Old 12-02-2014, 01:50 PM   #5657
whataboutbob
AutoX-10/10ths every run
Originally Posted by poorsche View Post
The pulley itself failed? Not understanding
I had the bearing in the idler pulley start to fail in about 7k miles.
Build thread:Here
Old 12-02-2014, 08:09 PM   #5658
Lawnik
Lawnik's Avatar
Drives: Flat grey Toyota 86
Originally Posted by Ethan View Post
And for the record, I have the 69mm pulley, intercooler, and flex fuel kit from Delicious. Car is happy, happy, happy.
Do you have the flex fuel tune or the whole flex fuel kit? I don't see the kit on their website
@sales@delicioustuning.com
When will the full kit and tune be on the website?
Lawnik is offline   Reply With Quote
Old 12-02-2014, 08:18 PM   #5659
poorsche
poorsche's Avatar
Drives: 13 BRZ Limited, 2000 Impreza Sport
Ok, so the bearing failed and was replaced with the pulley. Got it.
Innovate powered- Corn fed- FBM tuned
poorsche is offline   Reply With Quote
Old 12-02-2014, 08:34 PM   #5660
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Stupid question, but do we have 2 idler pulleys?
Fizz is offline   Reply With Quote
Old 12-02-2014, 10:57 PM   #5661
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
We have several testers out, unfortunately our testers took the last of our FlexFuel sensors. We've ordered a batch and are waiting on them to come in. That's literally the last bit.
Sincerely,
Zach
Old 12-03-2014, 02:06 PM   #5662
CarzCarzCarz
CarzCarzCarz's Avatar
Drives: 2014 WRB BRZ
I've got a noise/squeak from the idle or tensioner pulley now, and only 500 miles after installing the supercharger. Does the pulleys making noise pretty much mean it's about to go, or is it normal now with the added strain from the SC?
CarzCarzCarz is offline   Reply With Quote
Old 12-03-2014, 03:19 PM   #5663
whataboutbob
I was getting squeaking from the idler pulley. It never failed completely, but when I took it off it had a lot of slop in the bearing. I'd suggest you pick up one of the pulleys that I linked to above, I've had it on my car for some time now and it isn't squeaking. Seems like a good fix.
Build thread:Here
Old 12-04-2014, 10:05 AM   #5664
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I've read about some guys having low speed drivability/throttle modulation issues, whereas some others say their's feel just like stock...simply by using a canned tune (i.e. Delicious).
So I went down to see a local sprintex installer/tuner (renowned subaru specialist) chatted a long time but he pretty much said it can't be totally eliminated. According to him they can smoothen but it'll always be there. I always thought a dyno tune would be best. So I left there slightly confused and not feeling very confident about using them
Going to speak to another tuner tomorrow. Plan is to bet boosted before xmas
Old 12-04-2014, 11:03 AM   #5665
s2d4
s2d4's Avatar
Maximum Motorsport then Tokyo Motorsports?
Old 12-04-2014, 11:17 AM   #5666
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Will speak to Jai from Big Rock tomorrow.
Old 12-04-2014, 11:46 AM   #5667
poorsche
poorsche's Avatar
I had surging/ bucking issues at partial throttle after being dyno tuned and started to think I made a big mistake. Eventually driveability got so bad I dyno tuned again at a more reputable shop and all the issues were completely eliminated. If it has any throttle issues, they are so minute that I can't feel them. It's all in the hands of the tuner here. Heard nothing but praise for delicious tunes, I wouldn't hesitate to go that route.
Old 12-04-2014, 12:19 PM   #5668
s2d4
s2d4's Avatar
Isn't he the service manager at the dealership? didn't know he is a tuner.
Old 12-04-2014, 12:20 PM   #5669
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
Innovate (Sprintex) Supercharger Owners Topic
Mine still to this day surges and bucks while the oil temperature is cold, and this is on the most recent revision from @DeliciousTuning. I'll be pulling the blower off of my car soon to look at the laminova core and to redo the pcv/ breather system on the car. Gonna be installing dual Radium catch cans and replacing the pcv valve. I'll also be adding check valves to the outlet sides of the catch cans, since radium doesn't supply any, if I can find them.
Edit: I also replaced the 2 coil packs that were misfiring the most and it still misfires while the engine oil temp is cold. Spark plugs, however, looked good when I checked them.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
Old 12-04-2014, 12:24 PM   #5670
poorsche
poorsche's Avatar
The only temp related issues if heard of were maf/map related, I wonder how oil temps are affecting driveability?
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
