Old 12-05-2014, 03:50 AM   #5685
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Fizz View Post
Will the MAF based Innovate tunes be phased out eventually in favour of the Flash&Go tunes only?
Right now the answer is no. Currently the MAF based tune is still a little more refined tune for the Innovate Kit and something we prefer to offer to this market instead of the Flash & Go. I do not believe we will ever drop it as we have spent far too much time on this tune to do so.
Cheers,
William Knose
The Following 3 Users Say Thank You to DeliciousTuning For This Useful Post:
Fizz (12-05-2014), Khorne (12-05-2014), Lawnik (12-05-2014)
Old 12-05-2014, 02:21 PM   #5686
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
@DeliciousTuning I see that you offer maf scaling options for the 3" perrin intake. Curious what gains are had with this intake if any. I just put one on and I'm ready to pull the trigger on a delicious tune because the dyno is getting expensive!
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 12-05-2014, 03:32 PM   #5687
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Originally Posted by DeliciousTuning View Post
Well the bucking you are getting if you even feel it warmed up I would check for small vacuum leaks. Also check your short term fuel trims at idle, what are they. This is usually a sign of a small leak too.
Otherwise when cold my car has a light hesitation but that is,about it. Once warmed up past about 50 Celsius it runs smooth.
Now I do know I coukd play with the cams even more for cold and warm conditions but just have not focused on this tune lately. We have been focused on our Flash & Go map for all forced induction applications. I even have it working on the Innovate kits now too so you can read higher boost but it is a much different tune. Speed Density versus MAF based.
Cheers,
William Knose
What should the short term fuel trims be showing at idle?
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 12-05-2014, 05:27 PM   #5688
DeliciousTuning
I hate to say it but we have not see any gains with the Perrin 3" intake over say an Airaid. Now over stock there is a benefit but beyond that we have not see any real difference.
Because of that we prefer anything that will keep the air temps cooler, so plastic, heat wrap, air from outside the engine bay etc... Anything to keep it cooler will help.
Idle fuel trims we like to see about 0 to +10 usually. If you are getting much above that there may be a small leak.
Cheers,
William Knose
MINOCIN (12-06-2014), poorsche (12-05-2014), whataboutbob (12-06-2014)
Old 12-05-2014, 05:31 PM   #5689
CK_Bladesmith
Drives: Raven FR-S
Cheers,
William Knose
Sounds good. I'll make sure I double check everything once I redo the pcv and breather lines. Thanks Bill.
Old 12-06-2014, 12:46 AM   #5690
Ethan
Drives: Subaru BRZ
Originally Posted by whataboutbob View Post
I was getting squeaking from the idler pulley. It never failed completely, but when I took it off it had a lot of slop in the bearing. I'd suggest you pick up one of the pulleys that I linked to above, I've had it on my car for some time now and it isn't squeaking. Seems like a good fix.
Bob, when you replaced the pulley, did you need to replace the belt too? I am getting a squeak and the guys at HG thought it was just the belt making the noise due to the rain/humidity we have now. But perhaps it could be the pulley.
Ethan is offline   Reply With Quote
Old 12-06-2014, 01:10 AM   #5691
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Since they're simple enough to change, I'd do the pulley first and see if the squeak goes away. Then belt later if needed.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
Ethan (12-08-2014)
Old 12-06-2014, 01:47 AM   #5692
poorsche
poorsche's Avatar
Cheers,
William Knose
Thanks, Bill. At least the Perrin intake makes the blower whine noticably louder at full throttle, and that's good 'nuff for me! Until it is accounted for in a tune, do I have to worry about damaging something running this? It seems to runs smooth on my current e85 tune.
[IMG][/IMG]
Old 12-06-2014, 10:36 PM   #5693
whataboutbob
AutoX-10/10ths every run
I did not, but I did just recently replace my belt after about 30K as it was making some squeaking noises when shifting. I'm still on the 75mm pulley.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
Ethan (12-08-2014)
Old 12-07-2014, 09:59 PM   #5694
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
@DeliciousTuning when purchasing your tunes online, there's a drop down list under "Vehicle World Region Identifier".
Which one should I select for Australian market vehicles?
Old 12-08-2014, 12:12 AM   #5695
blown
Drives: ft86
the perrin 3" fits with the plastic inlet pipe?
blown is offline   Reply With Quote
Old 12-08-2014, 12:38 AM   #5696
blown
Drives: ft86
anyone also think about adding a larger coolant tank??
Old 12-08-2014, 12:38 AM   #5697
poorsche
poorsche's Avatar
Yea since the innovate tube mounts at the stock location, the coupler is in the right spot for the perrin to bolt right up.
Old 12-08-2014, 12:25 PM   #5698
DeliciousTuning
Australia is JDM market.
Sincerely,
Zach
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
