Drives: 13' Scion FRS Track car
GT86 German Cup series - documents
I was looking for roll cage build form factory and I stumbled upon some very interesting document about the German GT86 cup series.
Unfortunately they are in German, but they have a VERY VERY precise documentation of the car modifications. it is loaded with small mods. Considering the series is backed by the manufacturer I would assume they have very good source for what needs to be modified or not. I hope someone here can read german and provide some feedback. couple of cool things include some cluster mod offering a shift light and buzzer.. I assume it comes with the ECU change, but would be cool to have
2013 Scion Frs Track Car - Sold.
| The Following User Says Thank You to philooo For This Useful Post: | Pat (12-03-2014) |
#2 |
Some preliminary notes:
- Very soft springs. Seems like a very conservative setup, but Ohlins have external reservoirs...looks like a 2-way TTX setup with super beefy camber plate. (EDIT: Rechecked specs and actually the spring setup is very similar to our setup, but stiffer (13k/16k) due to the type of tires they're using) - Small oil cooler using a high quality core - Motor is untouched - Warns that Torsen LSD must be used (I'm just guessing) which means Clutch-Type LSD would be a cheater mod... - Differential housing is enlarged for more oil capacity + includes a cooler - Dual exhaust exhaust with high flow cats welded at the tip - Lists two different FD. I think one uses STD Torsen LSD from the factory and the other uses an upgraded Torsen unit. - Monster TMG strut tower bar... - Project Mu 999 brake pads (we love this brake pad and have some in stock if you guys are interested). - OZ wheel 17x8 +50 must be a nice light wheel, but also shows 8" is really all you need for factory power. - Spec dry and rain tires. - Standard rotors w/ TMG SS lines + AP Racing 660 fluid...basically RBF660. - Brake ducting included so this is meant for W2W racing...not quite necessary for time attack. - Full data logger, fire suppression system, and complete roll cage. This is a pretty sweet ride. As noted, Ohlins like softer spring setups (standard basic knowledge) and roll stiffness looks to be on the softer side. This car looks like a 80k car...any pricing? Last edited by CSG David; 12-03-2014 at 05:02 PM. |
| The Following User Says Thank You to CSG David For This Useful Post: | Pat (12-03-2014) |
#3 |
Oh man... Ohlins TTX...
#4 |
I am attaching the price list
![]() 40k euro, not that bad for a clean car with toyota backing. BTW: the roll cage design is similar to their rally car CR-V3, to the exception of the bar going into the engine compartment for the rally car. Too bad that roll cage is not NASA/SCCA friendly because this is the only roll cage with the backing of Toyota motorsports. I was trying to find good specs on the cage but no luck so far.
#5 | |
#6 |
Any specs on the sways? I'm guessing typical european soft spring stiff sway...
#7 |
Looks like 18mm front and 14mm rear sways...uber soft...and yes...we're communicating via forums...LOL
NINJA EDIT: looks like 130kg/cm front and 160kg/cm rear springs...aka 13k/16k setup which indicates something...:P Last edited by CSG David; 12-01-2014 at 03:07 PM. |
#8 |
Dat break in communication...
#9 |
I don't think I have seen any amateur racing series with such a good documentation
ahhh zee germanz
| The Following User Says Thank You to philooo For This Useful Post: | CSG Mike (12-01-2014) |
#10 | |
Drives: 2013 Raven Scion FR-S
Emmanuel Baako: NASA-Southeast Race Control & NASA Florida Race Director
![]() RaceCar:2013 Scion FR-S #986 NASA PTD || Tow:2011 Dodge Durango R/T ![]() |
#11 |
StreetKart
Drives: 2014 Scion FR-S Monogram
seems kind of pointless... just extra weight hanging at the back and they wont get hot enough to work properly.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#12 |
#13 |
Drives: 2005 Toyota Camry
#14 |
sorry about that, my bad. I thought the horizontal harness was mandatory within the main hoop, but it is not...
oups
| Entertaining German GT86 review | NWFRS | Scion FR-S / Toyota 86 GT86 General Forum | 18 | 11-06-2014 07:31 PM |
| The German Take on the GT86..... | ntron1 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-28-2013 04:38 PM |
| Subaru Graduate Program Documents | Motopythons | BRZ First-Gen (2012+) — General Topics | 5 | 06-03-2012 12:09 PM |
