39
s2d4
s2d4's Avatar
Originally Posted by GT86_PRAGUE View Post
Cosworth inspired?
Front entry vs rear entry?
Or is every twin w2a tvs setup cosworth inspired?
Old 12-14-2014, 11:52 AM   #40
RFB
RFB's Avatar
Drives: FRS
No strut bar ? No tracking ?
RFB is offline   Reply With Quote
Old 12-14-2014, 03:07 PM   #41
GT86_PRAGUE
Drives: GT86
I dont know, this just cross my mind.
Old 12-14-2014, 03:09 PM   #42
s2d4
s2d4's Avatar
What else crosses your mind on a daily basis?
boost, byebye jackson racing, e-force, edelbrock, forced induction, supercharger
Trunk needs a bit of force to close..... Hachiroku14 Issues | Warranty | Recalls / TSB 30 06-19-2018 06:09 PM
X-Force 3" Exhaust mwjcyber Engine, Exhaust, Transmission 19 03-13-2017 02:55 PM
The force is strong with this one (2015 STi) blackhawkdown FR-S / BRZ vs.... 39 08-01-2014 01:26 AM
X force or Invidia N1 JakeG AUSTRALIA 8 01-18-2014 05:16 AM
G-force meter mikepaul21 Cosmetic Modification (Interior/Exterior/Lighting) 2 03-17-2013 02:24 PM
