Old 12-02-2014, 02:29 PM   #1
WGMGR
Drives: WRB Limit BRZ 2015
IS IT NORMAL
For your car to sit at 1 rpm when you push in clutch at speed? (Like it won't drop to idle (0.7 to 0.6) untill you come to a fully stop?
Also does turning on the air make the car go from 0.7 rpms to 1 and slowly back down or is this not normal?
WGMGR is offline   Reply With Quote
Old 12-02-2014, 02:43 PM   #2
Well 1 rpm is never normal!
If you add 000 or 00 to the rest of what you said it is all perfectly normal and nothing to worry about at all.
At speed you are just not holding the clutch in long enough (and don't it is not a good thing to free wheel too much).
The AC compressor kicks in and out and causes the fluctuation.
JohnJuan (12-02-2014), R2RO (12-03-2014), Ramster (12-02-2014), raven1231 (12-03-2014)
Old 12-02-2014, 02:52 PM   #3
8R6
8R6's Avatar
Drives: FRS
first manual transmission car?
8R6 is offline   Reply With Quote
Old 12-02-2014, 02:58 PM   #4
FR-STY 86
FR-STY 86's Avatar
Drives:
I have never held the clutch in while coasting, I think it may be extra wear on the throw bearings, so not sure. Just don't do that and there will be no problem =D
Yes when parked w/ the AC on my tachometer behaves in the same way. Components of the AC must be belt driven, turn off for max SPD
I love noticing these types of intimate details.
FR-STY 86 is offline   Reply With Quote
Old 12-02-2014, 03:01 PM   #5
WGMGR
Yeah, first car in general. Had asked my dad and he said he thought it wasn't normal (he owns a passat v6 manual, 2002 though)
Old 12-02-2014, 03:04 PM   #6
VakaGT
VakaGT's Avatar
Drives: None
normal. hes talking about when you push the clutch in in between gears. yeah it drops to 1 (im assuming you mean x1000) or something.
My Build Thread
Instagram: neel.vaka
VakaGT is offline   Reply With Quote
Old 12-02-2014, 03:07 PM   #7
If you are dropping your revs to 1000 between gears you are not driving this car right!
Old 12-02-2014, 03:07 PM   #8
that_one_guy
Drives: none
Neither you nor your dad understand why you do what you do when you drive your manual car. That's ok, but if you read up on what is happening when you engage the clutch pedal, shift gear, release clutch pedal, and how your engine builds power, most of these types of questions will be answered before you even think of asking them.
that_one_guy is offline   Reply With Quote
Old 12-02-2014, 03:09 PM   #9
WGMGR
I'm not talking I drop it to 1000 while actually driving but if you hold the clutch I thought it should go to idle not 300 above idle
I guess I didn't write the Op right. I meant hold it in at speed not just pushing and shift (obviously I'm not dropping to 1000 to just shift. I wouldn't get anywhere!)
The Following User Says Thank You to WGMGR For This Useful Post:
Tcoat (12-05-2014)
Old 12-02-2014, 03:13 PM   #10
VakaGT
VakaGT's Avatar
Drives: None
I dont, but im assuming he hold clutch and lets it drop or something weird, seems like a new manual driver? im just saying if he WERE to do that it would drop to right about there before he shifts, maybe a bit higher
edit: but yeah this guys right, O.P. you should be shifting much quicker and definitely not waiting for the RPMs to drop anywhere near that low before you shift. Practice in a large parking lot..
My Build Thread
The Following 2 Users Say Thank You to VakaGT For This Useful Post:
Frishkorn (12-08-2014), Tcoat (12-02-2014)
Old 12-02-2014, 03:15 PM   #11
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Yes. It will not idle when pushing the clutch in at speed. It's not designed too. You also shouldn't do that.
The Following User Says Thank You to Reaper For This Useful Post:
VakaGT (12-02-2014)
Old 12-02-2014, 03:15 PM   #12
VakaGT
VakaGT's Avatar
Drives: None
you shouldn't be "holding it in at speed"
Throw down the clutch and shift, essentially after gear 2-3 you can basically pop the clutch as you're shifting... you dont need to baby it.
My Build Thread
Old 12-03-2014, 01:14 AM   #13
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
He's talking about when coming to a stop, not when shifting!
Yes it's normal, I don't know why it's like that but my truck does the same thing, my guess is if have to let the clutch out in an emergency it shouldn't stall right away but rather chug, which could save you from being hit.
Gords_zenith is offline   Reply With Quote
Old 12-03-2014, 01:30 AM   #14
What about these?
Is this normal? Dino451 Scion FR-S / Toyota 86 GT86 General Forum 20 10-11-2013 12:56 AM
Is this normal? BlackyRose Engine, Exhaust, Transmission 8 10-04-2013 11:54 AM
Does this look normal to you? white_knight Issues | Warranty | Recalls / TSB 13 03-03-2013 03:10 AM
Is this normal? ArKiTeCkT Engine, Exhaust, Transmission 3 10-29-2012 02:54 AM
Is it normal to see a .... Mango22 BRZ First-Gen (2012+) — General Topics 10 10-12-2012 02:54 PM
