Old 11-27-2014, 01:13 PM   #1
huhu89151734
Drives: 2015 WRB BRZ
Please help choose canyon driving suspension
Hello all! I am looking to upgrade my suspension, and kind of stock with choosing between two options...
1:Stock strut with Swift sport spring, Racesang cam plate, SPL lower control arm.
2: RS*R Sport-I coilover with SPL Lower control arm.
My need is that I LOVE canyon driving and I drive 8.3 miles of canyon road 3-5 times per week. I need to improve the grip, and ease of handling the car when going over a high speed bump. I do not want to mess with 2 way adjustable, so 1 way is good for me. I run 18*9.5 square set of wheel with street summer tires, no plan to use racing tires in the future. I might upgrade my front lip (or wing, depend on what I feel the car lack of later). My current power mods are only OFT 91 ounce stage 1 tune and KN drop in filter, no plan to spend big money to increase power.
My question would be, which option suits me the best? Or should I go for something else? RS*R sport Racer maybe? Whats in your mind?
Oh forgot, My budget is $2k - $2.5K not including the lower control arm and cam plate.
Thanks!
huhu89151734 is offline   Reply With Quote
Old 11-27-2014, 01:44 PM   #2
Derka
Drives: 2015 frs
Why not include the budget of the cam plate into your coilover budget and look at a set of ohlins r/t?
Derka is offline   Reply With Quote
Old 11-27-2014, 08:20 PM   #3
troek
troek's Avatar
Drives: 2012 Toyota 86
what set of tires are you running? the stock tires are branded as street summer tires.
troek is offline   Reply With Quote
Old 11-28-2014, 03:23 AM   #4
CSG Mike
CSG Mike's Avatar
If you're driving hard in a canyon, you really should be hitting the track.
And, you don't want to skimp on suspension if you're on the roads I think you're on.
Firestorm_86 (11-30-2014), wparsons (11-30-2014)
Old 11-28-2014, 11:20 AM   #5
huhu89151734
Thought about it, but CSG DAVID once mentioned CSG guys dont really like it
I am using Michelin super sport
So what are you suggesting, Mike?
Old 11-28-2014, 11:54 AM   #6
JDB
Drives: FRS
Before you start there I would:
1) Sub Frame bushing inserts (a must!!!) ($40)
2) Perrin Steering Lockdown (best Mod I have ever done on this car) ($80)
3) TRD Short Shifter (WAY quicker shifts, and still warrantied)($180)
4)Transmission and Differential Inserts ($30 and $53)
For about $383 you will have a completely different car on those roads......and only after doing this would I even start looking at suspension systems.
2013 lava trd exhaust, trd intake, trd short shifter, trd lowering springs, whiteline sub bushings, whiteline diff bushing, whiteline transmission bushing, eibach sway bars, perrin steering lockdown, tech shift springs, mtech shift knob
JDB is offline   Reply With Quote
Old 11-28-2014, 03:52 PM   #7
Racecomp Engineering
IMO the Ohlins are freaking awesome for a road and some track coilover. Pretty much perfect for you, unless you'd like to lower more than an inch.
- Andy
Old 11-28-2014, 06:33 PM   #8
wootwoot
Drives: FRS
I'll agree with this. These parts are a great way to start a canyon build. They make the car feel awesome. The sub frame lock out bushings should be done before the car is allowed off the lot IMO.
For your goals I would do a Bilstien and spring package or the isports. A set of $3000 dollar coils for canyon driving seems a bit much unless you have the money burning a hole in your pocket. Either of those two set ups will be a step up from stock which is already very capable.
Old 11-28-2014, 08:24 PM   #9
troek
troek's Avatar
looks like you got some of the best street tires they make. and i agree with some of the others, i would include all the camber adjustment stuff into your coilover price and go as high end as you can. the fact that a suspension company is recommending another companies coil over speaks loudly to me.
Old 11-28-2014, 10:14 PM   #10
CSG Mike
CSG Mike's Avatar
The damping quality is awesome. What we don't like is the spring balance they come with from the factory.
Old 11-29-2014, 01:24 AM   #11
huhu89151734
Thanks for the guys who advice me to look for those additional mods to improve handling, I all definitely do some study on those parts!
Also Thanks Andy and Troek talk me back to Ohlins hah! Sounds like both Mike and Andy feel the springs on Ohlins is a problem, cuz I know that Andy changed their R/T springs to 8K square and felt much better. But if I really go for Ohlins, it will be on top of my budget and I wont be able to have more money to do mods on the springs.... But if I remembered right, Divd @CSG posted a comment on someone else's threat and said RS*R club Sports works like baby ohlins R/T, and the springs rate is 8K square. Now I think it is Ohlins vs RS*R
Old 11-30-2014, 09:47 AM   #12
wparsons
wparsons's Avatar
What tires are you running? 8k rates might be too much spring for the tires you plan to keep using. Being too stiff actually reduces mechanical grip unless you need the stiffness to control body motion from the grip your tires can produce.
flickr
Old 11-30-2014, 11:12 AM   #13
We did switch to 8k springs, but you don't need to. We were doing some experimenting and yes it was a little faster at the track, but it's not a must do by any means. The standard springs are very good too.
- Andy
CSG Mike (12-01-2014), wparsons (11-30-2014)
Old 12-06-2014, 03:23 AM   #14
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
Very much agree on numbers 1 and 4! Super value, the way the car should have been built. Easy install, and the only downside is minor gear whine. The upside is the car no longer hops around in low-speed turns, or jiggles over high-speed bumps.
*snip
You've got $2k earmarked for lowering springs? I have great news!
My FR-S has a build thread!
(It's mostly full of Nissans)
NissanGuy is offline   Reply With Quote
Suspension / Coilovers ~ How to Choose the Right Setup for YOU Circuit Motorsports Suspension | Chassis | Brakes -- Sponsored by 949 Racing 30 09-24-2015 01:53 PM
Optimal tire size for DD and canyon driving? ashtray Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 11-26-2014 04:22 PM
Suspension UPGRADE - Shock/Spring Pkg vs. Coilover System - Which to choose? themajesticone Suspension | Chassis | Brakes -- Sponsored by 949 Racing 80 11-14-2014 06:01 AM
Looking for picture of BRZ driving through canyon slowbrz BRZ Photos, Videos, Wallpapers, Gallery Forum 0 09-10-2013 05:43 PM
BOX CANYON ric342 Southern California 5 06-27-2013 02:39 AM
