#7071 |
@Pbrown maybe they will confirm the Supra launch before the spring, in which case you can put all of that money towards the down payment.
| The Following User Says Thank You to jvincent For This Useful Post: | jhx741 (11-27-2014) |
#7072 | |
Drives: 2013 Scion FRS Raven
LOL! I need to know by June 6th, 2016. I was looking at the videos of the car over the weekend and there is no way in it's current form it will be under 70 k especially if the engine is over 400 horse. Stunning vehicle for sure. |
#7073 |
Drives: FR-S Firestorm 6MT
#7074 |
Drives: 128i
Yep - Eibach ProKit. With the springs and the $7 crash Subaru bolts to give you more camber and you'll be set for the track suspension wise! The drop is a bit less than 1"
The front ones just need to be removed from the OEM struts - I don't have a spring compressor. You can have them if:
What's wrong? |
#7075 |
Drives: 128i
#7076 |
Drives: 128i
| The Following 4 Users Say Thank You to normancw For This Useful Post: |
#7077 | |
Drives: 128i
#7078 |
Will do. I sent them email today so I should hopefully hear back this week.
Anyone else interested in case there is group pricing? |
#7080 |
#7081 | |
Are you 20/20?
Drives: Hopes and dreams
![]() I need a cheaper hobby.
#7083 | |
Drives: '14 BRZ WRB
I'd be interested as well. Thanks! |
#7084 |
Drives: 128i
It was a huge difference, but I changed a lot of other suspension things at the same time (steering rack bushings, rear subframe inserts, rear sway bar, wheels/tires, caster/camber plates, rear LCA, front camber from -2.0 to -3.3). I did notice the damping was much better.
| The Following User Says Thank You to normancw For This Useful Post: | Chico (11-27-2014) |
