Old 12-01-2014, 01:33 PM   #323
nunonuna
nunonuna's Avatar
Originally Posted by FT-86 SpeedFactory View Post
Header was not designed for peak HP. Was designed for gains in the mid range where it matters with a low HP car. Torque and usable power mid-range is what matters on track and daily driving.
What I meant was I doubt the Dyno shop I went not this lovely header~ I knew it was designed for mid range power. None against the product. Car feels much better with this header. There is big enough difference for anyone can feel. That is why I yet can't accept what this dyno reading shows.
Before I went to dyno, I tried to pull virtual dyno with data log on the nice smooth flat road of both prior to header and after. That result shows very good gain throughout the powerband, but not on this dyno I went last time. Again, I am doubting the dyno NOT this header~ I love it~
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
Julio86 (12-04-2014)
Old 12-02-2014, 02:20 AM   #324
Jamesbrz
Drives: White BRZ
Received mine today.
Jamesbrz is offline   Reply With Quote
Old 12-02-2014, 04:03 PM   #325
brianhj
Drives: 2017 Camaro 1SS
Pics
brianhj is offline   Reply With Quote
Old 12-04-2014, 08:40 PM   #326
Julio86
Julio86's Avatar
Drives: 2013 Scion FR-S 6MT
let us know when you dyne this puppy. I'll base my decision off you lol
I don't always drift every corner, but when I do, I drift FRS . Stay drifty my friends
2013 Scion FRS Whiteout 6MT
Julio86 is offline   Reply With Quote
Old 12-04-2014, 11:17 PM   #327
nunonuna
nunonuna's Avatar
I don't think I will redyno any soon because there is not many dyno shops in my town. Also, I just found out that the a/c compressor is the cause of low reading of power. Climate control was set to defrost mode so we assume that is why we had low reading. I know it was dumb thing that we didn't make sure the a/c is off. So Im happy now with result. 164 whp with a/c on is not that bad on dyno dynamics. The base fr-s power was 145 whp on the same dyno. We never know what the readings will be with a/c off, but Im pretty sure it will show some more hp/tq. I don't know when I will get re-dyno, but here is virtual dyno comparison until I post new one.
Green graph is with stock header + headerback exhaust + oft stg1.
Blue graph is with this header + headerback exhaust + oft stg1.
Red graph is with this header + headerback exhaust + oft stg 2 uel tune.
All three runs were done on same exact road.
I know this is not true dyno but sure it shows gains of power.
kodyo (12-05-2014)
Old 12-05-2014, 01:18 AM   #328
s2d4
s2d4's Avatar
50 lbft between stock and this header on the same tune, amazing!
Old 12-05-2014, 06:51 AM   #329
nunonuna
nunonuna's Avatar
Like I said, this won't be true comparison for how much exactly it gained, but I just post it to tell the gain is there to show the gap. Yes I am stupid enough not to turn off a/c before Dyno, but am not that stupid to believe this shows true gain. Of course it never gained 50 ft lbs torque. I dont even believe that it produce 200 whp.
Old 12-05-2014, 07:17 AM   #330
Foobar
SLO NO MO
Foobar's Avatar
AC compressor shuts off at WOT anyway, so that shouldn't be much of a variable.
Old 12-05-2014, 11:57 AM   #331
s2d4
s2d4's Avatar
Well, forget it then until I re-dyno mine to have solid data. It may show the same result, but I just wanted to make sure before I accept last time result because I still doubt last dyno session because of 4th gear run instead of 3rd gear pull + a/c on are enough reason for me to make second thought. Reason for a/c is the cause? I've seen some Dyno result showing power loss with a/c on. I know it disengage ac compresser clutch, but still lose power. I will also give a try ac on and off when I redyno mine.
I just don't want people to think that this header doesn't produce good gain based on my result ONLY. There are many other members who claimed good gain throughout the power band. Its just mine shows that not. That is it.
What is your fascination with 3rd gear?
Old 12-05-2014, 08:19 PM   #332
nunonuna
nunonuna's Avatar
The previous pull was on 3rd gear before I had header install, but he did 4th gear pull this time. That is why I don't think it is good comparison.
Old 12-05-2014, 08:23 PM   #333
brianhj
Hahaha
Old 12-06-2014, 05:41 PM   #334
bodayguy
Drives: 2016 MX-5 Club
I am thinking of ordering one of these. Just curious, what effect will it have on gas mileage? Anyone have some experience to share there? Or with aftermarket headers in general? I get about 27 mpg now.
bodayguy is offline   Reply With Quote
Old 12-09-2014, 11:17 AM   #335
Mayb92
Mayb92's Avatar
Drives: 2013 Asphalt Scion FR-S
Currently 11th in Line, They hope to have mine out by the end of the month.
Mayb92 is offline   Reply With Quote
Old 01-27-2015, 03:24 AM   #336
Jonesy86
Jonesy86's Avatar
Drives: innovate sc frs
Has anyone else have this header crack on them? Not too happy, as it's only 14 months old...
Jonesy86 is offline   Reply With Quote
FT-86 SpeedFactory Catted UEL Header FT-86 SpeedFactory Engine, Exhaust, Transmission 2689 07-06-2019 07:19 PM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
FT-86 SpeedFactory UEL Catted m.wood0213 Engine, Exhaust, Transmission 0 12-06-2013 01:30 PM
I created an automatic Toyota order status notifier for you guys. Check it out. eleu2166 AUSTRALIA 32 03-05-2013 03:18 AM
