Old 11-30-2014, 04:57 PM   #1
samisons
Drives: 2013 Raven Fr-s, 2013 Versa Sedan
Flywheel Chatter
Completely stock car. Sounds like flywheel chatter goes away with pressing clutch. Sounds about the same as my 08 350z. Is this something I should go to the dealer for I always accepted that sound as normal in my Z days.
Edit: You can only hear it when idling.
samisons is offline   Reply With Quote
Old 11-30-2014, 05:25 PM   #2
JOSEC
Drives: 2014 Subaru BRZ WRB
It's normal. I've heard it since I bought mine last year with 4 miles on the odo.
JOSEC is offline   Reply With Quote
Old 11-30-2014, 07:45 PM   #3
It's actually gearbox chatter. Stuff rattles a bit at low rpm because the engine isn't actually rotating smoothly. Perfectly normal. Gets more intense with an even lighter flywheel.
aagun (12-03-2014), Reaper (12-01-2014), samisons (12-01-2014)
Old 11-30-2014, 08:07 PM   #4
Not uncommon with most rear wheel drive cars really. The big difference that a makes it so much more noticeable with these is that not only is the drivetrain just a few inches from your knees the only separation you have is metal barely thicker then a pop can and some cloth with flocking pretending to be carpeting. Hearing weird noises is just the price you pay for reduced weight.
axelo (11-30-2014), samisons (12-01-2014), Ultramaroon (11-30-2014)
Old 12-01-2014, 12:28 AM   #5
samisons
Only reason I mentioned the chatter, is that, I haven't heard it in the first two years of ownership.
Old 12-01-2014, 12:41 AM   #6
Then it's something else. If it's a new sound, definitely get some qualified eyes/ears on it.
Can you feel anything new in your clutch pedal? Throwout bearing?
Old 12-01-2014, 04:50 AM   #7
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
32k miles and my throwout bearing has gotten louder as well.
Very typical in cars with little sound deadening on the economy side of the price range, don't worry about it until the layman can hear the noise. Exedy who I believe may make the OEM clutch assembly is notorious for loud throwout bearings and rattling noises in their clutch assemblies.
It's a Subaru thing, hundreds of thousands of hits if you search for Subaru and transmission/exedy/clutch/rattle/noise/grinding what have you.
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
samisons (12-01-2014), Ultramaroon (12-01-2014)
Old 12-01-2014, 01:40 PM   #8
Wow, I had no idea it was that common. Meh, I love having an easy-to-drop tranny again.
Old 12-03-2014, 03:53 PM   #9
Fred E
Drives: WRB BRZ
By completely stock, do you also mean stock fluids (specifically transmission oil)?
Fred E is offline   Reply With Quote
Old 12-03-2014, 04:16 PM   #10
aagun
Drives: 86
i use 85w140 it is chattering
is use 75w90 it is chattering
any good idea then ignore it !!until the input shaft worn out
aagun is offline   Reply With Quote
Old 12-03-2014, 04:59 PM   #11
Fred E
Drives: WRB BRZ
The reason I asked is because the owner's manual does specifically say in the vehicle specifications section that "Using a manual transmission gear oil other than “MG Gear Oil special II” may cause occurrences of rattling noises while idling and poor fuel consumption." I've no idea how true that is or what they've put in the OEM oil to stop this rattling/chattering though.
Old 12-03-2014, 10:08 PM   #12
samisons
Yes, the transmission/diff fluid are still orginal
Old 12-03-2014, 10:14 PM   #13
strat61caster
There should be no issues using a correct rated gear oil, the manual reads the following:
Use either of the following:
• “MG Gear Oil special II”
• Other gear oil that meets API GL-3 and SAE 75W-90 specifications
Section 6-1 p.416 of BRZ Owner's Manual
Old 12-05-2014, 10:30 AM   #14
Fred E
Drives: WRB BRZ
Yeah, there won't be any longevity issues. I'm just pointing out the fact that Subaru does actually state (on that same page) that using a different oil can cause rattling.
(I'm using Motul, by the way; I'm not trying to push the OEM fluid. I do also hear the rattling.)
Clutch, LW flywheel and chatter.... wootwoot Engine, Exhaust, Transmission 20 11-17-2014 04:50 PM
Diff chatter when cold? BRZrkr BRZ First-Gen (2012+) — General Topics 1 06-23-2014 10:17 AM
Odd Chatter Noise? Chrisposey Forced Induction 5 05-05-2014 10:37 PM
Chatter upon engagement of gears 2,3,4 JDM-dono Issues | Warranty | Recalls / TSB 5 08-02-2013 09:09 PM
Increased media chatter can only mean one thing... sieeegel BRZ First-Gen (2012+) — General Topics 138 03-16-2012 11:19 AM
