Old 12-05-2014, 05:00 AM   #4439
Alabang 86
Alabang 86's Avatar
Drives: GT86
Finally installed mine this week...header was sitting in the box for months. yes, I'm nuts.
Faster, lighter and sounds way better.
Need to make a video....the video above doesn't sound like mine, mine is way better.
Does anyone have a tune for a full Nameless 3" with the Innovate SC?
...my turn...
Alabang 86 is offline   Reply With Quote
Old 12-05-2014, 05:02 AM   #4440
Alabang 86
Alabang 86's Avatar
Drives: GT86
Originally Posted by Brinks View Post
The million dollar question is the dip noticeable. Does the car feel slower in that RPM range compared to stock when driving around on a day to day basis?
to answer your question, the dip is noticeable but only if you are looking for it.
my car is way faster now. esp over 5k rpm
you can send me the mil, paypal ok.
...my turn...
Old 12-05-2014, 07:17 AM   #4441
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Can anyone confirme fitment with the greddy aka sbd turbo? I really don't want to sell this header when I go fi...
Or any fi for that matter.
Carlitoz3 is offline   Reply With Quote
Old 12-05-2014, 07:22 AM   #4442
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Doesn't greddy have it's own manifold?
So... No you can't use it with the greedy/SBD.
You could use it with the Ptuning kit, works, STS, anything else that doesn't replace the header.
Old 12-05-2014, 10:50 AM   #4443
jflogerzi
jflogerzi's Avatar
No. You must use there header.
2013 Series 10 FRS #553
Old 12-05-2014, 01:45 PM   #4444
Brinks
Brinks's Avatar
I been running the header for about two or three months now and I don't even notice it anymore. I rev the car more before taking off from a stop, problem solved.
Brinks is offline   Reply With Quote
The Following User Says Thank You to Brinks For This Useful Post:
Alabang 86 (12-11-2014)
Old 12-05-2014, 05:00 PM   #4445
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
The video above is with a full Nameless 3" exhuast and NA. Also a different tune the tune now sounds way better. If you just installing the header on a stock exhaust I would be curious to hear it as it would be much different.
Shneegle is offline   Reply With Quote
The Following User Says Thank You to Shneegle For This Useful Post:
Old 12-05-2014, 11:00 PM   #4446
blown
Drives: ft86
anyone have a picture of the header/oil pan clearance installed?
blown is offline   Reply With Quote
Old 12-06-2014, 05:07 PM   #4447
Jman1759
Builder
Drives: 2014 BRZ - World Rally Blue
Here you go
Jman1759 is offline   Reply With Quote
Old 12-15-2014, 03:26 AM   #4448
GT86_PRAGUE
Drives: GT86
Could someone explain to me the difference between Nameless and Cosworth (Nameless) Headers for FA20? I expect them to be the same, but there are some discrepancies on graphs both companies are showing.
I dont like the fact that having Cosworth header (actually whole 1.3 kit) installed put me back on power and torque against Catback only (1.1 kit).
Nameless present graph which is more desirable to me and I could probably use 1.3 Ecutek tune from Cosworth.
I asked Cosworth to explain the drop but without reply so far.
Based on this thread I dont think someone from Nameless will reply to my email but I will try.
Any thoughts? (which one to buy, what is different, why is there a drop in power)
GT86_PRAGUE is offline   Reply With Quote
Old 12-15-2014, 03:44 AM   #4449
Shneegle
Shneegle's Avatar
So the Cosworth is made by Nameless Performance, and honestly there does not look to be a difference in the way the header will work. The difference could be more one is on stock exhaust vs the other being on the Cosworth exhuast or a difference in tuners. What part of the graphs are you talking about? It could help to just link them as the ones I could find could be different from the ones you have found.
GT86_PRAGUE (12-15-2014)
Old 12-15-2014, 04:10 AM   #4450
GT86_PRAGUE
Drives: GT86
This graph:
Before they released 2.0 kit they were advertising this graph:
I am on Yellow now (will be tomorrow).
If/when I upgrade to 1.3 (Blue lines) I will be actually getting less power between 2800-3700rpm for 2000 GBP?
The Following User Says Thank You to GT86_PRAGUE For This Useful Post:
Calum (12-15-2014)
Old 12-15-2014, 04:17 AM   #4451
GT86_PRAGUE
Drives: GT86
The thing is, I thought people are buying headers to solve the dip problem (or I at least see this on Borla, but that is too laud for DD here). I would expect at least some improvement in the dip area. Or it is caused by moderate Cosworth tune?
Old 12-15-2014, 10:18 AM   #4452
Mad_Mike
Mad_Mike's Avatar
Drives: 2013 Scion FRS firestorm
The nameless header and cosworth header are the same piece.
Not all headers (by different companies) are equal. Some were made to eliminate the torque dip, some were made for max top end power, and nameless's was made (I think ) to give you the biggest area under the curve and specifically midrange power. They all have their pros and cons. Buy a header that suits what YOU want to get out of a header.
Mad_Mike is offline   Reply With Quote
The Following User Says Thank You to Mad_Mike For This Useful Post:
21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag
Nameless Performance BRZ Axleback Exhaust ESBjiujitsu Engine, Exhaust, Transmission 1377 04-21-2020 02:23 AM
Nameless Performance Axleback is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 114 07-23-2012 10:38 PM
Nameless Performance Downpipe is available for pre-order. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 4 07-12-2012 04:57 PM
We are Nameless Performance. John@Nameless Announcements, Contests, Giveaways 22 06-18-2012 11:32 PM
Nameless Performance is here. Nameless Performance Inc. Engine, Exhaust, Bolt-Ons 16 06-06-2012 04:32 AM
