Drives: 2013 FRS Whiteout
Hello guys and gals
I'm sure its possible to switch from the factory led strip to oem fog lights but would it be possible to use the led strip wiring/connection and toggle switch? I would prefer to hear from those who have done this if anyone has to avoid confusion or speculation. I think the wattage may not be the same and the led's dim when the headlights are on so i know there's some connection to cause this.. I wanted to use the same switch under the dash to turn on the fog lamps. Maybe some of the electrical guys could chime in. I do not know what type of connection the led's use, wire gauge, nothing really but i could find out.. Thanks. I snapped this pic of the under dash wiring... god this looks messy and complicated to me.. these two little wires come from the engine bay into what looks like a balast controller. Again this is all russian to me.. but maybe someone could help out.
#2 |
Drives: Scion FR-S 10 Series #2263
If you look at this DIY, you can see what the different colored wires do.
I am 99.9% certain you will see a blue wire going to the engine bay, and connected somewhere to your headlight wire - that is causing the LED strip to dim when your headlights are on. Actually.........the manufacturer on that "ballast" (actually a power control module) is different from the one I bought from - Auer vs Topsage - so I'm not sure if the control wires are the same color. In the Topsage kit, if you connect the blue wire to the headlight power, then it dims the LEDs, if you connect the white wire to the headlight power, then it turns off the LEDs. *EDIT* So I google'd the company and the installation directions: http://auerautomotive.com/images/pdf/1/SFR-313.pdf That is some unecessary, overly complicated shit lol. So much dissassembly of trim panels and body panels. But if you were curious about what the wires on your kit are located/do, please take a look at the instructions. |
#3 |
I actually did go to their site but was checking out the fog lamp installation instructions. Thanks. I think the LEDs will have to be removed because the fog lamp kits out there usually connect to the battery and the connectors for the bulbs are also completely different. Unless a company makes a kit for vehicles with LEDs.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
#4 |
Drives: 2013 Raven FRS MT
Just to confirm...the LED DRL strips are OEM from Toyota?
#5 |
Drives: 2013 asphalt scion FRS
Looks like it. That's the same controller my oem led strips came with mounted in the same exact spot.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car) 1995 gmc 1500 4x4(off road toy) 2005 Yamaha yz250f |
#6 |
Install from oem led strip to fog lights
Yep oem installed from Toyota. I emailed diode dynamics to see if they have sown thing or have ever considered doing something like this. May not be coming but after 2014 FRSs steered coming with those LEDs.
#7 |
Drives: 2013 FRS- Hot Lava
They're not OEM, they're a GST or SET accessory. And since you're from Florida, I'll guess SET. They'll be the same as the people with the aftermarket led strip so you may want to look up their install instruction.
#8 |
Izzy Gure (Senior Member)
Drives: FR-S TRD Release Series 1.0 / #1459
I hate it when I look at a new FRS on the lot and GST has installed the LED strips. They add an additional $399 to the sticker. I agree that the FRS was made for fog lights. Hope you get a quick fix on the switch.
#9 |
Not sure what the acronyms mean or if they're even acronyms but they're made specifically for Toyota from auer, the company logo is in the picture I posted. I did go to their website and checked the info they had. I don't mind them but I would rather have fogs. I'm just not great with t electrical stuff so I would rather pay for a plug and play solution. Let's see what @Diode Dynamics has to say
#10 |
GST is gulf state Toyota and SET is southeast Toyota. They're two of the twelve regions for Toyota sales. Because they were the first two regions established and have a more relaxed contract (with Toyota motor corporation, not TMS), they can and will do things like port installed accessories which are then labeled as "OE".
| "LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" | F-T | Exterior Parts - Lighting | 169 | 08-20-2016 01:15 PM |
| Questions regarding dealer added lower area foglight LED strip lights | NLS8520 | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-22-2014 11:17 AM |
| Switching fr-s DRL strip to fog lights | Crosscharge | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-01-2014 11:48 PM |
| "LED Strip Daytime Running Lights and Valenti Tails --- Shipped Anywhere!!" | F-T | Exterior Parts - Lighting | 187 | 05-15-2013 01:07 AM |
| Can anyone help install fog lights? | YDNA | Southern California | 0 | 03-24-2013 09:58 PM |
