Old 12-02-2014, 11:30 AM   #2283
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by STV3 View Post
So after reading all these good things about the OFT I am now thinking about getting one.
Just want to know two things.
1. Can you disable the secondary O2 sensor with the OFT to rid of the P0420 code?
2. If so, will this allow me to pass inspection. Basically when they plug into the OBD2 port for the inspection, it wont read as if the ECU is in open loop (I think thats what it is called) like I just reset my ECU to turn off a CEL.
1) Yes - you can disable the P0420 DTC with any flashing tuning solution.
2) Depends on your state and condition of exhaust system. Technically, as soon as you touch either of the OEM cats, it's no longer in compliance. Some states will perform a visual test and you'll fail that immediately. Others will perform a sniffer test and depending on how well your secondary cat works, you may or may not pass. Still other states perform only an OBD2 readiness test, and in those states, you'll pass, assuming the other sensors are all reporting OK and ready. You can use an app like Torque or some other OBD2 scan tool to check the readiness status of all of your sensors. Some states allow you to fail 2 of them and still consider your car passable.
Foobar is offline
The Following User Says Thank You to Foobar For This Useful Post:
STV3 (12-02-2014)
Old 12-02-2014, 11:44 AM   #2284
Foobar
SLO NO MO
Foobar's Avatar
Originally Posted by kodyo View Post
I don't think the quality is quite the same though (material and workmanship). This is mostly speculation based on the fact that FT86SF actually lists the material and OFH just lists it as stainless, and the fact that OFH is made somewhere in east asia, and FT86SF is made in the US. I did consider the OFH/OFT combo, but decided to go with this since I wasn't ready for a tune and wasn't sure about the quality of the OFH headers.
For what it's worth, OFH is only a 1 year warranty. FT86SF is lifetime.
Obviously I'm going to be pretty biased since I already purchased this and haven't had any issues.
My OFH is marked as SUS304 which is the same grade as the FT86SF I believe. Workmanship - I'm no expert on tubing/welding, but it definitely looks worlds cleaner than a Borla. FT86SF's lifetime warranty is definitely head and shoulders above the competition.
Foobar is offline
kodyo (12-02-2014)
Old 12-02-2014, 12:06 PM   #2285
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Howeveeeeer.
You are able to get OFH+OFT for 1k. Which is the price for these headers alone, so there are some definite tradeoffs.
If you get this header + OFT (most people like tunes) you're basically paying 500 for a lifetime warranty, at least that's one way to look at it in comparison to the OFT+OFH combo lol.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline
The Following 2 Users Say Thank You to Phantobe For This Useful Post:
Foobar (12-02-2014), YangerD (12-02-2014)
Old 12-02-2014, 12:12 PM   #2286
STV3
Señor Member
STV3's Avatar
Ok awesome thank you!
Yeah the O2 readiness is all I need here in NY. Plus I have a good mechanic that I am close with that knows I modify my cars. They pass my SRT-4 which has a straight pipe on it but no CEL's due to my Mopar Stage 1 ECU which just doesn't pick up any CAT related codes I guess.
STV3 is offline
Old 12-02-2014, 12:17 PM   #2287
Foobar
SLO NO MO
Foobar's Avatar
You're fine then - I'm also in NY and while our car's not old enough to get the smog check yet, I'm confident it will pass.
2015 will be the first year the 2013 models get smog checked in NY, so I'm set until August.
Foobar is offline
Old 12-02-2014, 12:59 PM   #2288
Trettiosjuan
Drives: GT86
Originally Posted by Phantobe View Post
Howeveeeeer.
Howeveeeer.
I got this header because it has a cat which makes it cleaner and quieter and that can only partially be compensated with a catted front pipe. And not at all if you already have a catted front pipe, so for me an OFH wasn't even an option.
And, can't compare power figures, but I remain in the idea that this header is the easiest way to remove any torque dip, no special tuning needed.
Trettiosjuan is offline
The Following User Says Thank You to Trettiosjuan For This Useful Post:
kodyo (12-02-2014)
Old 12-02-2014, 03:39 PM   #2289
Phantobe
Phantobe's Avatar
Originally Posted by Trettiosjuan View Post
Howeveeeer.
I think a comparison thread is in order because I'm considering these two setups lol.
OFT+OFH vs. FT86 SF Catted UEL
They are pretty much at the same price point.
Phantobe is offline
Old 12-02-2014, 03:44 PM   #2290
Foobar
SLO NO MO
Foobar's Avatar
I wouldn't put a Tune + uncatted header against a catted header by itself as a fair comparison, unless you're just comparing sound.
Foobar is offline
Old 12-02-2014, 03:55 PM   #2291
Phantobe
Phantobe's Avatar
Well to me it's worth cross shopping the two. Didn't say anything about it being fair but for "x" amount of cash these two setups to be fairly popular and offer good bang for buck.
Each will have its own pros and cons, I'll do me some research when I'm home. I'm a cali resident so sound is a bit of a concern, as far as loudness.
Phantobe is offline
Old 12-02-2014, 04:03 PM   #2292
Foobar
SLO NO MO
Foobar's Avatar
They serve two different purposes though, apples and oranges. What is the comparison?
Power? Tune + Uncatted wins.
Value? Tune + Uncatted wins.
Ability to reduce emissions? Catted wins.
Ability to use on a purely stock intake/exhaust car without throwing CEL without a tune? Catted wins.
Foobar is offline
Old 12-02-2014, 04:17 PM   #2293
STV3
Señor Member
STV3's Avatar
Just ordered my OFT from FT86SpeedFactory. Will update everyone once it comes in.
Also I am now running a Greddy Supreme SP catback with my header and catted motiv front pipe (CEL was an issue before I added the catback)
Pshh and I bought this car as my daily and said I was going to keep it stock.... SMH
STV3 is offline
Old 12-02-2014, 04:23 PM   #2294
chas3wba0
chas3wba0's Avatar
Drives: Yes
I daresay catted also wins in the sound department... uncatted can get pretty raspy--unless you're into that sort of thing
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
chas3wba0 is offline
The Following User Says Thank You to chas3wba0 For This Useful Post:
STV3 (12-02-2014)
Old 12-02-2014, 04:46 PM   #2295
Foobar
SLO NO MO
Foobar's Avatar
Mine is not raspy, but I have a resonated Perrin catback and catted Perrin front pipe, so even that comparison isn't fair, and it's really subjective since one's priority might be on quietness, which the catted would definitely win, whereas another's might be on volume, which the uncatted would win.
As far as I can slice or dice it, the FT86SF Catted UEL serves a different population than the uncatted counterparts out there, and when we're specifically talking about OFH, I don't think you can go wrong with FT86SF vs. OFH, so long as you know what you're looking for. Price/value, I'd have to give it to OFH, of course, but if you need/want a cat, then I'd definitely give it to FT86SF.
Foobar is offline
Old 12-02-2014, 04:47 PM   #2296
Phantobe
Phantobe's Avatar
Well that's a very crude way to compare things, I'm more interested in metrics & what not I'm very meticulous in deciding on things. My comparison will be much more detailed.
I'll do the research myself its for my own curiosity really.
Phantobe is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
